Results 1 to 5 of 5
    Tubless tire mounting isssue
    Here's the deal- I've converted many other rims to tubeless, mounted etc.... I feel like I'm a capable mechanic.
    So, I bought a bike that was already set up tubeless with Vee Rubber Trail Takers mounted and now am trying to get a new tire on.
    Basically, I can't get the dang thing to seat onto the rim. I'm using a compressor, plenty of Stan's, and using a mix of dish soap and water in a spray bottle to help.
    Nothing is fricken' working. Anybody have any secret?
    Rim is a Sunrigle "Equilizer" 650b.
    Success-
    I ended up putting an inner-tube in, and then inflating it and letting it sit for about 20 minutes. After that, I deflated, removed the tube, and inflated w/o stans. At that point, it took to the rim, so I deflated, barely broke the tire from the rim, put Stan's in, and re-inflated.
    Reputation: MSU Alum's Avatar
    Yep.
    Sweater
    Reputation: Buzzaro's Avatar
    Quote Originally Posted by mbell View Post
    I know you got it but.....
    Do you take the valve stem out? I remove the valve stem and use the blower nozzle. My air compressor also adjusts to how much air it lets out, I'll turn it up on stubborn ones.
    All out of S**** and down to my last F***
    The sun equalizer rims are not tubeless ready or tubeless compatible by any standard. Its time to put a tube in!
  1. Air Tank for Mounting Tubless Tires???
    By bowler1 in forum Tooltime
    Last Post: 02-18-2013, 05:28 PM
  2. Air Compressor for Mounting Tubless Ready Tires?
    By bowler1 in forum Wheels and Tires
    Last Post: 01-22-2013, 01:57 PM
  3. tube in my tubless tire - can I run it at low pressure?
    By Scott O in forum Wheels and Tires
    Last Post: 11-24-2012, 05:57 PM
  4. Tubless Ready Tire Selection Help
    By wyo_biker in forum Wheels and Tires
    Last Post: 03-01-2012, 03:04 PM
  5. New to tubless..front tire go BOOOMMMM
    By Iceman30 in forum Beginner's Corner
    Last Post: 09-25-2011, 03:15 PM
