    29er
    used 2011 crossmax vs new 2013 crossride ?
    found a set of used 2011 crossmax 29ers for $350
    but you can also buy a brand new set of 2013 crossride 29ers for only $300
    what do you guys think? which should i go with?
    the only advantage i see with the used crossmax is no need to run tape to go tubleless and a little lighter
    the advantage of the new crossride, is they are new, and have full warranty.
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    I'd go with warranty.
    How used is used? Do they have axle or freehub play? Have they ever been serviced?
    Lots of questions to ask. I wouldn't immediately discount getting a UST spec wheelset for $350 if they are in good shape.
    Nov 2012
    Crossmax or Crossride
    Go with the Crossmax, brand new with warranty. The Crossmax is a great wheelset, just got my Crossmax ST and I love them. Very stiff, compared to the stock Roval Traverse that came with the Stumpy. For $50 more go brand new. Thru-axle adapters usually come for the rear, but for the 20 x 110 mm TA front, you'll have to purchase a $12 set of adapters. Once you get them, just ride them. Going tubeless I assume?
    Sorry, I just realized the used one is the Crossmax, I'd hold off and get a new set of Crossmax, slightly lighter than the Crossrides, too. I guess if you're doing XC, the Crossmax will do you just fine.
