Results 1 to 2 of 2
    Stand-up philosopher
    Reputation: drwx's Avatar
    Tubeless question
    Last fall, I converted my wtb laser disc trails to tubeless using a stans conversion kit. My tires are 26" maxxis ignitor exo. When I did the conversion, I did the insulation tape in the channel, per everything I've read about converting these rims.
    When I deflate the tires to check the stans for boogers, they immediately pop off the bead and into the channel. Shouldn't they be staying attached to the bead? If so, I'm wondering if I need to do another wrap or two of insulation. Other than this, they hold air burps. I lose around 5 psi over the course of a week and then no more.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    no one can appreciate the poor misunderstood
    The tires should ideally stay attached to the bead. But since you are not actually using a tubeless rim, the tire will unseat itself when deflated. This has to do entirely with the bead shape of the rim, and no amount of tape you put on will fix it. It's just something you'll have to live with unless you want to buy a proper tubeless rim.
  1. Tubeless question from tubeless newb
    By johnb in forum Wheels and Tires
    Last Post: 05-13-2013, 11:25 AM
  2. Tubeless question
    By xxxxx in forum Salsa
    Last Post: 11-21-2012, 09:11 PM
  3. Tubeless Question
    By CrozCountry in forum Wheels and Tires
    Last Post: 08-17-2011, 07:10 AM
  4. Tubeless question
    By jmallory in forum Wheels and Tires
    Last Post: 07-26-2011, 11:34 AM
  5. Tubeless Question? Help!!!
    By Utilityman in forum Wheels and Tires
    Last Post: 06-07-2011, 04:02 PM
