Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 501 to 550 of 629
  1. #501
    Chris Bling
    Reputation: dustyduke22's Avatar
    Its pretty weird that some folks have nothing but good to say about the i23s and others think that they are garbage. I would love to try some, but not sure what way to trust right now...
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  2. #502
    Jun 2013
    I have been riding with mine for a few weeks so far and I have no complaints. They are holding up great (I know short period of time) but I would recommend especially for the price.
    Quote Originally Posted by dustyduke22 View Post
  3. #503
    WTB Frequency i23 AM wheelset: alternative to Flow rims
    I have been riding 2 wheelsets built by 4Slomo with i23 rims for quite a while with a variety of tires set up tubeless with Stan's, and I have been real impressed.
    My first set was probably one of the first with commercially-available i23 rims (7000 alloy) and the second set was among the first with the new alloy (WT69). I have ridden these wheels hard on a wide variety of surfaces/conditions. I have bottomed out on rocks, slid sideways, crashed, come to abrupt stops up against trees/rocks, etc. And I am no weight weenie. I weight 200 lbs before clothes/water/gear, and tend to carry way more stuff than I need.
    Anyways, the rims on both wheelsets still look like new, and they are still true as arrows. 4Slomo built them with DB spokes, brass nipples and CK hubs (1 geared and 1 SS).
    I have inflated tires tubeless with a floor pump and with a compressor. Best approach all-round seems to be: inflate the tire with a tube, ride it or let it set a day, then pull the tube and go with liquid. I have run Geax, WTB, Specialized and Bontrager tires in this fashion without problems.
    Just a quick review of my experience over the last couple years, since it appears there are others with different results.
  4. #504
    Chris Bling
    That is good to know. Are all of your tires designated 'tubeless tires', or are you running non-ust as well?
  5. #505
    All now are some variant of "tubeless ready", i.e., TNT for Geax, TCS for WTB, etc. I am no tire expert, but I think this means UST bead and some form of non-UST casing.
    I ran some non-tubeless ready/non-UST tires with Stan's and no tubes for a period of time. But the results were too unpredictable. Not worth it for me, especially considering how reliable and fool-proof my current combination is -- i23 (UST) rims. Stan's liquid and tubeless ready tires.
  6. #506
    Reputation: 4slomo's Avatar
    A classic i23 wheel set hits the trail
    Don came to me not too long ago to build him a set of wheels for his birthday, a present to himself. He settled on 26er Frequency i23 black 32h rims, brass silver nipples, silver WS DB14 double butted spokes, and Hadley XC/SDH QR 32h silver hubs. Rotating weight 1,882g. They built up laterally and radially very true and have somewhat of an old school look to them, with the black and silver matching his frame colors. One thing about the silver finishes is that it is quite durable, his wheels are going to look great for a long time.
Size:  86.8 KBName:  20131107_WTBFreqi23_WSDB14_HadleySDH_rear_mtbr_P1050460.jpg
    His initial riding impressions: "I have about 20miles on the wheels so far and they are fantastic (they are mounted on my hard tail) I've taken it down through El Prieto 3X now and the wheels are solid and smooth!"
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  7. #507
    Bike packing, gravel grinding, internal gearing, weight carrying
    About two weeks ago I completed a custom rear wheel build for Eugenemtbing. He bike packs and also rides gravel roads, among many other XC & AM rides. For bike packing he uses a tubeless 2.4" wide UST tire, and needs to mount a cyclocross 35C tire on the wheel when swapping it for gravel grinding on another bike. So the requirements are for a quite versatile wheel. The rim selection was a WTB Frequency i23 29er rim to meet the tire requirements. Due to the bike packing weight carrying requirements, the spokes are Sapim Strong single butted spokes laced x3. For simplicity, and to minimize effects of errant sticks, he selected a Shimano Alfine 8 speed hub. Here's a photo:
    Rotating weight (due to the hub): 2,496g!
  8. #508
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Why Sapim Strong and not Sapim Force (or DT Alpine 3)?
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  9. #509
    It turns out that there are two overriding design requirements for this wheel build:
    The hub flange spoke hole diameters are about 2.9 mm. I'm willing to put a 2.0 mm j-bend in up to a 2.5-2.6 mm diameter flange spoke hole. That limits spoke choices to j-bends with a minimum 2.3 mm diameter (the Sapim Force has a 2.18 mm diameter at the j-bend).
