Page 5 of 13 FirstFirst 123456789 ... LastLast
Results 201 to 250 of 629
  1. #201
    OK, just got my pair of i23's at the post office. 485 and 482 grams with the badge, not as light as advertised.
    There is some solid gray residue left on the inside of the bead hook, anybody else seen that? Like a tire had been mounted tubeless and that's the leftover sealant, which is of course a crazy idea since the rim is brand new (or at least is said to be).
    They seem to have some flex when I squeeze them with my arms, is that ok?
    J Random, I see your point, but the problem is, our wheelbuilder doesn't want to to take the "110kgf" figures into account Like he's been building his wheels with some tension tables, and those 110kgf are totally unnecessary. Maybe I'm using wrong terms when giving him the tension data?
    As far as the uneven drilling goes, well, this pair has it as well, that is, some eyelet facets are about 3-4mm wide, some 1-2mm, that's probably what the builder has noticed as well. Is that ok?
  2. #202
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Quote Originally Posted by DaWiseNuthatch View Post
    This is normal I think. I've only seen weights around 480 g too.
    All Frequency rims that I built with had some very noticeable uneven anodizing (discoloration) in the tire channel, but never a residue.
    Well, why not. This can be felt even in high profile rims such as Giant P-XC when squeezing them radially.
    He's probably referring to tensiometer conversion tables. Both 110 and 120 kgf readings should be present in such tables for whatever tensiometer he may be using.
    Is he suggesting that 110 kgf is too low?
    Now that doesn't sound good!
    Extrusion profile is constant throughout the rim, thus it sounds exactly like drilling has been made to uneven depth, as if the rim was ever so slightly wavy and the drill bit always went to a fixed depth relative to the machine, not to the rim material.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  3. #203
    Reputation: fermenter's Avatar
    I had some grey residue in mine too.
  4. #204
    Reputation: mud390's Avatar
    I just setup my wheels tonight (xt hubs and i23 rims). The rims had no residue on the inner surface, but they were a little dirty. I set the wheels up tubeless with some WTB Stout 2.3 tires using a Stan's kit. Everything went smoothly and I was able to set the bead with my floor pump. No compressor needed. At this point, I'm very happy with them. I'm sure that opinion won't change very much once I finally get the bike together.
  5. #205
    Reputation: in the trees's Avatar
    Mar 2005
    Regular folding bead tires (Schwalbe) with I23s? Yay or nay? Just wondering how these will setup tubeless with non TL-Ready tires.
  6. #206
    I just got the new Moto Fantom 29 Pro and it came with WTB Speeddisc I19 rims. If I were to purchase the WTB Frequency I23 rims, could I just swap out rims and be done? I can't find any full I23 wheelsets anywhere.
  7. #207
    Reputation: 4slomo's Avatar
    Hi Larsin,
    The rims have different ERD dimensions, which means different spoke lengths are required. Think custom wheel build. Easy to do.
    Quote Originally Posted by Larsin View Post
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  8. #208
    4slomo,
    Thank you for the response. I will research that further and hopefully be wheel-building soon!
    Larsin
  9. #209
    mountain biker
    Reputation: slyfink's Avatar
    Quote Originally Posted by in the trees View Post
    nay. earlier this year I ordered what I thought were TL version of the Fat Albert and mounted them to my i23 (26"). They would blow off on every medium sized jump and under hard cornering. Took me an email to Schwalbe with the serial # to find out they weren't TL ready. Starting last year (I think), all of Schwalbe tires are TL ready, even if they're folding bead. The tires I had bought were older still.
    continuous growth is the strategy of a cancer cell.
  10. #210
    So I've been following this thread from the beginning. I'm leaning towards using the i23's. I have found about 3 sets of these wheels built up with DT Swiss 350 hubs. 2 are brand new and 1 used. My question is in regards to the DT 350's. Is it a quality hub? How many poe's? Any issues with them from any users here? I'm 6'2" 180 with gear.
    *2015 Knolly Warden,Custom Build*
    *2014 Knolly Endorphin,Custom Build*
    *2016 Ibis Mojo HD3,Custom Build*
  11. #211
    Clueless genius
    Well after a warrantied rim, and a good few rides back under me, I'm happy to report no further issues! The rim in question did indeed have far too much spoke tension, and coupled with me being an awful wheel builder, the torn spoke hole was kind of inevitable really. So this time I ponied up a few bucks and had my shop lace it up and check my front wheel for correct tension while they were at it! Awesome rims, light, really stiff, and make my 2.2 tires look (and grip) like 2.4's!
