Go Back   Mtbr Forums > Classic Mountain Bike Forums > Wheels and Tires
Reply
LinkBack Thread Tools Display Modes
Old 01-14-2012   #1
offroader
Rep: CupOfJava will become famous soon enough
user gallery
WTB Frequency i19 29 wheel build review
I recently got a hold of a pair of WTB frequency i19 rims and thought I'd share my experiencebuilding these wheels. I started off with a set of wtb laserdisc hubs, wheelsmith db14 spokes and the rims.
First a little bit of background. I've built about 20 or so sets of wheels in the past plus some wheel maintenence for friends. My main rim of choice is stans flow but I have built velocity and mavic rims in the past.
First impression: The rims are well machined and the welds are seamless. The quality of the alloy used seems stiff and durable (unlike the velocity p35 rims which were soft and scratched easily) The finish was camparable to Mavic (which IMO has the best finish of any rim I've used). The eyelets in particular were nicely finished as seen from the inside. They are directional so I played around with the spoke and nipple to be sure I was lacing them correctly.
At 434g the rims are slightly heavier than Stans Crest but comparable to the Arch. They felt beefy but not heavy and the bead hook was noticeably longer than the Crests which felt thin walled and the bead hooks short. There is no doubt in my mind these rims were solid.
Building: these rims are probably one of the easiest to work with. In particular the nipples seated on the first twist as if the were on an eyelitted rim even though the rims are not eyelited. So my colored nipple did not get caught inside the rim by the eylets and didn't get scratched like they usually do with Stans rims. The nipples also seem to turn easier either due to the smooth finish of the rim eyelets or the directional eyelet or a combination of both. All in all they were a dream to work with.
Conclusion: I have yet to ride the wheels but I plan to soon. The weight of my set should be in the range of 1600g for both font and rear. I haven't weighed them however. More to come....
CupOfJava is offline   Reply With Quote
Old 01-15-2012   #2
offroader
user gallery
Rode the wheels today. They are fricken awesome. Stiff and light and they look tight on my bike. My next set of rim are going to be the i23 for sure. Tuebless was as easy as stans and the bead locked on. As much as I love the flows if the i23 are as capable as these rims I think I may not go back to stans.
Some after ride shots:
Old 01-16-2012   #3
macming's Avatar
Rep: macming will become famous soon enough
user gallery
The i23 look really interesting. Considering the ERD is 537, when I need a replacement for my DT 5.1d (540mm ERD), I may look for a i23
macming is offline   Reply With Quote
Old 01-17-2012   #4
A1an's Avatar
Rep: A1an will become famous soon enough
user gallery
I have about six hours on my i23 rims and love them so far. Couldn't compare them to Flows since I have never owned those but they are a night and day difference over the crappy Alex rims I had on this bike previously. They also air up much faster than my Bontrager Rhythms with the TLR strips (and those are super easy to setup tubeless).
__________________
2008 Redline Monocog 29er
2012 Trek Superfly AL Elite (replacement for Gary Fissure Paragon)
A1an is offline   Reply With Quote
Old 01-17-2012   #5
macming's Avatar
user gallery
Very interesting. So the i23s are 23mm wide internally, and can go tubeless with just some yellow tape?
Old 01-17-2012   #6
offroader
user gallery
Yep, I used Stans yellow tape and Stans valves. They worked flawlessly. What I particularly like about the rims is the 4d drilling used for the eyelets. The biggest gripe have have with the Flows were that the eyelets straight drilled causing the top of the nipples to get caught inside the rim causing them get get scratched on the way out. It also looks like the directional drilling will help in keep the wheels true longer and contribute to lateral stiffness (I'm only guessing here), but time will tell. I can't emphasize how much I liked the finish of the rims. On a scale of 1-10 I rate the Flows a 10 and these a 10.5.
Old 01-17-2012   #7
A1an's Avatar
user gallery
Yes. I used the 25mm yellow tape and Stans valves. The bead popped into place at about the 15-20psi mark using a floor pump with the i23 (2.4 Purgatory up front and 2.3 Bontrager 29-3 in the rear).
__________________
Old 01-19-2012   #8
jadedbee's Avatar
Rep: jadedbee is on a distinguished road
user gallery
I'm very interested in using the i23s for my next build to replace my Arch/Flow combo. Can someone clear up the marketing speak for me: Will a non-UST beaded tire (or tire not marketed as "Tubeless Ready") seal up as easily on these as on a Stan's bead socket?
I prefer Maxxis and Panaracer non-UST tires which mount up great on Stan's. It seems like WTB is trying to push their heavy, UST-beaded tubeless ready tires to be used with their 'system'. I know other tire makers have their tubeless-ready branded tires now (basically a UST bead without the stiffer sidewall and airtight casing?); Specialized and Kenda come to mind. Although in Kenda's case, the non-tubeless ready versions wouldn't stay sealed even on Stan's due to the braided bead. But it looks like the OP'er has Slant Sixes on the Frequencies; are they the 'tubeless-ready' version?
Also, you mentioned these rims are not as soft as Velocity rims; are they harder than Stan's? I'm asking because I get a lot of flat spots with my hardtail, even with my new Flow build.
__________________
Rollin' rocks will never die...
jadedbee is offline   Reply With Quote
Old 01-19-2012   #9
Former Bike Wrench
mtnbiker72's Avatar
Rep: mtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud ofmtnbiker72 has much to be proud of
user gallery
My experience with UST spec rims (Mavic in my case) is that non-tubeless tires do not mount up well with them. I tried several different brands of tires on my Mavic UST wheels and they all were a pain to mount even with a compressor and burped easily. I've honestly had better luck with "ghetto" setups on regular tires than with UST rims (although still a hit or miss scenario). The WTB TCS system is made to UST specs so I would expect the same. Not sure why you think they are trying to push "their system"...UST is actually Mavic's system. As you mentioned, there are other manufacturers of Tubeless Ready tires if the WTB tires are not to your liking.
