Results 1 to 5 of 5
    Caution;  Merge;  Workers Ahead! Tubeless Conversion FSA300- does the tires have to be tubeless? or nontubeless work?
    I did a search and didnt quite find an answer.
    I have a set of FSAXC300 and just purhcased Stans Rim Strips.
    Now I am deciding on what tires to get. Does it matter of the tire is Tubeless or not tubeless? Shouldnt the sealand seal either up?
    ALso for the owners with these with tubeless. what tires are you guys using, and how do u like?
    I converted those wheels with kenda's small block 8's, NON tubeless, held air great, than installled a maxxis larsen TT, non tubeles also, so it's up to you what tire to buy..
    oo ok.. how did either of those tires hold up for you?
    They work pretty good for the conditions they are designed for... right now i have a SB8 in the rear and a maxxis monorail up front, i really like the monorail..
    Zak
    Zak is offline
    Discernibly Turgid
    I set my girlfriend's up ghetto tubeless with 20" presta tubes and non UST nevegal 2.1 front, karma L3R 1.9 rear. Went together easy with a a compressor and stans. Working well for the past month or so.
