UST Tire advantages for standard rims when going tubeless?
Are there any pros/cons to using tubeless ready tires with a standard rim when doing a tubeless conversion?
The problem is in using a standard rim. Will never work as easily or securely as a proper UST spec rim/tire tubeless setup
mtbtires.com
Plenty of people run a standard rim tubeless without problems.
It is a crap shoot if a specific tire/rim combo works. Many more issues with "tubeless" conversions than with proper tubeless setups. Not even Notubes guarantees results when a tire/rim is used outside their design intent. Try at your own risk.
mtbtires.com
Back to the original question:
- You may not post replies
- You may not edit your posts
Forum Rules
