    Reputation: ToneyRiver's Avatar
    What Rim Should I Use?
    I'm building up a new wheel set using Chris King ISO hubs and do not know what rim I should use. It is for mostly trail riding so do not want a light weight XC racing rim but also do not want All Mountain DH rims. I would also like to keep it alloy don't want to go carbon too expensive. Any suggestions? Thanks!
    Reputation: GEARHEAD_ENG's Avatar
    Re: What Rim Should I Use?
    You have a lot of options. What is your geared up weight and how aggressive do you ride?
    A few wide and lighter weight rims that you can run tubeless.
    Stans Flow
    Pacenti DL31
    I just built a set of TL28, but they are more of a wide XC rim (similar to a Stans Arch).
    Sent from my SPH-L710 using Tapatalk 2
    May 2013
    Stans Flow or Arch are pretty much standard category for trail/AM
    Stans Crest would be XC.
    My personal favorite would be the Flows.
    Geared up weight would be about 170-175lbs. I have had a few problems in the past with Stan's rims but it was the Crest rim a welding splint would come loose and bang around in the rim, nothing structural but annoying it happened with a few sets of them.
