Page 2 of 2 FirstFirst 12
Results 51 to 89 of 89
  1. #51
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Wheelbuilding resources
    Quote Originally Posted by aizu1 View Post
    Would it be possible to replace a rim with an ERD of 599mm with new rim with an ERD of 595mm using the same spokes? Maybe by using longer nipples?
    No. You need shorter spokes.
    mtbtires.com
  2. #52
    GoCyco
    Thanks Shiggy. I was thinking the other way. So my spokes are 4mm too long. That doesn't seem so much but I guess I need lots of thread to have a strong wheel.
  3. #53
    Dec 1998
    Ummmmm...no. You still need to learn a lot about wheelbuilding.
    mtbtires.com
  4. #54
    Reputation: chuckeieio's Avatar
    Jun 2013
    You'd have spokes that are 2mm too long. 1mm you MIGHT be able to work with. 2mm no unless the threads were barely engaged to begin with on the stock build which is never the case.
    GTA
    Ontario
  5. #55
    Reputation: spyghost's Avatar
    Oct 2012
    this may have been discussed, but... what is the 'subjective' indicator that you've tensioned the spokes correctly? is there something audible (creaks) or visual (spoke twist).
    (sort of like knowing that you've tightened a nut/bolt correctly without a torque wrench)
    i'm relying on the fact that old school wheel builders didn't have any tension gauges nor any objective (numerical) means of measurement of any sort.
  6. #56
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by spyghost View Post
    Just like in the auto trade - tighten until something breaks and then back off a 1/4 turn.
    But seriously, there really is no indicator other than gut feeling. And it does work as I built wheels for half a century without a tension meter and none failed from not measuring tensions. But what's more important than exact tension is equal tension and that's easy to determine - by plucking spokes and listening to their tones. Equal tone = equal tension, if you're just checking spokes on one side of the wheel and comparing to each other (NDS and DS spokes have different tensions of course).
    Then, two months ago, I obtained a tension meter (the excellent Wheel Fanatyk Digital Tensiometer and I found that all my wheel tensions were on the low side ~ around 95kgf where (depending on the rim) 100-125kgf is the normal range. But - my previous tensions must have been acceptable as my wheels didn't suffer from the normal problems of low tension - loosening nipples and fatiguing spoke elbows.
    And I also proved that obtaining equal tension by plucking and equalizing tones is just as accurate as this digital tensiometer - for me anyway but then I've got lots of practise.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
  7. #57
    Oct 2012
    Thanks Mike.
    I'm used to twisting relatively high torque threads since I've worked on cars before. Perhaps this disrupted my perception of low torque threads.
    I'm just waiting for the arrival of my wheelsmith spokes and I'll be building my 29er. 36h ztr flow ex and hope pro 2 evo.
    I've got no issues with lacing, truing, etc. Just hitting the right tension.
    Anyway we'll see. Hope for the best wish me luck.
    @Mike a few q's regarding your site about stress relieving:
    - when you say 'you've got a fair amount of tension, when is that?
    - is that the baseline true or something else after that?
    - is that the point where i loose the arcs formed by the intial lacing after the baseline true?
    - coming from this 'fair amount' of tension, approx how many turns is that away from the 'correct/ideal' tension?
    - i reckon method 1 and method 4 should be done at the same time?
    - when do i do method 3?
    - when do i know that i've properly stress relieved the wheel? i tried method 2 on several wheels. they do sound, but i think the sound comes from the friction between the crosses.
    for method 1 - by tapping the j bend flatter, do you mean pushing the spoke to sort of 'pinch' the flange between the spoke head and the j bend itself?
  8. #58
    If you have a tone generator or tuner handy, you can often get a sense of the tension on the wheel, provided you also have an idea for what octave you are listening for. See http://www.bikexprt.com/bicycle/tension.htm. Note that this only really works well for straight gauge spokes (see below).
    The bad part is, if you have no experience tuning instruments, you can be easily mislead by false beating; this happens for a few reasons, but the short answer is that spokes aren't built to be good tone conductors, especially butted spokes.
    I've built a couple pairs of wheels like this, mostly as a curiosity, and it does work. Certainly not as convenient as a tensometer, but a careful ear can do pretty close.
  9. #59
    Beer Please! SuperModerator
    Reputation: Klurejr's Avatar
    Added a video link to the first post on Wheel Truing.
    Ride Bikes, Drink Craft Beer, Repeat.
