Results 1 to 8 of 8
    Rides the Desert
    Reputation: ltk1144's Avatar
    Dec 2011
    Weirwolf 2.5 29er tire
    Honesty is this tire even useable? I dont think theres any frame that can fit a tire this wide between the chainstays. I never thought there could be issues with tire width up front but I just found a thread with some guy complaining about a 2.3 Purgatory rubbing on his Reba. I would very much like to have a tire this wide as it would be BA but will it even fit on the front?
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    That WTB tire will go good on a white bros groove 200 (pictured is a 2.4 maxxis with still a lot of room left between the legs) also a Marzocchi 44 will fit that tire (seen here also with a maxxis ardent 2.4)
    Another factor is the size of the rims.Tthe SUN MTX33 is... well, 33mm wide so a rim
    like that between a Reba will make poor Reba blush between the legs. A narrower
    rim may be the answer. In the photo with the Marzocchi I am using a narrower 27mm
    Alex SX44, thus the 2.4 Maxxis fits nicely with room to spare.
    However you may be right about a frame unless you ride a PBJ or LunchBox. Them big bones are pretty wide. IMO although I have a freeride 29er, a 2.5 is overkill. I have 2.3's and 2.4's and they are plenty wide.
    Reputation: vapezilla's Avatar
    I run it on the front of my niner one9 with rock shox Reba pro
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by ltk1144 View Post
    Sure it will work - especially since most reports are that it only measures out to be a 2.2 - 2.3 tire at best.
    great tire on my MC29er
    meow meow
    Reputation: b-kul's Avatar
    it is maybe a 2.25 tire. and heavy to boot!
    Reputation: Gasp4Air's Avatar
    WTB lies about the size of this tire.
    Use it, use it, use it while you still have it.
    How's the size and weight compared to the Rampage?
