Results 1 to 15 of 15
    Tubeless Pressure, Rider Weight, Tire Size - POLL
    Let's see your Tubeless tire pressure, your weight and wheel size comparisons. I'll start first.
    Terrain type, clay medium packed, sometimes muddy
    20psi F/R, 148lbs fully equipped, 29x2.25 nobby nics
    Reputation: Joel RW's Avatar
    25 psi front, 27 psi rear, 175lbs, 26 and 29 x2.25 maxxis ardent UST.
    I'm Increasing my rear pressure to just above 30 because I've been pinching the side wall on jump landings. I started at 22 psi and I've been slowly increasing each time I pinch the walls. Happened a few times so far on different rims too.
    Pivot mach 6!
    Reputation: gmats's Avatar
    Apr 2005
    My pressures vary a lot depending on the type of riding I do. I'm about 145 lb. Ride Turner 5 spot with 26" rear and 650B front. Oh, almost forgot. Tire size is 26X2.3 rear and 650BX2.3 front.
    Rooted, technical riding (up or down) - around 20 psi
    Long fire road climbing - 35 psi
    Descending on fire road stuff - maybe around 30 psi
    Smooth hard packed single track - 25-30 psi.
    Bottom line is I vary the tire pressures for the kind of riding I'll be doing. For me, I think of my bike as a 4x4 trail truck that you'd drive to the trails, do some rock crawling or trail running, see what you can accomplish. Then at the end of the day, air up the tire and drive it home again. Sometimes the truck breaks, fix it so that it can be driven home again.
    Great poll, will be interesting to see what others put down.
    Former Bike Wrench
    Specialized Purgatory 29" x 2.2" 2Bliss
    Current weight 210 lbs
    Silty Loam to Silty Clay Loam riding surface, wet in the winter, many logs and roots, a few rocks
    26-28 psi
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    29er
    205 lbs.
    rigid ss, 23mm rims with Geax TNT 2.2 tires
    21psi f/r
    FS, 21mm rims with Schwalbe EVO 2.25 tires
    27psi f, 29 psi r
    terrain: rocks, gravel over hardpack, more rocks (embeded limestone)
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Reputation: speed metal's Avatar
    I just my first set of tubeless wheels and tires. This thread has been helpful.
    Comas aren't as fun as riding your bike, so wear a Helmet.
    220. High rocky mountains terrain. RR 29"-2.25f. 24psi. Ardent 2.25r 29psi. Both for rigid SS SPEED. Other is FS. ingnitor 29" 2.1 30psi and geax suagro 2.2 34psi.
    High Ho Sultan, Lets GO
    kamikaze quotes czarface
    Reputation: silentG's Avatar
    Front 24 psi, rear 25-27 psi on Mavic XM819 with WTB Prowler MX 2.3 UST
    I'm 200 lbs fully geared up.
    Terrain is northern AZ (Prescott) - loose over hardpack (mostly granite), rocks (vary from small to large), dirt. Very dry and dusty.
    Also hit lower desert this time of year with same pressures - loose over hardpack and sandy, not as rocky.
    210lbs
    28 front WTB 2.3 Stout
    30 rear Kenda 2.2 Slant Six
    SF Bay Area
    Reputation: ihaveagibsonsg's Avatar
    140lbs
    29er
    F: 2,4Ardent 18 PSI
    R: 2.3 Exiwolf 22 PSI
    Terrain: Rocky/hardpack
    215 pounds, schwalbe fat albert front, albert rear on Mavic 819 rims. 28 front and 30 rear in the bay area, bump it up a couple of pounds for Downieville and Tahoe with all the sharp rocks.
    Riding slowly since 1977.
    Reputation: k2rider1964's Avatar
    200 lbs geared up on a FS 29er
    Ride everywhere I can in SoCal and SW Utah mostly, XC and lite AM type stuff at high speed
    Rotate around between Geax Sagauros and Panaracer CG....always 26-28 psi
    COTA member
    Reputation: Dry Side's Avatar
    24 psi F/R, 165 lbs, 29x2.2 Geax AKA on Enve XC UST rims.
    Lightly salted
    Reputation: fuenstock's Avatar
    I have only a few rides on some new Hans Dampfs, so far running front 26psi, rear 28psi.
    OriginalDonk
    Reputation: OriginalDonk's Avatar
    25F/28R Maxxis Ikon EXOs on 29er Crest rims. 170 lbs. riding a 29er hardtail on primarily loose over hardpack interspersed with some rough off camber granite sections.