    1994 Cannondale M400 2017 Felt Surplus 30
    1997 Marin Point Reyes 2013 Pivot Mach 5.7
  12. #212
    meow, meow.
    Quote Originally Posted by kevinboyer View Post
    350 should be very solid hubs. They replace 340 in DT lineup. As a Star Ratchet type hub, they have 18 POE stock and can be upgraded to 36 POE, but the latter is much more demanding with respect to correct greasing. The coasting mechanism is very modular and lightweight. Water sealing is excellent and AFAIK second to none (although this is speaking from experience with 240 and 340 hubs).
    Spykr,
    that's good news. Directional drilling certainly makes it easy to keep tightening the spokes beyond 120 kgf.
  13. #213
    [QUOTE=J. Random Psycho;9799852]350 should be very solid hubs. They replace 340 in DT lineup. As a Star Ratchet type hub, they have 18 POE stock and can be upgraded to 36 POE, but the latter is much more demanding with respect to correct greasing. The coasting mechanism is very modular and lightweight. Water sealing is excellent and AFAIK second to none (although this is speaking from experience with 240 and 340 hubs).
    Thanks J. Random Psycho. Is 18 POE a "good" number when it comes to POE?
  14. #214
    meow, meow.
    kevinboyer,
    well... that depends on whether you have already tasted high POE hubs )
    16-18 feels broken at first if you're used to, say, 48.
    Modern top of the line hubs have those numbers at like 72 and 120.
    Mid range hubs are at numbers like 24, 30 and 36.
    Personally I'm fine with 24 (Hammerschmidt to fixed hub) and can get used to 18 if needed.
    On another bike I'm just as fine with 48 (Hope Pro 2 Trials) but going to go back to instant engaging silent clutch (True Precision Poacher). Ahhh, the silence.
    DT Swiss Star Ratchet hubs are rather quiet at 18 POE, by the way. And you don't have to apply lots of grease to achieve it. That's very good in my book.
  15. #215
    Reputation: cackalacky's Avatar
    What width of WTB rim tape are you guys using for the i23? The 28 mm?
  16. #216
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by cackalacky View Post
    Yes, use the 28mm tape.
    mtbtires.com
  17. #217
    Mar 2005
    1" Gorilla Tape fits as well.
  18. #218
    Dec 1998
    Thick tape adversely affects the bead lock shape.
    mtbtires.com
  19. #219
    Lightly salted
    Reputation: fuenstock's Avatar
    Bringing back an old thread,
    Im looking to build a set of i23 rims on dt swiss 240 hubs to replace my tired Mavis sx wheel set. I have only built a handful of wheels and I'm having trouble deciding if I should go with dt swiss super comp or comp spokes? I'm 190lbs ready to ride. I want a light but strong wheel set for trail/am riding with drops to 4' with smooth landings. Nothing to aggressive and no bike park use. Will the comp spokes be noticeably more stiff than the super comp spokes at hard corners/hard pedaling?
  20. #220
    meow, meow.
    I'd go with super comps. A 32-spoke, 3-cross laced wheel (what i23 are designed for) is going to be stiff enough laterally and torsionally with any conceivable spokes, but with thinner spokes it will be stronger.
  21. #221
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    How is an i19 compared to the Arch? I'm talking about durability and feel. Is it easier to mount a tire on a wider or narrower inner rim width, 19 vs 21?
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
  22. #222
    Reputation: mestapho's Avatar
    I've had Arches then i23's and now FlowEX 650b's.
    I think they are all very equivalent in terms of durability, stiffness, and ease of build.
    The only trouble I had was with the Stan's rear hub.
    I haven't seen any difference in mounting tires on either of my Stan's vs the WTB hoops. All were very easy. I haven't ever had to use anything other than a floor pump to set up tires tubeless.
  23. #223
    Bicycle Addict
    Quote Originally Posted by mestapho View Post
    That's all I needed to hear. Thanks and a rep +
  24. #224
    Te mortuo heres tibi sim?
    Quote Originally Posted by J3SSEB View Post
    Pretty much what mestapho said.
    I've got a mix of Arch, Flow, and i19 rims in use on three different bikes - functionally, when getting them up and running tubeless, I've not been able to tell a difference. They've all been equally easy.
    Caveat: all with yellow tape, a cup of sealant, and either tubeless ready or full UST tires.
    I'm not a hack, ride fairly smoothly, am only 150# soaking wet, and have not been gentle with any of them - they're all working beautifully.
