Results 1 to 7 of 7
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Velocity wheelset
    Anyone have any experience with the Blunt Sl wheelset?
    I currently have an old set of VXC Disc rims and Hope hubs that have been a good, but heavy, wheelset. Looking to go tubeless as well.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mopartodd View Post
    Blunt SLs are not much lighter than the VXC and there are better choices for tubeless (WTB TCS).
    mtbtires.com
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I find the Blunt SL to be a very soft rim. I've dented my rear wheel a couple of times before finding the minimum pressure that I can run without bottoming out my tire on my local trails. The wheel also had a tendency to get our of true when built at 90 kgf but once I've bumped it closer to 110 kgf it's much better although if I remember correctly it's over the published limit.
    Basically, it's nothing exceptional and I would look at the WTB as proposed by shiggy if I were you.
    Check out my SportTracks plugins for some training aid software.
    Reputation: Bike Whisperer's Avatar
    I'd either look at the WTB i19 TCS or the Pacenti CL25. The WTB uses a stiffer (and therefore more dent resistant) alloy and a UST compliant bead shape that makes installing tubeless ready tires a snap. The Pacenti is the same bead shape as the Blunt SL but with eyelets. It also doesn't have the reputation of denting easily.
    2015 Kona JTS
    Jan 2009
    I have had a few sets of Blunt Sl with CX Ray spokes built up by Velocity. I have found them be excellent wheels. Velocity tends to run 110-120 kgf spoke tension. Mine have remained true and I have had no real trouble with denting. I run 28 PSI with 2.125 tires and weight 145 lbs.
    Quote Originally Posted by Drider85 View Post
    Thanks. Wouldn't happen to know the "real world" weight of those wheels would you?
    2015 Kona JTS