    Know these before you post:
    http://www.mtbr.com/guidelinescrx.aspx
  10. #60
    A wheelist
    Quote Originally Posted by Klurejr View Post
    Can you please clear out any broken links? Thanks.
  11. #61
    Reputation: kali's Avatar
    Nov 2006
    Hi guys
    I'm having a problem with one of my first build..
    on my rear wheel, when I want the left side tight enough, it's very hard to get the wheel dished without having the drive side extremely tight.
    Is that a problem of spoke length ?
    all spokes have the same length, 266mm
    Light bicycle carbon rims
    DT 350 disc
    Sapim D-light j-bend
    I know that the spokes are a bit too short as I ordered the spokes before having the rims in hands... and LB erd is wrong by 3mm
    I just think that is strange, because difference between both sides is big
    Thanks !
  12. #62
    Nov 2007
    hate to tell you this, but it would be impossible to get the correct spokes without first having the rims.
    Because you can't know the rims ERD until you measure them, and I wouldn't go by the manufactures listed ERD, they are known to be off.
    2nd, you mention Disc. Well if you want to take into account the Rotor, then you need to calculate the dish even for a front hub, and the lacing pattern to support the Rotor.
    You didn't mention if this is a front or rear wheel.
    And I question all the spokes with the same length then on a Disc wheel sounds wrong.
    I started with Jost Brandt's Wheel building book, which is dated now. I have since used Roger Musson's which is more current and covers Disc wheels. It's about $15 for the PDF. And you can print out the pages that cover your needs, put them on a clip board to follow out in the shop.
  13. #63
    A wheelist
    Quote Originally Posted by kali View Post
    NDS spoke tension is always a product of DS tension and flange spacing, not the other way around. You get DS tension to what you want it to be, dish the wheel and NDS tension will be what it is.
    Example - you want DS tension to be 120kgf. You tension to 120kgf, check and adjust dish and NDS tension will end up around 60kgf, or approx, depending on flange spacing.
    Nope. It's a problem from back-arsewards tensioning.
    all spokes have the same length, 266mm. I know that the spokes are a bit too short as I ordered the spokes before having the rims in hands... and LB erd is wrong by 3mm
    You can't mess around here. Spokes have to be the right length and you have a +/-1mm fudge factor. Parts need measuring before spokes are ordered or there is a big chance they will be wrong.
  14. #64
    Nov 2007
    you must have just written your reply right after me. Just want to say if you're going to be an advocate to newbies, you may want to direct them to resources or given a simpler explanation than going into tension. Look at my post and let me know if you agree with it.
    BTW: I agree with your point, but the builder it seems is missing the whole point about measuring parts out correctly to begin with. That is why I mention ERD, Disc hubs, and the dish. Let them first get that correct and get the wheel straight before they have to worry about the finished product and tension.
  15. #65
    A wheelist
    Quote Originally Posted by oberwil View Post
    At the top of this forum is a wheelbuilding stickie with lots of resources plus, the link in my sig takes you to my wheelbuilding site - which contains all the info and resources (that are put there to provide the info that my site never will) that anyone will ever need. If a newby wheelbuilder is planning on building wheels, they need info first, build second, not the other way around. Horse before cart.
    EDIT - we're even posting in the wheelbuilding resources stickie.
  16. #66
    K&K
    Reputation: ki5ka's Avatar
    Mike, your suggestions and resources have been invaluable to this neophyte wheel-builder. Over the past couple of years I have built 3 wheel sets using the information you have provided here. Thank you for all the time you put into this forum.
    As you point out, the research has to be done first, impatience cause me to have to re-order spokes, and re-build my first set several times before I sat back and took a more patient and disciplined approach.Wheelbuilding resources-wheelbuilding-square-copy.jpg
  17. #67
    A wheelist
    Thanks Ki5. I just does my best. Nice pic BTW.
  18. #68
    Nov 2006
    Thanks for the very quick and precise answers ! ;-)
    So I can't do better than I did, I just wanted to have the NDS thighter, but it's fine.
    What is the usual difference in kgf between both sides ?
    "back-arsewards tensioning" Sorry my english is not good enough to understand that, what do you mean ?
    Of course I know that spoke length is crucial, that was my first wheelset I wanted to get better. As a matter of fact the ERD is not 3mm wrong, but 1.6mm, because I wanted to mount bushings wich I did not go for. So they are slightly too short. That is experience... and now I always await components to calculate spoke length.
