Results 1 to 8 of 8
    Aug 2010
    Tubeless sidewall leak/Bontrager team issue TLR...
    This morning I noticed a sidewall leak in roughly 5-6 spots along the sidewall, thus I have sealant pretty much all over on one side of the tire. Is this a case of the sidewall simply being warn out from rubbing and such, or would perhaps putting more sealant in seal things up? I'm guessing the former, and I'll be needing a new tire fairly soon anyway, but I'm hoping its the latter, as my LBS is closed today and I have sealant on hand (thus would love to get a ride in).
    Thanks in advance...
    Reputation: ucdengboss's Avatar
    How long have you had the tire? Maybe the better question is how many miles on what kind of terrain?
    I have never tried tubeless but just bought the XR4 Team Issue tires and have been thinking of going tubeless. This may have me thinking twice.
    Aug 2010
    Quote Originally Posted by ucdengboss View Post
    Quite a while---not sure how many miles, but like I mention I'm due for new tires fairly soon regardless. I'd highly recommend going tubeless...I went the tubeless route about three years ago and have never had a flat or any real issues. In fact this is the first problem I've had with my tubeless setup.
    Reputation: Swissam's Avatar
    I'm having the same problem with the sidewalls leaking sealent through tiny pin holes. Have to pump up my tires every second day. Which is why I went tubless in the first place. Grrr.
    Any solutions? Maybe a different sealent? I'd prefer to keep using the TRL stuff as I paid 35CHF and still have a ton left over.
    Tra a different sealant.
    Caffelatex or Conti revosealant seal up right away, never had porous sidewall issues.
    Quote Originally Posted by Goran_injo View Post
    are sealants mixable? Seeing as I have enough TLR to seal a teams worth of tires it seems a waste to spend so much and it cant even plug micro holes. Maybe mixing it with a bit of Slime or Orange might be the ticket. Still I would rather this stuff would just work on its own as thats what its supposed to do, seal holes.
    Some are, some aren't.
    I don't mix even those that are.
    For me, sealant is too critical to be cheap, and mixing something that works with something that does not work equals a lot of something that I can't trust to work.
    Tubeless sidewall leak/Bontrager team issue TLR...-20150920_190904.jpg
    Well its now leaking through the tread as well. I'm guessing this is not normal.
  1. Bontrager xr4's team issue....
    By stangbang in forum Wheels and Tires
    Last Post: 11-13-2014, 09:58 PM
  2. Bontrager XR3 Team Issue
    By cycling51 in forum 29er Bikes
    Last Post: 08-03-2014, 12:47 PM
  3. Bontrager XR0 Team Issue
    By whitet777 in forum Wheels and Tires
    Last Post: 08-31-2013, 11:20 AM
  4. Replies: 8
    Last Post: 08-11-2013, 03:42 PM
  5. Bontrager Team Issue 29.1 tubeless?
    By nOOky in forum Wheels and Tires
    Last Post: 08-08-2013, 09:33 AM
Members who have read this thread: 4
