    WTB Slickasaurus 1.5"
    Hey all
    Just picked up a set of these at the weekend and have been running them for a couple of days. Really impressed with the difference between these and my Semi-Slick Crossroads in terms of rolling performance and weight etc.
    Now I have an odd question, which I have tried to find, but its really experience thats needed for this one.
    The Tyres are rated at 65-80psi, now I have heard that it is possible to run slicks at higher pressures than they are rated for.
    From experience, what are people running these tyres at? What gives the best rolling performance for them, and obviously remains safe!
    Would 85? 90? 95? 100? be well outside of the limits?
    Any help is most appreciated
    Andy
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    I wouldn't ignore the rating. I once pumped up a road tire to what I figured was a safe 80 psi or so. Was only rated for 65(doh!) and it blew out the sidewall in under an hour.
    Reputation: logbiter's Avatar
    if you're a heavier guy or bike is loaded, go with psi towards the higher end. those ratings are there for a reason, it's not wise to exceed them by much. they would ride super harsh anyway.
    Hi, Thanks for the replys, it seems as though its not a good idea then Really appreciate it, I haven't ever tried it personally.
    I am running the tyres at 80psi mainly due to the bike only being used on the road, thus (I would assume minimising rolling resistance) I thought that slightly higher, i.e. 90psi would reduce this further, but if its unsafe then its not for me.
    I'm only about 70kgs so not heavy by any means, bikes never loaded, quite the opposite, bit of a weight weenie me!
    Thanks again (If anyone else wants to share experience that would be cool!)
    Andy