    What do you think about 180kgf light bicycle give as max spoke tension ?
    the rim has 3mm of carbon thinkness
    thanks and merry Christmas
    Olivier from Switzerland
    edit : I went for that technique, that's brillant
    Wheel Building Tip No. 6 - Build Rears from Right to Left - Wheel Fanatyk
  19. #69
    A wheelist
    No problem.
    That totally depends on the hub flange spacing away from the center line and the flanges' widths apart.
    "back-arsewards tensioning" Sorry my english is not good enough to understand that, what o you mean ?
    It means you did it backwards. Required DS tension should be achieved and the NDS tension will be what it is when you have the correct dish. It doesn't matter what it is as you can't change it - other than by increasing DS tension and there is only so high that you can go.
    Of course I know that spoke length is crucial, that was my first wheelset I wanted to get better. As a matter of fact the ERD is not 3mm wrong, but 1.7mm, because I wanted to mount bushings wich I did not go for. So they are slightly too short. That is experience... and now I always await components to calculate spoke length.
    New wheelbuilders need to have everything as perfect as possible to lessen any problems.
    What o you think about 180kgf light bicycle give as max spoke tension ? the rim has 3mm of thinknesse
    That's a very high tension but I don't know anything about those rims. The rim is the weak link.
    Mike in Canada!
  20. #70
    Nov 2006
  21. #71
    Reputation: dirtrider76's Avatar
    Sep 2012
    Props to Mike T! I used his site set a wheel next to my build and fired out my first complete wheel last night. Took me about 1-1.5 hours to build and came out with no hop and just a tiny bit of run out I'll fix when I got to my friends house with a stand.
    I probably should have started with something else but I needed to build these. Industry9 hubs, Sapim Race/Polyax and 295trails.
    I like to fart when I'm in front of you on a climb
  22. #72
    A wheelist
    Quote Originally Posted by dirtrider76 View Post
    Cool! Glad to be of some service. I hope you didn't rush with that "1-1.5 hours to build" as that's a very short time for a first-time wheel. It takes me longer than that (and I'm never in a hurry). Don't forget oodles of stress relief. You can never do too much.
  23. #73
    Sep 2012
    I've swapped rims before just never built from scratch. I just got them with some tension on them till I get access to the truing stand. I was not in a hurry I just laid out all my stuff and once I had the first side done it went fast. Getting the actual layout and getting the logo on the hub lined up with the valve hole and making sure the logo on the rim was correct took some time. I actually started the spokes, rotated the hub and it was off so I adjusted it.
  24. #74
    A wheelist
    Roger Musson's e-book gives the definitive info for lining up the valve hole and the logo. BTW - you already have a truing stand - your fork (or frame) !!
  25. #75
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    i used roger's e-book for my first go around and they came out real good.
  26. #76
    Oct 2012
    i'm not a pro builder, just doing these for myself, but since i started building several months back, i just realized that after a hard day's work in the office desk, wheel building/truing is relaxing.
    the wheel turning on the the truing stand, the sound of the spokes getting higher and equal pitch as the rim gets closer to the gauge soothes me.
    the plus factor here is that it feels awesome once i get equal pitch and a radial/lateral true build.
    Canfield Yelli Screamy
  27. #77
    Feb 2010
    I have all the parts on order to do my first solo (and disc) build. I built the wheels for my road bike at my old LBS with the lead mechanic there to give me guidance, but I had done lots of reading, to include Mike T's site before I got to work. I really enjoyed the experience, especially just getting in the zone when adding tension and how everything else just disappeared.
    My question as I start reading again for this build, is do I need a dishing tool before I get started? Being in the military and currently stationed overseas, mail order is my means of acquiring the parts and tools that I need, so time is required.
    I'll be building up a set of Nextie 42mm Crocodile rims with White Industries XMR plus hubs and double butted spokes. This is also my first carbon build. I'll keep doing my reading and research, but any advice is humbly accepted!
  28. #78
    nerd
    Nov 2012
    Some less-known books
    Building Bicycle Wheels by Robert Wright, 1977
    The Spoking Word by Leonard Goldberg, 1984
    Book review: Goldberg's Variations (Bike Tech, April 1985)
    Perfect Wheel by Richard Talbot, 1986
    An Illustrated Guide to Bicycle Wheel Building
  29. #79
    Reputation: andrepsz's Avatar
    Jan 2013
    Bonking ... not feelin' well
    Ok...trying and see If someone can help me here: I'm new to wheel building. I just signed up on the DT swiss calculator to investigate a 'soon to be done' Front wheel build....but I bumped into a mystery while entering some data to understand things. Here is the problem: I have a 26" Lefty front wheel a part.
