Results 1 to 12 of 12
    Mar 2013
    What causes spoke failure when JRA?
    I'd never broken anything but in the last 2 rides I've broken my rear derailleur, cassette (sheared a cog off), chain, and now a wheel spoke.
    ALL while quite honestly JRA. Totally smooth and flat terrain while soft pedaling each time.
    Do you guys carry spare spokes in your bags? I'm thinking maybe I should start.
    Nov 2012
    Previous damage manifesting itself. Spokes in a bag isn't going to work, but stuffed in the seatpost may work.
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
    Mar 2013
    Quote Originally Posted by shupack View Post
    Makes sense, just seems like it would break when you went off a drop or something, not under minimal load.
    Are you saying a bag wouldn't work because they'd get bent around in my camelbak? What if I taped them to a ruler first?
    Reputation: J.B. Weld's Avatar
    Most likely the spoke was either previously damaged or the wheel was poorly built, I've never known anyone who carried extra spokes during a mountain bike ride unless it was an extended tour or something similar.
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Galvanic corrosion. GOOGLE it..
    Todd
    Jun 2014
    Purely from an engineering perspective, just the vibration of JRA can cause a small crack caused by something catastrophic to get bigger and break.
    Mar 2013
    Quote Originally Posted by J.B. Weld View Post
    Gotcha. To what extent should I baby the bike back when a spoke is broken? There's still 31/32 spokes remaining but with the tension on the 31 remaining, the wheel will be out of true so I imagine that puts extra strain on the remaining spokes and it's worse than having just 31/32nds as strong of a wheel.
    I was only 4 miles from my car when it happened today and could take pavement all the way back, but what if I was further out and didn't have the pavement option?
    Mar 2013
    Quote Originally Posted by Flyin_W View Post
    My $ is on a factory wheel. When machine built they rarely get spoke prep, or any lube.
    This causes the nipple to bind to the rim, or to seize onto the spoke, and either can cause failure while JRA.
    It's easy to carry spares, a cassette tool, chain brake & big-azzed crescent not so much.
    I carry a chain breaker... I've never replaced a spoke but based on your post I'm assuming you need a cassette lockring tool to replace the spoke?
    And yes, Roval Traverse 29 wheelset. Factory on my Stumpjumper Evo.
    ^ Weird time lapse going on. To remove a cassette to get to te drive side spokes you'll also need a chain whip. (big/heavy)
    Mar 2013
    Yeah I saw that in another thread too.
    Alright, not doing that then. How bad is it to ride on a wheel with a broken spoke (just to get back to your car)? I'm not going to be going off any drops or plowing through rock gardens but not having to walk it would be nice.
    Reputation: squareback's Avatar
    Re: What causes spoke failure when JRA?
    I have heard of poorly implemented tubeless conversions, leaking Stans through the spoke threads, causing corrosion and then failure.
    This was relayed to me by a race mechanic, regarding a perplexing failure I saw with my own eyes
    sent remotely
  1. Replies: 9
    Last Post: 03-17-2015, 08:52 AM
  2. Replies: 16
    Last Post: 01-28-2014, 10:32 AM
  3. Replies: 0
    Last Post: 08-12-2013, 12:07 PM
  4. Bicycle Wheel Spoke Patterns and Spoke Fatigue
    By TigWorld in forum Wheels and Tires
    Last Post: 11-05-2011, 07:33 AM
  5. Best post-crash durability: High spoke alloy or low spoke carbon?
    By fueledbymetal in forum Wheels and Tires
    Last Post: 09-13-2011, 08:12 AM