    Secondly, the wheel build design is for a load of about 300 pounds (including rider, bike and bikepacking equipment). A 1.8 mm butted section does not give adequate durability and performance for this weight. That drops out the DT Swiss Alpine III.
    Quote Originally Posted by J. Random Psycho View Post
  10. #510
    meow, meow.
    Oh, 2.9 mm is a bit too much indeed. I once had to build a 26" wheel with a huge and heavy 3 kW motor hub and 2.0 mm spokes. The hub had 3.9 mm (no typo, three point nine) holes; I used stacks of different sized brass washers. For all I know the wheel served fine (which I attribute to the beefy rim), but it certainly was not pleasant to build.
    But as for the load, do we ever get so much dynamically added tension on a spoke that the sum exceeds static tension by more than several percent? I haven't seen spokes, even 1.5 mm in diameter (or those rolled flat from 1.5 mm round spoke), exceeding their yield strength in any riding situation, including rims being destroyed by radially directed shock. (Unless of course the spokes were compromised during build by twisting too much, or a foreign object such as a rock or horse hoof hit them -- that I saw happen, and I can say that no wheel is horseproof!) What I think we should worry about with excess load is the possible momentary loss of spoke tension near contact patch. This is where fat J-bends and threadlocking come into play.
  11. #511
    Got my Alfine 8/WTB i23 29er wheel from Steve. It is a beauty. I am not surprised, as Steve/4slomo has built other fantastic wheels for me.
    I am still collecting the Alfine bits I need to make this conversion on my 29er bikepacker. I was impressed, though, with the care Steve put into building this wheel -- and even the way he packaged it for shipping. Everything orderly and well protected. And he knew it was for bikepacking, so he included extra spokes -- drive-side and non-drive-side spokes carefully labeled.
  12. #512
    Mounted a Geax Saguaro TNT to the rim last night. These i23 rims are so great. A little soapy water, some Stan's liquid, a few pushes on the floor pump, and it's done.
  13. #513
    Feb 2006
    Quote Originally Posted by 4slomo View Post
    Can I post my builds /advertise here also?
  14. #514
    Mar 2013
    If they're frequencies of course you can Fred. I've been riding my i25 9rs for a couple of months and very pleased with the performance. XT 785 and 788 hubs they built up nicely.
  15. #515
    Reputation: George Gr's Avatar
    Hi guys,
    I've just seen the thread below WTB Frequency i23 rim cracks???? regarding fails on the i23's and I was wondering if any of you had the same problem.
    Is it just on the old rims with the 7000 alloy or there's a problem with the WT69 series alloy?
    "Do not go where the path may lead. Go instead where there is no path and leave a trail" Ralph Waldo Emerson
  16. #516
    Slower But Faster
    Reputation: BrentD's Avatar
    Quote Originally Posted by George Gr View Post
    Hi guys,
    The 7000 alloy was problematic, the WT69 is all good.
  17. #517
    meow, meow.
    No cracking issues reported so far on any i19s and i23s that I built with over these years (with both alloys). I keep max tensions within 1200 N. As for rider weights that I remember, well.. no one is over 100 kg.
  18. #518
    Thanks a mil guys.
    I'll go for it then!
  19. #519
    Mar 2012
    I hammered a set of 29er I23s and now the 27.5s. Really like them. I killed a rear and a front last year, but not too suprising. They lasted a lot longer than they should have. Aside from 1 small ding in the 27.5 rear, they're doing even better. I've blown a bead twice, both times running a Specialized Butcher Control. That tire mounts really, really easily and I no longer use them. Never had a problem with Maxxis. All mount up pretty easily.
  20. #520
    Quote Originally Posted by jselwyn View Post
    TR or not?
  21. #521
    Mar 2012
    TR or not?
    Both. Run Ikon on the rear in 2.35 Exo NON-TR just fine in some pretty rough terrain. Try and use TR/Exo, but I wouldn't worry about it if you found a good deal.
  22. #522
    Chris Bling
    I tried to mount a non TR EXO Maxxis Ardent 2.4 on a i23 wheelset with a tube to see if it would hold and it blew off the rim at about 35psi. Scared the $#!* out of me and left my ears ringing.
    Every TR or UST tire I have installed on the i23's, KOM's or i25's went on with minimal effort and seated the bead with a floor pump.
  23. #523
    Dec 2005
    Frequency i25s are sick!!!!
