Results 1 to 8 of 8
    Oct 2011
    Wheel Builder Spoke/Nipple Questions
    Gonna keep this generic because it relates to all wheels (my specific happens to be for my roadbike)
    Had a nipple break, also bending the spoke.
    After taking things apart I find that the spokes barely come to the bottom of the screw driver slot, some are flush, others are below.
    Should I replace this an all the spokes with new spokes that are 2mm longer? The extra 2mm would put the end of the spoke close to the end of the nipple. From my understanding that is a more ideal situation than to short, especially with alloy nipples.
    For reference my spokes are someplace between the left and middle of the below example.
    Wheel Builder Spoke/Nipple Questions-dt-threads.jpg
    Reputation: gmats's Avatar
    Apr 2005
    Where did the nipple break?
    Strength wise, somewhere between middle and right is your strongest. But remember, the pictures you are showing are with the nipple screwed in to the same point where you have about 2 turns left.
    Oct 2011
    It broke basically at the end of the spoke, which fell short of the screwdriver slot.
    I estimate with the current spoke/nipple combo, there is 4mm before the spoke would bottom out.
    bikes don't have motors
    Reputation: life behind bars's Avatar
    May 2014
    Flush with the bottom of the slot is the optimum length.
    Quote Originally Posted by me View Post
    Of all the paths you take in life, make sure that most of them are dirt.
    Quote Originally Posted by mack_turtle View Post
    Gravel bike hate is imagined.
    Sweet.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Yep^^. Middle picture is ideal. I had a Specialized that came with straight gauge 2mm spokes and aluminum nipples. I kept breaking nipples. I realized all the spokes were too short like the left pic. Rebuilt the wheels with 2mm longer double butted spokes and brass nipples and no more breakage.
    Tension's gotta be right too. In fact, before you buy anything, check the ERD on the rim and run it through a spoke calculator like Freespoke. Then your spoke length will be right.
    I like turtles
    I have the same problem on an older wheelset. Could you just swap to brass and call it good enough?
    (Backup wheelset, not worth new spokes)
    Sometimes Rickety, not a turd
    turtles make me hot
    Not really. You really need the spokes to end in the right place.
    I like turtles
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Anywhere between the middle and right is ideal.
    Middle is minimum really.
    Brass nipples will mask this issue somewhat, since they are stronger than aluminum.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  1. Replies: 6
    Last Post: 02-21-2018, 03:29 PM
  2. Questioning wheel builder on spoke tension?
    By keen in forum Wheels and Tires
    Last Post: 08-15-2016, 07:37 AM
  3. Rim without nipple holes - broken nipple
    By C-kaae in forum Wheels and Tires
    Last Post: 06-12-2015, 09:08 AM
  4. wheel building / spoke nipple question
    By VT Mike in forum Wheels and Tires
    Last Post: 06-02-2015, 05:56 AM
  5. Replies: 0
    Last Post: 10-27-2013, 08:16 PM
Members who have read this thread: 61
