Results 1 to 6 of 6
    pyroclastic flow
    Reputation: troyer2112's Avatar
    xtr wheelset and geax tnt barro mountain 2.3
    i was wondering what i would need for tubeless conversion with shimano xtr wheelset and geax tnt barro mountain 2.3 tires. i know i need some sealant but no strip. what else to complete the job.
    thanks in advance
    "THE FACT IS THIS FRICTION WILL ONLY BE WORN BY PERSISTENCE"
    2009 PIVOT MACH 4
    Reputation: gticlay's Avatar
    Quote Originally Posted by troyer2112
    thanks in advance
    Air, and lots of it.
    "It looks flexy"
    Reputation: macming's Avatar
    thanks in advance
    Tubeless valve and possibly an air compressor
    Former Bike Wrench
    possibly some patience...though a UST rim and Tubeless Ready tire should limit the frustration.
    Quote Originally Posted by mtnbiker72
    Aren't the new XTR rims UST? I guess it'd depend on which generation the op has
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by macming
    isn't that what he said?
    OP- most likely you'll be able to air up with a floor pump. Don't forget to use soapy water to lube the bead & help get it seated.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
