Results 1 to 8 of 8
    Reputation: Waltah's Avatar
    Listen! tubeless rim strip issue, bontrager rhythm 29er (pic)
    got rim strips from my LBS. i think they are too narrow. i have bontrager rhythm 29er rims that i think are wider than normal rims. when i snapped in the rim strips one side has a small gap between the rim and the rim strip. this seems wrong to me. i thought it should go as wide as the entire rim. can anyone confirm?
    Gary Fisher HiFi Deluxe 29er
    Reputation: shiggy's Avatar
    Dec 1998
    Yes, you have the wrong rim strip. It should look like part of the rim when installed--bead hook to bead hook.
    And remove the old blue rim strip before you install the correct one.
    mtbtires.com
    damn, figures its the wrong one
    Jul 2003
    Yep, wrong one. They got you the asymmetric rim strip, likely part # 400337 for the RXL wheel. What you need for the Rhythm is the 406892 symmetric rim strip.
    And a Shiggy noted, pull the blue rim strip out before you install the TLR strip or it won't seat properly in the rim.
    Good Dirt
    thanks squash! should i share that 406892 part number with my LBS?
    Dec 1998
    Quote Originally Posted by Waltah View Post
    Just say you need the Rhythm Symmetric 29. The part number has changed in the past. No need to confuse new/old stock.
    mtbtires.com
    thanks again.
  1. Issue: Bontrager Rhythm wheel system
    By dtkavc in forum Trek
    Last Post: 04-25-2017, 08:58 PM
  2. Replies: 4
    Last Post: 08-09-2011, 06:27 PM
  3. Replies: 1
    Last Post: 03-20-2010, 04:57 PM
  4. 5.1d and Bontrager Rhythm rim strip
    By Broccoli in forum Wheels and Tires
    Last Post: 10-13-2009, 11:06 AM
  5. Bontrager Rhythm Comp tubeless
    By robbakersc in forum 29er Bikes
    Last Post: 05-10-2008, 05:17 AM
