02-23-2012
#1
Rep Power: 9 Rep:
user gallery
Worthwhile upgrade to carbon rims with I9 hubs?
I found out that light-bicycles.com is make new 26" rims that is 30mm externally wide and 23mm internally wide for relatively cheap. The rims are UST compatible as well, which is a huge bonus. The only issue is that these rims are targeted to be around 470 – 490 grams. I currently have DT Swiss 5.1Ds on my I9 wheelset, I will be able to re use my existing spokes due to the similiarity in ERD (537mm on the carbon rims, and 539mm on the DTs).
The weight savings will be very minimal, but I bet the new wheels will be a bit stiffer. I’m pondering whether the upgrade is worth it. What are your thoughts?
02-23-2012
#2
transmitter~receiver
Where did you hear that the light-bicycle rims are UST?
No offense, but how can anyone tell you whether or not a handful of grams and a "bit" of stiffness is worth $350 to you?
__________________
Originally Posted by pvd
Time to stop believing the hype and start doing some science.
29er Tire Weight Spreadsheet
02-23-2012
#3
Rep Power: 9 Rep:
user gallery
The company is making that claim:
The weight will be around 470g to 490g.
Yes, it is UST compatible, and the internal width is 23mm.
We use MES shipping, the delivery cost will be at USD70 to USD78 by EMS for 4pcs rims.
Thanks,
Nancy
I think I'll wait for them to reduce the weight a bit. The 29" version with the same width is ending up around 400 grams. If I can save 200 grams from my wheelset, I say it's worth the $$
02-23-2012
#4
Rep Power: 12 Rep:
user gallery
For $75 per rim, you can buy WTB Frequency I23 rims which are 23 mm inside, weigh 475 grams and are UST rims. Why spend $550 more?
__________________
The best thing I can say about my ex-wife is I no longer fear going to hell.
02-23-2012
#5
The carbon rims will be stiffer and stronger.
huh? the carbon rims are $350 total, shipped to your door... for TWO.
__________________
02-23-2012
#6
Rep Power: 3 Rep:
user gallery
I was told 370-380g for the wider 26er per Nancy. The narrow 26er is 330-350g.
__________________
Current Ride:
Ibis Mojo SL-R - Medium - South Beach White
'11 Specialized Roubaix Compact Rival
02-23-2012
#7
Rep Power: 9 Rep:
user gallery
Here is my conversation with Nancy. I expected 370 - 390 as well myself.
Hello Yang,
Thanks,
Nancy
Ming Yang
10:11 AM (5 hours ago)
to Nancy
Oh, the weight seems a bit high to me. The 29" version is currently around 400 grams. Are you sure they will be around 470 - 490 grams? 370 - 390 sounds more reasonable to me.
If the weight is really around 400 grams, put me down for 4 rims!
Nancy Yu sales@light-bicycle.com
10:13 AM (5 hours ago)
to me
Hello Yang,
The first rims will be heaiver, when the production line make more rims, the engineers will try to make the weight as light as possible.
02-23-2012
#8
Rep Power: 9 Rep:
user gallery
The WTB and the Flow are at the top of my list for replacement rims. I don't know if it'd be worth the effort/cost to swap out my perfectly good rim for an alloy model.
02-23-2012
#9
Rep Power: 3 Rep:
user gallery
Hmm..this is exactly what Nancy told me.
"Hello sir,
The current 26er rim(24mm wide) is about 350g, so the wider one will be around 370g to 380g.
Thanks,
Nancy"
__________________
Current Ride:
02-23-2012
#10
Rep Power: 12 Rep:
user gallery
Thought it was each. At 370 grams, that makes for a better value. 200 grams savings for $200 is right where the weight weenies aim, and loosing it in rotating weight makes it feel like more.
__________________
02-23-2012
#11
Rep Power: 9 Rep:
user gallery
That really depends on the cabon make up. Carbon has way more versatility to be made whatever way the engineer wants. If they go cheapo on the resin and type, the carbon rim could be more flexy than a good Al at 1/4 the price.
Just because it says carbon, doesn't mean it will be like the DT Swiss or Enve carbon rims out there now
__________________
Look for the C.A.R.B. charge on your PG&E bill soon since Prop 23 went down. 2 jobs lost for 1 green job created.
02-23-2012
#12
Nice theory, but they are stiffer, which makes them build stronger wheels due to improved load sharing/distribution between spokes.
__________________
02-25-2012
#13
Rep Power: 9 Rep:
user gallery
Good news! Nancy confirmed that 480 grams is a typo. The target weight is indeed 380 grams.
Originally Posted by nancy
Hello Ming,
The target weight is 380g, but the first rims will be heavier, and our prodcution line will try to make them light after doing some testing samples.
Thanks,
Nancy
02-25-2012
#14
Rep Power: 9 Rep:
user gallery
Well in this case, I'd lose over 1/2 a lb in my rims, and gaining 3mm of internal width at the same time. The added stiffness is icing on the cake. For $130 per rim, plus $60 for shipping, that's pretty reasonable IMO.
I agree there should be reservations, but people have reported good feedback on Chinese carbon rims from selected manufacturers including light-bikes. I figured it can't hurt to give it a shot.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