    If you're a much larger mammal, or ride like a bowling ball, then the wider rims may work out better, or if you want to run biiiig tires.
  25. #225
    Bicycle Addict
    Quote Originally Posted by scrublover View Post
    I am a bit larger fella, 220 lbs, and I currently use Archs without issue. I'm looking at the i19 because of its price. I can get it about $30 cheaper than the Arch. I was just concerned about the width of the rim. I may give them a try on my single speed. Thanks for the input scrublover.
  26. #226
    Poacher, Oaktown Honkie
    10 months on WTB i23 set up with db spokes on King hubs, Geax Gato Tubeless ready 28psi. Downieville runs, 1500 ft local downhill runs, and I ride 3 or 4 days per week. Rim rode 1/2 mile out on a flat tire once(on smooth dirt). These are GREAT. Took to wheelbuilder after 10 months, and they did not need to really true wheel. Justin just kinda inspected on truing stand, gave a few nipples a twist to make sure tension was there. Wrench Science built me great wheels. They use spoke tension gauge (as I am sure all professional wheelbuilders do), I am SO glad I did not try to build these myself.
  27. #227
    Bicycle Addict
    I just ordered a set from my LBS today. I'm pretty excited to ride them. They will be laced to a White Industries Eno Eccentric hub.
  28. #228
    Lightly salted
    I got my new i23 rims yesturday and built them up today on dt swiss 240 hubs using brass nipples and comp spokes. Very solid feel to them. These are replacing an old set of 2010 mavic sx wheels. I built myself flows on dt swiss 240's last year and the i23 rims feel noticably stronger. I removed the i23 stickers and weighted them at 453g and 452g for the 2 rims. That seems much lighter than the advertised 475g per rim? I have left over 25mm stans tape, will that be ok to use for the i23's? Wtb recommendeds 28mm tape, but would like to use the stans since I already have it. Will the 25mm tape work?
  29. #229
    Reputation: two-one's Avatar
    Quote Originally Posted by fuenstock View Post
    I'm pretty sure I sealed mine with a single layer of Stans 25mm tapes. Seems to work alright.
  30. #230
    Reputation: flyxaos's Avatar
    I'm doing that exact same build, with dt240 oversize in front, and dt240 in back.
    What spoke length did you use for all of them? Are you happy with that length?
  31. #231
    Lightly salted
    Quote Originally Posted by flyxaos View Post
    I used 259mm for front disk side and 260mm for the rest of the spokes. That was what I calculated using 537 erd and the dt swiss spoke calculator. Length was perfect. After the wheels were tensioned almost all the spoke threads came to the bottom of the nipple driver slot or whith in a thread. My hubs are dt swiss 240 12x142 rear and a 20mm thru axle OS 240 in the front. They were easier to build and true compared to the flows I built last year.
  32. #232
    Lightly salted
    Few pictures of the built up wheels with the stickers removed. Stickers came off clean very easy. Weight is without rim tape of valve stems.
    Wtb i23 rims
    dt swiss comp spokes
    dt swiss brass nipples silver
    dt swiss 240s OS 20mm front hub
    dt swiss 240s 12x142 rear hub
  33. #233
    Reputation: GTscoob's Avatar
    Wish they made this rim in a 36 model for the rear. I can normally get away with 32/32 but prefer 36 out back when possible.
  34. #234
    fuenstock, i also used 25 mm tape, cuz the lbs was out of 28 mm. So far no problems after 7 months.
    '14 rocky mountain altitude, rally edition
    '11 transition blindside, 650b converted
  35. #235
    Reputation: BoomerBrian's Avatar
    WTB Frequency i23 AM wheelset: alternative to Flow rims
    Found a good deal on the i23. These are am wheels and I only ride xc. I am 220lbs. Would these be overkill for xc and would I be happier with the i19?
  36. #236
    Moderator Moderator
    Quote Originally Posted by BoomerBrian View Post
    I've always kind of figured that race gear was too light for Clydes. Trail gear was effectively race gear for Clydes. And that AM gear amounts to Trail gear for Clydes.
    I'd go with the 23's. The wider bead set presents a nicer tread-print to the dirt and ends up being less flexy.
  37. #237
    Lightly salted
    The i19 is pretty narrow, I would only get those if I was planing of running 2.1 or smaller xc tires. The i23 would be better for 2.2 and larger tires. At your weight I would pick the i23 over i19 unless it was a race wheelset that had to be as light as possible.
  38. #238
    meow, meow.
