Results 1 to 8 of 8
    would this be an upgrade?
    currently running mavic crossmax st (2008) that came with my bike. would going to hope 2 with arch hoops be considered an upgrade?
    Apr 2005
    Maybe by some. I'd think of it as a downgrade (losing UST). Hope hubs are nice, but not amazing. The rim won't be as good, but you will lose the proprietary spokes (has that been a problem for you?). Maybe it's a step sideways.
    thanks epic! i've been saving for some new wheels and a set came up for a decent price. just wanted to know if i should pull the trigger or not. looks like i'll continue saving my pennies.
    The hope hubs are worlds better than mavics hubs. They're some of the best, if you dont consider their low engagement.
    Reputation: Bike Whisperer's Avatar
    Quote Originally Posted by One Pivot View Post
    This^^^^...plus the 2008 Crossmax ST uses the older FTS-X two pawl system so the Hope actually has a higher engagement then the OP's current system.
    The Arch will work fine with Tubeless Ready and UST tires with sealant, which most people run anyway on UST.
    cool. thanks for the info guys. the wheelset is going for $275 right now. should i pull the trig? and what is the current engagement on my crossmax?
    Quote Originally Posted by blindman22 View Post
    It's either 16 or 18...I can't remember but it is only two pawl and there are only two bearings in the Mavic hub (the freehub body actually rotates on a bushing). The Hope hubs use five bearings in the rear hub and is four pawl engagement with 24 points...very solid.
    Thanks bw
    Sent from my MB870 using Xparent Blue Tapatalk 2
