Results 1 to 14 of 14
    Moderator Moderator
    WTB Vigilante Review
    In August of 2013 I mounted up a WTB Vigilante 2.3 Team TCS.
    The Vigilante replaced a Hans Dampf. I found the Hans Dampf to be too light for my weight and terrain; I was tearing off the row of knobs between the center and outer edges. The HD works great on the front through.
    I only had 2 "flats" with the WTB, the first was a rusty nail right through the tread when the tire had about 300 miles on it. The hole was too jagged for the stans sealant to close up. I patched this with a panracer rubber plug and never had a lick of problem with that patch.
    Today I was noticing that I was not getting the kind of braking performance I was used to. The center knobs were worn down to almost nothing. I decided I'd retire the WTB at the end of the ride. About a quarter mile later I hit a rock and put an inch long slice in the side wall; failure no. 2.
    I just checked my strava. I have 1,012 miles on the tire which is a good long way for me. Over all I'm super happy with the tire. Its the only tire I've ever worn out before I damaged it beyond repair. Two thumbs up for the Vigilante.
    Reputation: Burt4x4's Avatar
    Feb 2013
    You never say if this is on the front back or both?
    The Vigilante is on my list as possiablle rear tire...so just curious....
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Moderator Moderator
    You're right. I kind of implied it in the HD discussion but I never really said it. I had it as a Rear. Vig on the Rear, Dampf on the Front. It's also a 29er, set up tubeless on WTB's i23 rims.
    Apr 2014
    Seems a lot of people are knocking WTB tires. Not sure why I have been on them for years and currently running a vigilante on the from and Weirwolf in the rear. Awesome set up for the dry terrain in Tahoe and the best combo I have come across. Glad to hear about the durability you got from it. WTB.Thumbs up
    Mar 2012
    Started usng a vigilante team issue recently. Done a couple days of racing, a few trail rides, and a couple days at keystone bike park. Absolutely love them. Wearing really well, especially for how soft they are. Grip in the loose, blown out stuff or wet is very confidence inspiring. Even pushing are on hard-pack, they hold well.
    Used DHF, DHR II, HR II, HD, butchers and these are by far my favorites.
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    I have one on the shelf, cant wait to try it.
    I am currently running butchers, only reason I have swapped yet is I am lazy.
    Reputation: dirtrider76's Avatar
    Sep 2012
    I switched to a WTB Weirwolf not long ago in back and absolutely love it so far. I tend to chew up rear tires and its held up great.
    I like to fart when I'm in front of you on a climb
    Reputation: bigkat273's Avatar
    Glad to hear the vigs are doing well. I just ordered a set of the new trail boss light version. Same basic tread just a bit tighter for quicker roll.
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    I would wholeheartedly recommend the Vigilante to anyone. I was turned onto it by my wheel builder (dustydukes22) and I love them. Super easy to mount up tubeless as well.
    Royalston Mass
    Reputation: Bertleman's Avatar
    The only problem I'm having with with mine is too much traction in the rear....I can't slid them in the corners...going to try a WTB beeline in the rear next
    Don't argue with idiots...they will take you down to their level and beat you with experience
    Moderator Moderator
    Quote Originally Posted by Bertleman View Post
    I've got a couple rides in on the new Vig now. I've had to up pressure in the Vig on the rear and drop pressure in the (worn) Dampf on the front. The rear tire was out gripping the front which made for some curious handling.
    I also took a dremil tool and ground down the outter edge of outter knobs. This lets the rear drift a little sooner in corners and helps keep the tire from rubbing the chain stays when the wheel deflects.
    Royalston Mass
    What pressure are you running and what's your weight?
    Moderator Moderator
    250#
    Running 25 pounds in the front, 30 in the rear...tubeless.
    Reputation: jazzanova's Avatar
    Www.steepandcheap.com has 27.5 for $28
  1. New WTB Vigilante tire?
    By zarr in forum 27.5
    Last Post: 06-03-2014, 05:09 AM
  2. WTB i23 rims + WTB Vigilante tyres
    By cfrench in forum Knolly
    Last Post: 12-01-2013, 01:54 PM
  3. WTB Vigilante- Underweight
    By Cary in forum Wheels and Tires
    Last Post: 09-24-2013, 08:04 PM
  4. Any news on the WTB Vigilante?
    By eugenemtbing in forum Wheels and Tires
    Last Post: 06-08-2013, 10:36 AM
  5. WTB Vigilante 2.3
    By evasive in forum 29er Components
    Last Post: 02-26-2013, 10:03 AM
