Page 2 of 2 FirstFirst 1 2
Results 26 to 27 of 27
  1. #26
    Reputation: rob1035's Avatar
    Started with stan's then switched to slime pro, which seems to last much longer. I have whipped up my first batch of home brew (windshield fluid and latex) and will be experimenting with that soon...
  2. #27
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Why isn't Slime used as opposed to Stan's?
    Quote Originally Posted by BodegaBay View Post
    Zach: so it's OK to switch to Orange Seal after you've used Stan's on your current tires? I just had my first tubeless setup done at the bike shop using Stan's sealant before reading about OS. I live in the high desert and expect the Stan's to dry out quickly. Will refill with OS instead.
    Both Stans and OS use natural latex so yes they can be mixed. The only sealant I'm aware of that does use natural latex is Cafelatex which has a unique artificial base. It can't be mixed with natural latex. Read the ingredients, natural always mixes with natural, even with Slime mixed in.
    IME, again, homebrew is as reliable as any commercial latex sealant and SUBSTANTIALLY less expensive.
    Old enough to know better. And old enough not to care. Best age to be.
  1. Slime PRO for UST Application?
    By cru_jones in forum Arizona
    Last Post: 03-18-2014, 10:50 PM
  2. Replies: 1
    Last Post: 07-23-2013, 05:08 AM
  3. Tubes, should I go w/ Slime or something different?
    By tealboy1 in forum Wheels and Tires
    Last Post: 03-14-2013, 12:08 AM
  4. Slime in crossmax st?
    By kneetowaist in forum All Mountain
    Last Post: 11-14-2012, 04:28 PM
  5. Liners or Slime
    By Licketysplit in forum Arizona
    Last Post: 06-10-2012, 04:09 PM