The TCS rims are made with 7000 series alloy which is going to be "harder" than the 6000 series used by many other rims manufacturers (including Stans).
__________________
Rollin With No Colon!
The Bike Whisperer
Crohn's and Colitis Foundation of America
mtnbiker72 is online now   Reply With Quote
Old 01-20-2012   #10
Rep: kdiddy is on a distinguished road
user gallery
I've tried mounting a TCS 29er tire to a Bontrager TLR Duster rim with no luck - the tire was too tight to get the second bead on. WTB checked the tire on one of their rims and it worked fine. On a different note, I've mounted 26" TCS tire on Bontrager TLR rims with no problem.
kdiddy is offline   Reply With Quote
Old 01-20-2012   #11
offroader
user gallery
Not sure if they're harder, but I would say they definitely don't feel softer. They don't have that hollow high pitched "ting" sound that the Velocity's had. The Slant Six are regular tires not TL or UST. They sealed up just fine. I tried to mount my Small Block 8 on the rims but they were hard to get on, but I can't really blame the rims because I had the same issues mounting my SB8 on my Flows as well. I'm fairly confident these rims could mount just about any recent tire I throw at it. My SB8 were kind of old and had been run tubed for a while.
Old 01-20-2012   #12
MTB B'dos
LyNx's Avatar
Rep: LyNx is a splendid one to beholdLyNx is a splendid one to beholdLyNx is a splendid one to beholdLyNx is a splendid one to beholdLyNx is a splendid one to beholdLyNx is a splendid one to behold
user gallery
Hey COJ, thanks very much for the write up, hadn't heard of these before, but they sound like a good alternative to the Stans rims. What price did you pay for them? Right now though I'm really wanting my next set of wheels to be wider than the Flows I currently have to mainly use on the Rigid and HT to help widen the footprint and let me use lower pressures to help with some cush. Have to think that the directional drilling of the spoke holes will make seating and building much easier. Oh how much tension did you build them to?
__________________
I work to live, and live to Ride.
LyNx is offline   Reply With Quote
Old 01-20-2012   #13
jadedbee's Avatar
user gallery
The TCS system push was more of an impression I got from a WTB rep I spoke with. They were positioning it as an alternative to the UST system, since just the bead-hook was UST spec; you have to use a sealed rim tape and sealant which you don't with UST. Using a tire with just the UST bead is an advantage because of reduced weight and cost along with a more supple casing versus a UST tire. But not being a big fan of WTB, Kenda or Specialized tires (in 29"), who seem to making non-UST tires with UST beads, I wasn't sure if these rims would work for me. Guess we'll have to see what people's experiences are mounting up other brands.
This is definitely another plus in WTB's favor to get me to switch.
__________________
Old 02-19-2012   #14
Crushin' Grapes
racinjasonmoe's Avatar
Rep: racinjasonmoe is on a distinguished road
user gallery
Note that WTB makes rim tape in specific widths for their TCS rims. 19mm inner width rims use 24mm tape. 23mm rims use 28mm tape. The simple rule is to add 5mm to the inner rim width to determine the best tape width.
Also note that the purpose of using a UST bead on a light weight casing is to ELIMINATE the need to use tube type tires tubeless. Tube type tires are for just as the name says: to be used with tubes, and tubes only. Tubeless use of a tube type tire will generally result in a poor tubeless experience. Ask any tire manufacturer if you should use their tube type tires in a tubeless application. The answer will always be the same.
The simple tubeless rule, lightweight, or otherwise: UST tire bead + UST compliant rim equals consistent tire/rim fit, all the time, even when mixing brands. Anything outside of the UST fit world is questionable at best.
racinjasonmoe is offline   Reply With Quote
Old 02-19-2012   #15
jadedbee's Avatar
user gallery
Wow, I guess you've had bad experiences running non-UST tubeless tires. Just like a lot of people, I suppose.
Maybe I've just been lucky: I've had no seal problems whatsoever in 3 years running non-UST Maxxis and Panaracer tires on my Stan's Arch and Flow rims. The fact that I really like these tread patterns on the trails I ride, coupled with the fact that they aren't available in a "TL ready" version, makes me less likely to fix it when it ain't broke. But as I described above, I do have some concerns about the durability of the Stan's rims, which makes me curious to try others.
You mentioned that the tape on the WTB rims is 5mm wider than the inner width; is this standard for UST bead designs? I was told to trim away any of the tape that wandered into the bead hook on my Stan's rims because it could interfere with seating the tire. And I would think the same would be true on a UST bead hook, especially given the specific dimensions it is suppose to be built to.
__________________
Old 02-19-2012   #16
Poacher
Rep: hoolie will become famous soon enoughhoolie will become famous soon enough
user gallery
According to WTB website, I-beam construction includes extra wall inside rim, running from tire bed to spoke bed. This would seem super strong to me. Stan's rim is hollow. I am not cutting a rim to verify.
hoolie is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Thread Thread Starter Forum Replies Last Post
My 2012 Karate Monkey Build - rigid, SS thomasbien Surly 27 04-16-2012 02:44 AM
Flow vs Arch vs WTB Frequency - Hadley vs DT 340 for AM roxtar Wheels and Tires 8 01-11-2012 12:37 AM
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
