    I love scotch.
    Reputation: jlself's Avatar
    Mar 2012
    What tire size range for Sun CR18 26" rims?
    My Cannondale I got used has these rims, and came installed with Kenda 26x1.50 road tires, and I got a set of Kenda off-roads 26x1.95, except one tire has bead showing so I'm replacing that one. I'm checking out PerformanceBike but don't see a 26x1.95 option.
    The other offroad tire for the front is the same 26x1.95, would it matter if I get a different width on the rear? What's the max I should go?
    Lastly, in the good offroad tire (I'd mount on front), there is a slight bend in the bead, and some small tears in 2 parts of the tire. Should I just replace the front, too? The rest looks pretty good.
    I design sites n' stuff www.jade-raven.com
    And play guitar www.bryssis.com
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by jlself View Post
    1.1"-3.0" will fit on the rim. Your limit is what will fit in the frame/fork.
    Mixing widths is fine.
    The second pic looks fine.
    mtbtires.com
    I love scotch.
    Mar 2012
    But not the first pic? That's from the same tire as second pic.
    Dec 1998
    If you do not trust it, replace it.
    mtbtires.com
