Results 1 to 3 of 3
    True Precision STEALTH Hub ?
    So I found only bits and peices floating around about these hubs. I have been on quite a few high POE hubs over the season's but none of which were silent. My current Halo Supa Drives are quite noisy and maybe its time to go the quiet route. Any long term duarability reviews or thoughts on the Stealth's ? Thanks.
    Former Bike Wrench
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I have used one on one of my bikes for about a year (bought it used and built on a EX823). Only problem is that the bearing preload may get out of adjustment occasionally, resulting in excessive drag. Once I readjust (which is easy), it is fine. Not certain if it is a problem or not, since it still may be breaking in after I initially cleaned and lubed. I am used to this though since I mainly use Chris King hubs, with require adjustments during break in.
    Other than that, as advertised. No sound and instant engagement. And True Precision folks are very helpful.
    Seems the TP hubs had some problems in the early 2000's, so I may be cautious of those.
  1. True Precision Stealth Poacher Hub
    By cndoane in forum General Discussion
    Last Post: 08-20-2009, 11:16 AM
  2. True Precision Stealth Poacher Hub
    By cndoane in forum Texas
    Last Post: 08-13-2009, 11:24 AM
  3. True Precision Stealth hub, QR conversion?
    By timms in forum Wheels and Tires
    Last Post: 02-18-2008, 12:38 AM
  4. True Precision Stealth cassette hub: availability
    By El Caballo in forum Wheels and Tires
    Last Post: 09-18-2006, 12:08 PM
  5. True Precision Stealth SS Poacher Hub, yep, I rode it...
    By red-haze.com in forum Singlespeed
    Last Post: 08-12-2004, 07:12 PM
