Results 1 to 5 of 5
    Reputation: csparks66's Avatar
    XC Raceday flat repair kit setup
    What do you carry, how do you carry it? Running tubeless.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    two tire levers, a multi-tool, & a CO2 inflator in the zipper bag that came with the inflator; a tube with a zip tie around it; and a pump (got burned once by the CO2, but you can't beat 'em for speed)... in jersey pockets
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    I use electrical tape to tape together:
    1. a tube
    2. a tire lever
    3. an Innovations Big Air 40-gram CO2 canister, with the Innovations Air Chuck Elite threaded onto the CO2 canister and electrical-taped down so it can't spin off.
    And I stuff that in a jersey pocket.
    The Innovations rep would recommend their 25-gram CO2 cartridge instead of the 40-gram Big Air, because the higher internal pressure of the 25-gram cartridge gives a better "rush" if you're trying to get a tubeless tire to seat & seal. But if I'm putting in a tube anyway, I'd rather use the Big Air. The cannister's significantly lighter, being aluminum, and it can get even a high-volume XC tire pretty hard so I don't have a pinch flat while trying to catch back up. And they're cheaper than the pricey 25-gram cartridges too.
    Never trust a fart
    Reputation: frdfandc's Avatar
    The last 2 races I did were short, so I only carried 3 CO2 cartridges (16 oz) in case of a tire burp. Other than that I carried nothing.
    But the other races where I was using a camelbak, It was 2 tire levers, 3 CO2 cartridges (16 oz.) spare tube. I figured I was already hauling 100 oz of water (couple of the races were hot/humid), whats another 1/2 lb of stuff in the pack.
    Quote Originally Posted by mechBgon
    1. a tube
    2. a tire lever
    Good information. I like this setup. Simular to what I have been doing but wasnt sure if tubeless setups had a good alternative instead of carrying a tube. You just cant risk not having a tube...
