Results 1 to 16 of 16
    May 2018
    Trying to improve on Ardent 2.4 / Ikon 2.2 combo for XC
    I ride longer (25-35 miles) XC with lots of solid rock, loose rock, crushed rock, loose over hard. My bike is a Yeti 4.5. Wheels: Ibis 935s / 29mm internal.
    Front Tire:
    I tried Forekasters 2.35 front and Ikon 2.2s back -- and could scream up hills and straight rollers; however, at the turns, it got really sketchy. I'd end up riding my brakes or outright having the bike come out from under me in turns. There's such little confidence in my mind riding them yet I LOVE the light feel, speed, and great acceleration.
    Switched the front tire to an Ardent 2.4 and could stay fully off the brakes. I pushed turns as hard as I know how and they just stuck hard. However, I feel the extra weight and/or rolling resistance on longer XCs. Climbing, acceleration, straightaway speed suffers. If I was only doing 10-15 mile rides for speed or just riding for fun, it'd be an acceptable tradeoff. However, on the longer XC stuff for speed, I sure feel the constant weight and resistance.
    So, for the front, is there something that is light and rolls like the Forekasters (mid 700s) yet grips like the Ardent 2.4 in the loose stuff and turns -- and would be a good fit on a 29mm wheel?
    Rear Tire:
    On the rear, I have no complaints with the Ikons except the flats. They grip way better than I'd guess from just looking at the tread; rarely slip unless I am out of the saddle and pulsing a climb. But flats have been a problem. I've had 3 in 150 miles -- with the latest today slicing the sidewall past repair. I love the low weight, low rolling resistance, and ample grip.
    Any suggestions for a good, light XC tire on the rear around the weight of the Ikon (mid 500s) with more flat protection?
    I greatly appreciate any suggestions anyone may have. I look forward to getting some suggestions, ordering a few tires, and giving it a whirl.
    Oct 2014
    I've been in a similar boat to you. I'm currently running an Ikon out back, and a Ardent Race up front. For my trails I get way better grip out of the Ardent Race than I did with the standard Ardent. That being said... I do want a good front tire that is a bit more aggressive than the AR.
    There are a lot of good words going around about Vittoria tires at the moment. My next set of rubber will be a Barzo up front, and most likely a mezcal out back. I saw some pros runnin this setup at the Snake Creek Gap time trials this year, and it's had my attention since then. Seems like a fast rolling setup with good traction and puncture resistance.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    You aren't going to get a mid 500s rear tire with more flat protection. It. Does. Not. Exist.
    You're riding an XC tire on non-XC terrain. You're going to have to nut up and pay the grams for reliability.
    May 2018
    Thanks for the response. It's amazing to me to look at the Forekaster and Ardent side by side, mounted. They look so close; however, the Forekaster spins up and rolls so much better yet slips so much worse than the Ardent. I would think the feel wouldn't be so dramatic based on the look being so close -- but they certainly are.
    I'll look into Vittoria and the Ardent Race. The plain Ardent has plenty of grip for me; if the AR has even more, I'd be fine.
    A few of the Cat1 XC guys that ride these same trails swear by the Continental X-Kings 2.4 up front. One guy won the State XC championship on them up front, Ikons on the back -- and that course is tougher on tires than where I ride. Still, I read horrible reviews on the X-Kings, yet they still swear by them and say they offer really good sidewall protection plus really grip in the loose stuff / corners. May get one just to try... Can find them online as low as $35.
    Appreciate the input... Will post back any improvements found.
    Barely in control
    Feb 2007
    They just updated the Cross King. The Barzo is a similar tire.
    I have had the forekaster for about a year.
    It is highly sensitive to pressure, and it needs to be run a little soft.
    Sent from my Moto G (5) Plus using Tapatalk
    Reputation: Porkchop_Power's Avatar
    Not sure how you are feeling the Forekaster is a worse gripping tire then the Ardent. As the above post said you need to run it soft, up front at 18-20 lbs for a 190-200lb rider works well. I run it on the rear also but have moved to a 2.6 REKON up front which just destroys the super loose gravel and sand we have out here. Still have a Forekaster in the rear which works well. Almost anyone (including myself) will tell you Ardents just don't have the cornering grip since the side nobs are too narrow.
    Jan 2018
    I've been running the Mezcals front and rear. They do roll really nice and dry grip is ok, but grip on wet roots and rock is sketchy. It feels more like a rubber compound issue than a tread design, and I've had quite a few Conti's with the black chili which gripped much better even when completely worn out. I'm just having trouble deciding which Conti's to go with as they've changed their whole line up. Mid 700's is as heavy as I'd like to go, so it looks like the new Mountain King or X King. Leaning toward the Moutain King but I fear that it looks to be a slow roller.
    May 2018
    Quote Originally Posted by Porkchop_Power View Post
    Not sure how you are feeling the Forekaster is a worse gripping tire then the Ardent. I run it on the rear also but have moved to a 2.6 REKON up front which just destroys the super loose gravel and sand we have out here. Still have a Forekaster in the rear which works well. Almost anyone (including myself) will tell you Ardents just don't have the cornering grip since the side nobs are too narrow.
    I hear you and have heard the Ardent not gripping hard. But it latched-on for me much more than the Forekaster. I did what you you said and dropped the Forekaster from 22 to 17 and there was a noticable improvement.
    The 2.6 Rekons are interesting. That's a pretty low weight on a tire that big. Will put it on the list of what ot try. Thanks for the input.
