Tubeless - Panaracer T-Serv Protex Road Tire Black, 26X1.75
Think I could get this tire set up ghetto tubeless on mavic 317 rims using gorila tape? I have had two flat tubes on these tires on two rides...
Mavic 317, with gorilla tape and stans...
Thanks,
David
I wouldn't run it over 40psi...
I was wondering that actually. Stans says not to exceed a certain PSI. Is that why you mention it, or are you thinking it will blow off the rim?
Thanks,
David
Thanks,
David
Blow off the rim...which would suck even more on asphalt with cars around
Thanks, I just put another tube in it :-)
- You may not post replies
- You may not edit your posts
Forum Rules
