Results 1 to 9 of 9
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    WTB TCS Weirwolf wont mount on Bonty TLR rim
    Darn bead is just too tight. Can't get the second side mounted more than 3/4. Busticated 2 tire levers. I have tried soapy water, Vaseline, leaving it out in the sun.....nothing works. Every time I try and push up the last 1/4, it pops off somewhere else.
    And to make matters worse I can't even take the tire off! The one side that is mounted wont lift over the rim to remove it.
    VERY frustrated. Any tips/suggestions?
    Veni Vidi Biki
    I came, I saw, I biked.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    they are tight, just make sure you get the bead down in the bead pocket in the rim all the way around.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by skankingbiker View Post
    http://mtbtires.com/site2/tech/77-ho...mounting-video
    http://mtbtires.com/site2/tech/77-ho...-removal-video
    mtbtires.com
    VENI VEDI BIKI
    Quote Originally Posted by hitechredneck View Post
    I cant get the bead over the rim
    Veni Vidi Biki
    Dec 1998
    Which is why you need to do that.
    Watch the videos.
    mtbtires.com
    VENI VEDI BIKI
    Quote Originally Posted by shiggy View Post
    Watch the videos.
    Do what:?
    I watched the videos. The tire just rolls on in the first one. I can't push mine up like he does in the video.
    Veni Vidi Biki
    Dec 1998
    Do what:?
    Because you need to get the tire bead into the center drop of the rim.
    Detailed better in the removal video.
    mtbtires.com
    mtbpete
    Reputation: changingleaf's Avatar
    Also, Mount the valve area last! If you mount the valve area first you will have to stretch further as the valve impedes the center channel of the rim.
    Reputation: ghettocop's Avatar
    Just keep at it man. You will get it. Shiggy and the others gave lots of good tips. When I first started doing tubeless with Stans Rims and tight tires I was positive that it was impossible. Now I switch out tires all the time. While not necessary, I have found that inflating the tire you intend to mount tubeless on another rim with a tube overnight to stretch it and give it some shape helps too.
  1. Replies: 7
    Last Post: 01-31-2013, 06:58 PM
  2. New snakeskin wont mount up. Getting upset
    By machine4321 in forum Wheels and Tires
    Last Post: 07-28-2012, 10:42 PM
  3. new tire wont mount to rim
    By 4low in forum Wheels and Tires
    Last Post: 08-31-2011, 06:41 PM
  4. Old Weirwolf VS. Ardent VS. New Weirwolf
    By hitechredneck in forum Wheels and Tires
    Last Post: 06-07-2011, 03:42 PM
  5. Bonty 29-4
    By noosa2 in forum 29er Bikes
    Last Post: 12-31-2010, 01:36 PM
