Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 51
    Reputation: ggnarl's Avatar
    Tubeless tire pressure survey
    As a new convert to tubeless I was wondering what people are running pressure wise: Please state your weight, tire pressure, and tire size for edumetainment
    thanks
    Where's my funny hat?
    68kg, 26/28psi f/r, 2.25-2.4"
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by ggnarl
    thanks
    Weight 200 / 210 geared
    Full Boinger (NoTubes Arch) = 29x2.1 24psi F / 27psi R
    (2nd wheelset Sun RhynoLite) = 29x2.35 23psi F / 29x2.3 26psi R
    Rigid SS (22mm rim) = 29x2.35 19psi F / 29x2.2 21psi R
    (2nd SS/fixed wheelset Kris Holm 40mm rim) = 29x2.4 12psi F / 29x2.4 15psi R
    CCCMB web - Facebook
    SLO trail maps - conditions
    "The physician heals, Nature makes well" - real fortune cookie
    trail addict
    Reputation: Uncle Six Pack's Avatar
    I am about 160 (170 geared up)-all my tires are ghetto tubeless now
    6 inch full sus
    Front 2.4 Enduro Pro 22-23
    Rear 2.3 enduro pro 27-28
    Hardtail
    Front 2.35 rampage 22-23
    Rear 2.35 rampage 27-28
    Generally about 5 psi less than I used to use with tubes.
    You better just go ahead and drop that seatpost down to the reflector... the trail gets pretty rough down there.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    190 lbs geared up,
    5.5" full suspension bike,
    26x2.4 Continental Mountain King UST F&R
    Front: 24-25 psi / Rear: 26-27 psi.
    26x2.35 Schwalbe Fat Albert UST, same pressure as stated above.
    For races I use tubed Schwalbe Racing Ralphs 26x2.4 F&R and run them with:
    26-27 psi in front / 27-28 in the rear.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    MEDBLKANOSCBLT2RP23
    Reputation: pakdoc's Avatar
    Dec 2005
    200lbs geared
    Maxxis HR Lust 2.35 USTs 27F/30R
    Stans sealant
    Blur LT2
    175lbs
    2.1 maxxis crossmarks ust
    26psi front
    28 psi rear
    Reviewer/Tester
    Reputation: Rainman's Avatar
    165lb.
    FS: 25/25
    HT: 25/25
    Stans Flow rims, Panaracer Rampage tires front and rear, both bikes.
    Tubeless with Stans yellow tape, home brew sealant.
    R.
    It is inevitable ...
    Reputation: kevbikemad's Avatar
    150 lbs
    f - 20 - 23 psi
    r - 22 - 25 psi
    2.0 tires
    xc riding/racing
    Reputation: shiggy's Avatar
    Dec 1998
    thanks
    For UST and tubeless ready tires I use about the same as I do for the same model/size standard tire with tubes.
    When I experimented with DYI "tubeless" conversions I needed to run 5-15psi higher pressure to keep the tires from squirming in the corners.
    mtbtires.com
    great. I am trying to collect datapoints so I can make a scientifical type graph, so if you please?
    Reputation: cabbgage's Avatar
    furious fred's 2.0
    73kg's
    28frount
    32rear
    Underweight Rider
    Reputation: AznRider's Avatar
    XT776 wheelset
    Front nevegal 2.35 sticky E + maxxis DH tubes - 17psi(until i can get ust 2.35)
    Rear Nevegal 2.1 UST tubeless - 20psi
    Reputation: bholwell's Avatar
    Oct 2007
    A graph, eh?
    160 lbs, full 2.25 front and rear, regular tires w/ Stan's, AC rims, hardtail w/ 100mm fork travel
    23psi front / 25-27psi rear (depending on trail conditions)
    LMN
    LMN is offline
    140lbs
    Maxxis Cross Marks 2.1
    F 20 R 22
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    155 lbs
    Kenda nevegal 2.1 on bontrager race lites converted with stan's kit.
    35 psi F/R,
    I'm shocked to see such low PSI from everyone. At 35psi I can look back and see my tire noticeably compressed. I'd be worried about rim damage, but maybe its just the rocky conditions here in vegas.
    Mar 2006
    My rims might be too narrow. I have to run better than 28psi in the front to keep from burping... at 165lbs
    Dec 1998
    Quote Originally Posted by big_slacker
    155 lbs
    35 psi F/R,
    See my post about "converted" tires.
    mtbtires.com
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    I rarely run anything lower than the following:
    Fr: 32psi
    Rr: 35psi
    Trev!
    May 2005
    168 geared
    two differant sets of wheels tried....mavic 21mm wide rim and 23mm wide rim..2.35 nevegals 30 psi f and r i'm surprised at such low pressures also.. ive also used 2.1 nevs in ust ran at 30 psi.... ive tried 26 psi but ng... around here rocks have sharp edges and corners and guarantee cut sidewalls as the rim hits hard on the rocks...
    Reputation: ewarnerusa's Avatar
    185 lbs w/o gear
    29er rigid SS - ghetto tubeless - 2.3" WTB Exiwolf wire bead tires - 30/32 psi fr/rr
    26er FS geared - UST wheelset - 2.0" S-works 2Bliss Captain tires - 32/35 psi fr/rr
    I used to run lower pressures (~25/30 fr/rr) but I've crept back up in PSI as I feel like the fast cornering feels better this way. I don't notice any difference in rear wheel traction between the lower and current pressure. And seeing my rear tire less squished makes me feel like the rolling resistance is better.
    Underweight Rider
    155 lbs
    35 psi F/R,
    If i were to run at the recommended 30psi F/R the bike would be jarring like hell(not that i havent tried). At my current psi, i can rough land a 4' drop and still wont pinch flat my tires. I carry a pump and psi meter during my 1st 5 rides and adjust pressure to check lowest vs most tractable ratio i could get.
    pressures
    I weigh 150 and run crossmark 2.1 up front at 26lbs and ust pythons 2.1 back with 30lbs.I run the same on my hardtail or full susp.I thought I was running sorta on the low side.Much lower and everything gets squirmys and I can feel the tire bottoming out on occasion.I ride mostly hard back,occasionly rocky terrain with some sand.
    Underweight Rider
    Big slacker, how wide are your Bontragers? Forgive me but looking at LMN's post i heaved a sigh of relieve knowing there someone riding at my ballpark psi(thought i was the weird one out hehe)....oh forgot to state i am 135lbs suited up so i guess rider's weight is one of the factors as well. maybe my rims are a bit wider thats why i can run lower psi and not worry about tire squirming?
    BTW rolling resistance is not on the top of my list due to the nature of the trails i ride. Tractability and compliance comes 1st.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    190lbs fully geared and I ride in Phoenix as well, mostly national and the like.
    -819's with Chunder 2bliss tires 2.3/2.2
    -never more than 30 psi, often 25 to 28 psi.
    -I am not a freerider but hit most drops of several feet and below.
    I like with the lower pressures b/c I like my rear tire to conform more on the rocks when climbing the chunky stuff at SoMo and the suppleness I feel on the way back down. If I only rode xc stuff I would use higher pressures for sure.