    May 2018
    Quote Originally Posted by hellion View Post
    I've been running the Mezcals front and rear... and I've had quite a few Conti's with the black chili which gripped much better even when completely worn out. I'm just having trouble deciding which Conti's to go with as they've changed their whole line up. Mid 700's is as heavy as I'd like to go, so it looks like the new Mountain King or X King. Leaning toward the Moutain King but I fear that it looks to be a slow roller.
    I'm with you. I've ordered a 2.35 X-King for up front, 2.2 in the back. Also bought at 2.3 Mountain King as well -- to swap with the 2.35 X-King and see if there's any noticeable change.
    My rough plan after trying out the X-Kings and Mountain King:
    * Minon SS 2.3, 795g. Looks like a mix between the Ikon and Minon.
    * Rekon 2.6 as someone here suggested. 780g on a 2.6 tire is interesting
    * Vittoria Barzo 2.35 when it becomes available
    * Vittoria Mezcal as you suggested
    * Maybe Schwalbe Fat Alberts at 780g...
    * Schwalbe Nobby Nic
    Sure appreciate the input. Thanks.
    Reputation: MSU Alum's Avatar
    It would be great if you could report back on the durability and width of the 29x2.4 nexgen CrossKing. My experience has been horrible regarding durability, but they were blazingly fast on the previous model.
    I feel like about any tire I run grips reasonably well after you find the right pressure, and that is very rider weight & style, suspension set up, rim width, and terrain dependent. But here in NE I have had excellent luck with 2.35 Ikons F&R, 2.35 AR front W/ 2.35 Ikon out back, 2.35 Rocket Rons, 2.25 Mezcal G+ (in all but leaves!), and currently on the new Specialized Fast Track 2.3 (I am really liking this tire, but have to run it a little higher PSI than others).
    My favorite all around XC tire (again in Maine with LOTS of roots and rocks) is 2.35 Ikons F&R
    One thing I noticed with my Ikon 2.2 rear on a i29 rim is the profile almost seemed a little stretched where there was tons of sidewall showing. Sure enough I sliced it after maybe 150-200 miles.
    Just put on a Ikon 2.35 in the rear to go with my Ardent Race 2.35 front. Iím hoping thereís a little more protection with this tire profile on a i29.
    Like the OP, I like running XC tires on my hardtail on ďenduroĒ trails. Really XC in my book but the sharp rocks donít help. If this doesnít work Iím really looking at the Bontrager XR2ís. Bontrager sidewalls (XR3 at least) have always served me well but I like the Maxxis Grip better.
    My previous setup before the Ardent Race / Ikon was Schwalbe HD / NN. Thatís a heavier setup than Iíd like, but bulletproof for me.
    May 2018
    First feedback:
    I put on Continental Cross King Protections (Black Chili / 2018) front and back today. 2.35 front @ 20, 2.20 back @ 22. Way more grip than I'd have expected. I could push corners hard and stay off the brakes. But what surprised me most was the rolling and climbing ability. They look like they'd have a good bit of resistance, but they rolled and climbed better than the Forekaster 2.35 / Ikon 2.2 combo despite being heavier. Extremely good feel.
    I also recieved a Continental Mountain King incase the Cross Kings didn't grip enough, but I really don't think they will be needed. Very likely will send them back.
    My only nit-pick: When I went over a few damp areas the grip went from great to nothing in a flash. However, other than some morning dew, I don't ride in muddy conditions due to the damage it does to the trails. Acceptable tradeoff for me.
    Will keep them on the bike and see how long they can last without flats. If I can get anything even close to reasonable (>300 miles) without a flat, I'm going to leave well enough alone and just stick with them.
    FWIW -- this is trail I rode with them -- trail/tech XC -- little bit of everything but the loose rock on sweeping turns is what I was worried about -- and the Cross Kings did wonderfully. Certainly not easy on tires.
    https://www.mtbproject.com/trail/702...-complete-ride
    May 2018
    Quote Originally Posted by Marty McCasland View Post
    First feedback:
    This was the setup I had on my felt edict for my first season which it. I loved everything about it for my dry conditions here in Utah. The durability was not great, though I never had a flat. Hopefully, the new ones are better in the durability dept. I have since added a new x King up front and added a mountain king in the back, which Iím not as keen on as having both x kings.
    May 2018
    Quote Originally Posted by Dromos123 View Post
    Thanks for that feedback. I was wondering if the Mountain King on the back would do anything. I can return it with confidence and just keep both Cross Kings front and back.
    I felt the Ikon on the back performed better in term of grip, but 3 flats in 150 miles was just too low reliability for me. As someone said, hard to expect much durability at 550g. Hopefully the Cross Kings in the mid 750s will be better.
    Take care,
    -mm
  1. Ardent 2.4 front ikon 2.35 rear? Ardent race 2.35 rear??
    By Hbnel5on in forum Wheels and Tires
    Last Post: 04-04-2017, 07:58 AM
  2. "rolling resistance". Maxxis Ardent vs Racing Ralph vs IKON
    By trhoppe in forum XC Racing and Training
    Last Post: 05-02-2014, 04:36 PM
  3. Replies: 20
    Last Post: 02-22-2014, 06:16 PM
  4. Tire with strong sidewalls: Ikon, Captain, Ground Control or Ardent
    By TurnerConvert in forum Wheels and Tires
    Last Post: 05-06-2013, 11:01 PM
  5. Replies: 5
    Last Post: 04-22-2013, 01:09 PM
Members who have read this thread: 129