    +1 for i23 over i19. You'll hardly notice the weight. I'd even run them with 2.0" if I was racing.
  39. #239
    Reputation: dirtdan's Avatar
    Another vote for going i23 over i19 unless they were going to be race specific with a 2.1 or smaller tire on them.
  40. #240
    Thanks for the input.
    Does this look like a good deal? Also how do you know if you could use 15mm thru axle? I am putting these on a Trek Cobia with the stock Recon shock.
    WTB Frequency I23 29er Tubeless Mountain Bike Wheelset SRAM x9 Hub 6 Bolt Disc | eBay
    WTB Frequency I23 29er Mountain Wheelset SRAM x9 15mm thru Axle Front Hub 6 Bolt | eBay
  41. #241
    The specs of the fork will dictate what type of axle/skewer setup you will need. I'm pretty sure the Recon on the Cobia is standard Quick Release which would make a 15mm thru axle not work. Most hubs are pretty easily converted though. I would bring bike to LBS and they'll help you or ask the people you're considering purchasing from the technical questions.
    Looking at the pictures of the hubs on the two ads on the ebay ads should give you your answer on what type of skewer/axle system you have. I'm guessing you have the the type in the first ad.
  42. #242
    Reputation: ianick's Avatar
    Laced up some King hubs, dt comp spokes and i23's yesterday. They feel pretty burly. Hoping to get a ride on them today.
    WTB Frequency i23 AM wheelset: alternative to Flow rims-dsc_0882.jpg
  43. #243
    Bicycle Addict
    I hope to get a ride on these soon. I am waiting for a new frame to put them on. They feel pretty solid and aren't as heavy as I thought.
    Attached Thumbnails Attached Thumbnails WTB Frequency i23 AM wheelset: alternative to Flow rims-imag0648.jpg
    WTB Frequency i23 AM wheelset: alternative to Flow rims-imag0650.jpg
  44. #244
    Ordered a set today. Can't wait to try them.
  45. #245
    Feb 2013
    Does anyone know maximum rider weight and maximum tire pressure for i19 and i23?
  46. #246
    Nov 2012
    Quote Originally Posted by sergey_1987 View Post
    I can't imagine a rim this burly having a max rider weight, it's going to be more about quality of the person doing the wheel build and perhaps using stronger spokes in lacing them up. Someone else mentioned that they don't make this rim in a 36 hole drilling so if your a superclyde, that isn't an option.
  47. #247
    Feb 2013
    Thank you. So, front wheel (on suspension fork) laced on i19, DT revolution spokes and Syncros hub will be ok for non-agressive riding (city and light XC without drops) for a 200lbs person? Also if I set 622*32 tire at 70psi wouldn't I damage the i19 rim?
  48. #248
    Nov 2012
    Why would you want to run that much pressure? I'm 250lbs and even when I'm riding out on the streets I only take it up to about 45-50psi max?
    At 200lbs you can ride on pretty much any mtb rim you want for the riding style you mention, just dont try to ride anything with too low of spoke count.
  49. #249
    Feb 2013
    Quote Originally Posted by cpfitness View Post
    I was wondering if the rim is going to explode under 70psi pressure. I pump that because I use narrow semi-slick (Nokian Ravagozzi Cross S 622*30) with 65-90psi recommended inflation perssure. For XC I use Maxxis Aspen 29*2.25 at 30-50psi.
  50. #250
    Nov 2012
    Re: WTB Frequency i23 AM wheelset: alternative to Flow rims
    Gotcha. Im pretty confident you will be fine as you have to remember that mtb wheels dont have a braketrack that is getting worn down that can become a weak point
    Sent from my DROID RAZR using Tapatalk 2
  1. Why do I have to run more psi with Flow rims?
    By gticlay in forum Santa Cruz
    Last Post: 08-26-2011, 12:58 PM
  2. Stan's Flow rims vs. DT Swiss 5.1 rims
    By qbert2000 in forum Wheels and Tires
    Last Post: 04-13-2011, 12:16 PM
  3. What's a good alternative to a Stan's Flow?
    By bsdc in forum 29er Bikes
    Last Post: 03-25-2010, 01:51 PM
  4. Flow Rims - What's the best set-up
    By loamranger in forum All Mountain
    Last Post: 02-16-2010, 08:20 AM
  5. racing wheelset for 29er: king w/Flow or I9 w/Flow?
    By massalsa in forum Wheels and Tires
    Last Post: 04-08-2009, 05:31 AM
Members who have read this thread: 10
