Results 1 to 5 of 5
    WTB SX-24 replacement wheel suggestions?
    So I just picked up a new to me Iron Horse Warrior 6.0 which happens to have a pretty well bent rear wheel. I want to replace this, but I am completely lost when it comes to the wheel choices out there.
    I weight about 220lbs and ride all trail with small rock gardens, some drops offs, and things like that. What would be a decent replacement for this that isnt going to break the bank. I dont feel like paying more for a set of wheels than I did for the whole bike just yet as I am still learning and building rider skill. Also, do I have to replace both front and rear and the cassette/disk brake as well or can I just swap the cassette/disk brake over to the new rim?
    Former Bike Wrench
    The existing cassette and such should transfer over just fine right? I think I need a tool for this, but I am not sure which one is needed to remove the cassette, could you point me in the right direction for my bike?
    Lastly, do I need to swap out both front and rear or will it track just fine with different wheels and I can just replace the front if I want to later on?
    One more question... is this better or equivalent to what was on there stock?
    Former Bike Wrench
    Yes the cassette and rotor will switch across. You need a chain whip and cassette lockring tool, along with a Torx T-25 for the rotor bolts.
    The hub is at least equal to your OEM hub and rim and spokes are a upgrade.
  1. Replies: 2
    Last Post: 09-02-2011, 09:38 AM
  2. Need suggestions for replacement BB
    By goeppngr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2011, 11:21 PM
  3. Rotor Replacement Suggestions
    By jbsmith in forum Brake Time
    Last Post: 04-16-2010, 06:43 PM
  4. Wheel bearing replacement or new wheel?
    By kboykin in forum Beginner's Corner
    Last Post: 09-30-2009, 03:10 PM
  5. Replies: 6
    Last Post: 05-14-2007, 06:40 AM