    Hey guys I finally pulled the trigger on i25s and laced em up on my i9 wheels and they are sick. I've been chiming in on tire choice and coming from the original flow rims w non tubeless tires tape but had to use Stans rubber rim strips too. But now the i25s w gorilla tape only and Bontrager xr4 team 2.35 non tubeless work perfect!!! Saved weight w/o strips and tape is super cheap. Loving these wheels. Trying the front in dirt today for the first time.Attachment 893051
  24. #524
    endorphin addict
    +1 on the i25's mated with Bonty XR4 tires and gorilla tape. I had an issue on the rear getting a good seal with the WTB tubeless tape and decided to try gorilla instead -- cheaper and better!
  25. #525
    Dec 2005
    Thanks for the concurrence. I couldn't find the 30mm wide wtb or stans tape locally so I said Gorilla to the rescue. It may be a little heavier than yellow tape but thicker w adhesive should allow for better tire to rim mismatch of any combo. I feels super light still so I'm happy. The rims also seem very stiff compared to the Flow's I had, and I am already running the Industry 9 aluminum spoked wheels that are very stiff already. That I-beam design is good stuff! The has become more stable and less peaky, it still has a very round profile for my preferred riding style. It seems the narrower rim made the tire feel more like I was riding on a knife edge of sorts. Now I can't wait to throw the front through some turns. The ride with jus the rear new made me really notice the difference in profile.
  26. #526
    Dec 2005
    Oh and I use the Bontrager sealant now instead of stans. I like it and it should last longer since its synthetic latex I believe.
  27. #527
    Wheel spec on my TBLTc 29er
    Front Hub DT 350
    Rear Hub DT 350
    Rims WTB Frequency Team i23 TCS
    Spokes DT 14/15 spokes, alloy nipples
    Anyone have an idea on what these weigh?
  28. #528
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by smilinsteve View Post
    Front HubDT 350
    Rear HubDT 350
    RimsWTB Frequency Team i23 TCS
    SpokesDT 14/15 spokes, alloy nipples
    1,850g
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  29. #529
    Quote Originally Posted by meltingfeather View Post
    1,850g
    Hmmm, not bad. Thanks bro!
  30. #530
    Mar 2005
    Front Hub DT 350
    Rear Hub DT 350
    FWIW I have the same bike (2014) and same wheels. On my scale the wheels measure 1950g (wheels only; no rotors/bolts or cassette)
  31. #531
    Reputation: Reelchef67's Avatar
    Ok wake up thread!
    Wondering how these wheel sets have faired over time.?
    I myself have been riding wtb i23 wt69 versions 26rear/650b front for a couple months now.
    Mine are laced to hope pro2 evo hubs with 32 dbl dt swiss comp spokes.
    So far I am very impressed they are very stiff wheels. So much easier to control in chunky chunkier.
    I stripped the stickers off mine. Going for a "murdered out" red black theme on my buildnot original I know...
    " I don't ride park"
  32. #532
    Master of the Universe!
    Ive been riding on the older 7000 series i23's and the rear finally had a spoke pull through the rim. Hopefully my shop and WTB can work something out.
    Can't a guy get bombed and call his ex at 3 in the morning without it meaning something?!
  33. #533
    meow, meow.
    Finally I've gotten around to build a wheelset with Frequency i25 Team rims. Measured ERD is 537 mm as claimed, like i23, so it's not a uniformly scaled up i23 profile. Weights are 478 and 497 g, which is rather big difference compared to ZTR rims. Anodizing quality is notably better than all i23 instances which I handled. Overall, I'd say i25 may be regarded as drop-in replacement for i23, that is with those weights I no longer see where i23 would suit better than i25. Maybe even to the point where i25 becomes *the* MTB rim of choice, unless one wants something specifically different.
  34. #534
    Reputation: Burt4x4's Avatar
    Feb 2013
    I am looking forward to riding on my i25 29" wheels..just a few more weeks and I should be rollin again. REad aftrer read it stays positive with the Frequency I-beam
    Should be sweet!
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
  35. #535
    Oct 2013
    Quote Originally Posted by djr8505 View Post
    I can say from personal experience WTB at least in my case has some of the best customer service Ive ever seen!
  36. #536
    J:
    J: is offline
    Fun with dirt
    Reputation: J:'s Avatar
    Dec 2009
    Been on the i25 since it came out and agree, 4$ at this point in time, never tried the i23 but have tried the first Flow.. If the next i25 bead profile is the same, and even spoke tension can be improved, the i25 is "*the* mtb rim of choice, unless one wants something specifically different"
  37. #537
    Reputation: Nubster's Avatar
    What's a good price on the i25 rims? I can get them for $50 shipped each. I'm thinking about building up a new set of wheels for my Cannondale that's currently rolling on i19's (stock). I'd like something wider and better hubs.
