Results 1 to 2 of 2
    Reputation: turnerth's Avatar
    Aug 2010
    X-0, Elixir CR + XTR Hub
    I am ordering a new rear XTR/Edge XC wheel.
    will I be able to run my existing 9 speed SRAM cassette?
    I am also buying a XTR CL rotor. Will I have any issues getting my Elixir CR breaks to line up? Not including the normal CR headaches.
    Appologies if these have been answered - I did searches / did not see a clear answer.
    Reputation: brentos's Avatar
    Any Sram or Shimano 9 or 10 speed cassette will fit an XTR hub.
    You can use an XTR centerlock rotor with Elixirs. But you will have to remove about 1/16" of material off the bottom of the caliper. Mount everything up, see where it interferes, and you'll see what I mean. 30 seconds with a dremel or file. Easy as cake. Once mounted, it outperforms my cleansweep G3 rotor up front.
