Results 1 to 7 of 7
    Jul 2013
    Wheel building & Spoke lengths
    Hi,
    I assume this is a common question asked by newbies to wheel building so here I am no doubt asking the same.
    I used a spoke calculator and it told me i needed the following spoke lengths
    Front wheel:
    Left side = 261.6mm
    right Side = 263.7mm
    Rear Wheel:
    Left side = 262.8mm
    Right side = 262.2mm
    Looking to do 32 spoke wheels with 3-cross pattern.
    Is this what I need to buy:
    16 x 261mm
    16 x 263mm
    32 x 262mm
    Thanks in advance
    Dean
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dis00 View Post
    Hi,
    Front wheel:
    Left side = 261.6mm
    Rear Wheel:
    Left side = 262.8mm
    16 x 261mm
    16 x 263mm
    32 x 262mm
    Thanks in advance
    Dean
    Wheelbuilding resources
    mtbtires.com
    Jul 2013
    Thanks for the link to the links. Ive had a good look at them and some suggest to round up or down, mostly down. Am i rounding down to the nearest whole number? or do i go more?
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Re: Wheel building & Spoke lengths
    I would just use all 262. It's less of an exact science than the spoke calculus leads you to believe.
    --Lars
    --Peace
    Reputation: J.B. Weld's Avatar
    It depends which program you use, I usually rounded up with mine (Wheelsmith), 262's would not have worked out well at all if I came up with a 263.7 number.
    Measure the rim before calculating and ordering spokes.
    Dec 1998
    Quote Originally Posted by dgaddis1 View Post
    And the hubs.
    mtbtires.com
  1. help: different calculator, different spoke lengths
    By alternaklaus in forum Wheels and Tires
    Last Post: 03-05-2013, 04:33 PM
  2. First wheel build and I'm nervous about spoke lengths!
    By AmericanTemplar in forum Wheels and Tires
    Last Post: 01-06-2013, 11:17 PM
  3. Spoke Lengths
    By Macbeth in forum Fat Bikes
    Last Post: 03-15-2012, 10:58 AM
  4. Wheel building, spoke question
    By cbieh589 in forum Wheels and Tires
    Last Post: 05-30-2011, 02:33 PM
  5. Wheel build advice - spoke lengths!
    By Hynam in forum Wheels and Tires
    Last Post: 02-23-2011, 03:21 PM