    Cannondale F29 carbon
    Jamis Renegade Elite
    Kona Big Unit SS/full rigid
    Kona Private Jake SSCX (build in progress)
  38. #538
    Feb 2013
    FIFTY bucks? oh are you talking about 26"?
    29" is $70 everywere...give or take a few bucks.
    I talked my wife into using her Amazon acount to buy mine LOL
  39. #539
    Nope. 29er. $44 per rim plus $12 shipping for one or two rims. So two rims comes to $100 shipped. So I'll take it that's a good deal...lol...I'll probably order them up tomorrow when I get my pay check in the bank. I'll just have to save a while for the hubs.
  40. #540
    Where are you getting this price?
    Quote Originally Posted by Nubster View Post
  41. #541
    meow, meow.
    I've been brought a pair of CRC-bought i23 (WT69) labeled rims recently for wheelset build. One of them was an actual i23, another, much to my surprise, turned out to be an i25. Customer didn't notice this so I told them.
    Anodizing quality is good on both.
  42. #542
    Apr 2013
    Interested in getting some 650b i23 or i25 wheels built with hope pro 2 evo hubs. Which is better i23 or i25 these would be going on a 6 in travel AM rig. He hubs I can get come in 32 and 36 hole, which is preferred? Finally what kind of spokes are recommend.
    I can can get the rims 50% off cause I work in the industry. So I figure that's going to save me a little cash.
  43. #543
    Quote Originally Posted by Strife21 View Post
    This week, i25 is better. Next week, i25 will be old news and you will have to sell them.
  44. #544
    meow, meow.
    Well, he doesn't have either ) so I'd go with i25.
  45. #545
    Depends on tires, I'd think... flimsy sidewalls? Probably i25. i23 is what I'd choose. I like the lesser rotational weight and i25 is kinda overkill unless you want the stronger rim for downhilling/freeride. Heck, I'd even consider dropping down to i21 if they offered it in similar strength. The rim width game is kinda silly imo, unless running thin walled tires. Lower pressures due to higher volume? Can't do that without ripping a tire off the rim, so no benefit to me. Plus I like Minion DHFs, which have a great profile on 23mm rims.
  46. #546
    Quote Originally Posted by Lindahl View Post
    Wait... you like the lower rotational weight of the 23s, which are "overkill unless you want the stronger rim for downhilling" so you can pair them with 2-1/2 pound, 2-ply downhill tires?!? Makes sense...
  47. #547
    For my non-DH/FR wheelset, I use single ply versions of DHFs (Exos). The flimsy sidewall tires I refer to are specificly single ply lightweight-design tires (usually, but not always, XC-oriented tires). Not all single ply tires have the same sidewall integrity.
  48. #548
    Aug 2014
    Just finished building my wheelset. Will test it on the trails this weekend..
    WTB Frequency i23 AM wheelset: alternative to Flow rims-image.jpg
  49. #549
    Quote Originally Posted by Reelchef67 View Post
    Ok wake up thread!
    I have had a set of these running since early 2013, IIRC. I bent one beyond repair when I hit tree washing out on a turn, but that MIGHT be rider error. I relaced it up to another i23 and beat the piss out it since.
    Both are still rock solid. For the $60 I paid for the rims, they are a great deal.
    Lead by my Lefty............... right down the trail, no brakes.
  50. #550
    I just have counterfeit WTB Ixx stickers made so I look like up to date and hip going down the trail at 25 mph.
  1. Why do I have to run more psi with Flow rims?
    By gticlay in forum Santa Cruz
    Last Post: 08-26-2011, 01:58 PM
  2. Stan's Flow rims vs. DT Swiss 5.1 rims
    By qbert2000 in forum Wheels and Tires
    Last Post: 04-13-2011, 01:16 PM
  3. What's a good alternative to a Stan's Flow?
    By bsdc in forum 29er Bikes
    Last Post: 03-25-2010, 02:51 PM
  4. Flow Rims - What's the best set-up
    By loamranger in forum All Mountain
    Last Post: 02-16-2010, 08:20 AM
  5. racing wheelset for 29er: king w/Flow or I9 w/Flow?
    By massalsa in forum Wheels and Tires
    Last Post: 04-08-2009, 06:31 AM
