Results 1 to 5 of 5
    (he thinks he can)
    will my qr rear drop out fit a 15mm thru axle?
    I want to build a SS wheel with the White Industries eric eccentric SS hub. I was going to lance it onto a notubes alpine rim. I was wondering if their was a compatibility problem with the QR drop out that on my C'dale F4 and the 15mm through axle it needs. Is their any adapter kit or anything to get around this?
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    ..and they place nice together!
    Former Bike Wrench
    The Axle bolts are 10mm, they will fit your F4 dropouts fine
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by krismac
    The White Industries ENO hub does not use a 15mm through axle. It is a bolt-on axle for use in standard rear 10mm open dropouts.
    mtbtires.com
    (he thinks he can)
    maybe the fact pricepoint.com has them listed as a 15mm axle threw me off..
    if i lace them to alphine's any1 know what spoke length i should use? would it be the same for both side's or different like a geared rear hub
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    Mar 2005
    Using the dt swiss spoke calculator, and assuming that you're using the ENO for discs, I came up with 244 mm (32 spokes, 3 cross). Same on both sides.
