Results 1 to 7 of 7
    DBR
    DBR is offline
    Be Present.
    Reputation: DBR's Avatar
    Apr 2005
    Weight Limit on Stans NoTubes Crest
    On Stans NoTubes website, it says the rider weight limit for the ZTR Crest is 190 lbs. I weigh 190 lbs. I want to keep my bike light and would rather not go the Arch EX route.
    I should be good on the Crests, ya?
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    depends on a lot of things but I weigh 200 and have ridden both 355s and Crests without issue... as have others in the 200-lb weight range.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    mtbpete
    Reputation: changingleaf's Avatar
    It certainly depends. Lightweight spokes, such as DT Revs would not be a good choice at your weight. With Sapim Race or DT Competition spokes the wheels should be pretty solid for you, but the Crest rims do dent easier than heavier rims.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by meltingfeather View Post
    +1 - A stock Stan's build Crest wheel set is fine for me (195 lb in the buff) and they also work for some jolly ~220ish lb cronies who hike it off bigger drops than I do..
    I also run a set of 355's with DT triple butted spokes that have been stellar. I tend not to hit staircases and other fun trail/urban features with that wheel set however I certainly do with the Crests.
    【ツ】 eDub 【ツ】
    DBR
    DBR is offline
    Be Present.
    Apr 2005
    So, the spokes would take more of a hit than the actual rim? I don't mind replacing spokes, as long as it isnt frequent. The Rim is what concerns me.
    DBR
    DBR is offline
    Be Present.
    Apr 2005
    Cool, thanks for the responses guys!
    Nov 2012
    OTOH, I just removed a set of Crest rims in favor of Arch because they were so flexy.... I weigh 180ish nekkid. Wheels were built by me, properly tensioned & checked with a park tension meter to check, straight 2.0 spokes and brass nipples. put maybe 300 miles on them.
    I found a set of lightly used Arch EXs and swapped them, same spokes/nipples out of impatience (wanted to try them out before leaving on vacation). Will be re-lacing with lasers and alloy nipples to offset the weight. First ride around the yard was a night-day difference in the feel/handling of the bike. Pulled a wheelie and instantly went over backwards.
    edit: hmmm, wonder if my tension meter is reading high?
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
  1. Crossmax SLR or Stans Notubes Crest + Tune Cannonbal & Kong
    By LeftyBiker in forum Wheels and Tires
    Last Post: 10-20-2013, 12:57 PM
  2. Stans crest weight limit.
    By kikoraa in forum Wheels and Tires
    Last Post: 06-03-2013, 02:32 PM
  3. Replies: 5
    Last Post: 04-25-2012, 06:12 AM
  4. Stans Notubes Ztr Crest 29Er Black - light XC and road
    By PatrickK in forum Wheels and Tires
    Last Post: 11-13-2011, 02:08 PM
  5. Do Stan's Crest 29er Have a Weight Limit?
    By ckropp in forum Wheels and Tires
    Last Post: 02-25-2011, 10:17 AM
