    Jan 2016
    Vittoria Airliner Smash test
    https://youtu.be/aA--7JqFU1U
    I found that the Airliner delivers on its ability to do more than just protect your rims! Now if they just weren't soo $$!
    5010 v1, MikeLikesTrails/MTBfilmschool
    Hey I just stumbled across your video. Nice job man! I had Cushcore, the install and removal with my carbon hoops was absolutely ridiculous. I've been looking at these. I'd gladly pay the $20-30 difference in cost if they are as easy to install as it looks. Any other updates on performance? Did you remove a tire yet?
    Jan 2016
    Quote Originally Posted by monts View Post
    Yes I have, I moved it from the rear of the hardtail and rand it in the front of my 5010 for a while, it does take more force to unseat the bead, what I found worked really well was using my knees for leverage on the spokes, then flexing the tire down as sharp as I could and it usually broke free. I would like to see if a wider rim/tire combo makes it easier, I feel like 30mm rims with 2.5 would be filled up less with the insert and make the install/removal even easier. I am moving it to the rear now that we are getting into wet leaf time of the rear, if I can run 22psi in the rear that should help a lot with traction. (I usually need 26)
    Oct 2015
    I currently have the Pepi's Tire Noodle but I like the look of these, might be an alternative if the Pepi's doesn't last.
  1. Airliner Crash At SFO
    By Brewtality in forum California - Norcal
    Last Post: 07-29-2013, 10:29 PM
  2. Test test, test test test test
    By axelbaker in forum test forum
    Last Post: 07-18-2012, 09:26 PM
  3. Replies: 8
    Last Post: 04-25-2011, 12:02 PM
  4. Semi OT - Airliner cargo holds
    By Ultra Magnus in forum General Discussion
    Last Post: 03-23-2005, 07:43 PM
Members who have read this thread: 105