    -Rim: ZTR 26" Crest, ERD: 541m, 32H
    -Lefty Hub:
    • Disc Flange Diameter: 58.0mm
    • Non-Disc Flange Diameter: 45.0mm
    • Disc Flange to Center: 18.8mm
    • Non-Disc Flange to Center: 31.6mm
    -Spokes lenght:
    • Half is: 250mm
    • Half is: 255mm
    -The number of intersections is 8 on each side (it has to be right?)
    -Nipples as standard 12mm long.
    The Mystery: Entering the all that data on the DT swiss tool, it gives me Recommended Spoke length 300mm and 292mm...
    I can see that by changing the number of intersections down to 2 on each side...the tool gives me approximate lengths to my spokes. I checked the configuration when the wheel was assembled and it was with 8 intersections on each side.
  30. #80
    A wheelist
    Quote Originally Posted by andrepsz View Post
    What do you mean by "8 intersections"? You mean spoke crosses? I don't understand. Wheels are either radial, 1x, 2x, 3x or 4x.
  31. #81
    K&K
    What Mike said...
  32. #82
    Reputation: Jado's Avatar
    Hi,
    Building with this rim (HD layup version, 40g heavier) what would be your recommended kgf to balance the tension at? Appreciate your input cheers.
    Hookless carbon 650B mtb 35mm wide AM 27.5 rims tubeless compatible Light-Bicycle
  33. #83
    Reputation: Schulze's Avatar
    Feb 2007
    Max tension says 180 but I would just go to 130kgf on the drive side.
  34. #84
    Jan 2013
    With such a strong rim, the allowed max tension for the hub flanges is the limit.
    If the hub manufacturer does not limit the tension, i would assume that 120Kgf -130 Kgf is the best bet. That numbers are virtually a standard among wheel builders.
  35. #85
    May 2012
    I got some wheels built for about 200USD (it felt like much - though this is in SF, CA) and riding em I found the front wheel to look a bit out of true (though its not by much if I put my finger at the rim, but looks like much when i look at the tire).
    To be sure and because it annoyed me a bit, I decided to get a parktool tension meter and a a truing stand (all that is less than 200USD actually...). I re-read the tension on all spokes several times to ensure I knew how to measure correctly and so on (and i always get the same reading within 0.5 notch on the tension meter)
    Rear wheel seems mostly true and front wheel indeed is not as true as I'd expect from a professional build. But then, tension seems rather bad - though I've no experience with this.
    I'm still reading the countless docs on how to build wheels but would like some rule of thumb, basically are these wheels been built really bad or is this acceptable? (it looks pretty terrible to me...)
    Back: ht mtb | Park Tool (Standard Deviation of Tension Right side (kgf) 16.23)
    Front: ht mtb | Park Tool (Standard Deviation of Tension Right Side (kgf) 10.38)
    Thanks for your help (note if you're curious about the rim/spokes I put all data in the parktool thingie)
  36. #86
    Feb 2007
    boubla, looking at the component list, am I reading this correctly that you paid someone $200 in labor to build those wheels? If so, I would send them back and tell your builder that you expect a lot better, like +/- 5 kgf tolerance.
  37. #87
    May 2012
    Quote Originally Posted by Schulze View Post
    yes, though it was a little while back, i doubt they'll re-do it (live and learn...). The whole reason I'm getting into this is because it looks so off even without knowing much about wheel building, that I decided to learn how to check all this.
    Anyway, I had a lot more reading since yesterday and indeed its way off. Planning to redo the wheels myself (well really I'm going to play with an old aluminum rim first)
    thanks
    Edit: I casually mentioned the issue to them and despite the long time period they're offering to retension them for free so that's cool (that said I'm still going to train on cheaper wheels as all this got me interested
  38. #88
    Nov 2007
    Tension for wheels is always taken from the rim manufacture.
    I think most rims will fail before the hub flange does.
    But maybe it's best to check both.
    I've always just used the rim as my guide to tension.
    That's why rim manufactures put their recommended tension data
    on the rim. At least Velocity does.
    Quote Originally Posted by Orfitinho View Post
  39. #89
    Jan 2013
    Max allowed tension for hubs can sometimes be found with super light road bike hubs.
    Hubs of tune and extralight are examples, IIRC.
