Results 1 to 8 of 8
    Dec 2012
    Tubeless - Leak by valve - will adding stan's fix it?
    I have a small leak coming from the valve of my tire. It is a new leak, was able to ride about 50 miles on it before this happened. Will adding Stan's sealant fix it, or do I need to retape and re-add sealant.
    Generally speaking you would want to try to tighten the valve or possibly even uninstall and reinstall it to try to get it to seat better. With that being said, I have a couple hundred miles in on a recent tire bead that I was able to seal with Stan's.
    Dec 2012
    Re: Tubeless - Leak by valve - will adding stan's fix it?
    somehow the leak that began in its own (sprung overnight), was fixed on its own. guess stan's works?
    Nor­wegr
    Reputation: Vegard's Avatar
    Indeed it does, chances are you'll find a blob of stans around the valve next time you have the tire off. I usually put a drop of loctite on the outside nut before tightening it, granted use one that isn't permanent
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    My leaky valve problems usually appear immediately. What I do now is apply a dab of rubber cement or silicone sealant to the rubber in the valve before inserting it, then torque the valve nut as hard as I can by hand to make sure it is airtight. Then mount tire, squirt sealant thru the valve, pump and seat. This cures valve leaking for me for as long as the tire stays on the wheel.
    Old enough to know better and old enough not to care. Best age to be.
    Old enough to know better. And old enough not to care. Best age to be.
    Dec 2012
    it is my opinion that the rubber on the valve needs to be a little bigger to ensure a tight, sealed fit around the valve hole
    dwt
    dwt is offline
    Quote Originally Posted by sinfony78 View Post
    Indeed. You can buy 2 Stan's valves @ $16.00/pair and the rubber on the valve is tiny.
    Tubeless - Leak by valve - will adding stan's fix it?-imageuploadedbytapatalk1367277574.635901.jpg
    Meanwhile, you can buy Q-tubes with presta valve & removable core @ $5.04/ea. and cut the valves off with as much rubber as you deem necessary.
    http://m.jensonusa.com/Q-Tubes-Presta-Valve-Tube
    Jan 2013
    Yep, it's gotta
  1. Replies: 3
    Last Post: 12-02-2012, 12:06 PM
  2. Valve stem leak
    By ryguy135 in forum 29er Bikes
    Last Post: 08-22-2012, 10:45 PM
  3. Tubeless conversion valve stem leak. Any help?
    By wallyh3 in forum Wheels and Tires
    Last Post: 08-22-2012, 02:56 PM
  4. Bontrager Rhythm Elite 29er TLR Valve Stem Leak
    By dshack in forum Wheels and Tires
    Last Post: 05-01-2012, 04:40 PM
  5. Tubeless leak around valve stem
    Last Post: 06-25-2011, 09:34 AM
