Results 1 to 10 of 10
    Tires for Sun Rhyno Lite Rims
    Anyone have recommendations for general XC tires for the Sun Rhyno Lite rims? Mounting most tires on these rims seems nearly impossible - I've managed to mount Panaracer XC Fire Pros with my bare hands, but any other tires (i.e. Kendas) are impossible to mount, even with my Park TL-10 shop-rated tire lever tool. The rim's shallow profile seems to be the root cause for difficult mounting...
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by kzoo_cyclist
    Use a thin rim tape. Fiber reinforced packing tape is my favorite. This helps more than anything else.
    Generally avoid Ritchey tires. I have had no real issues with most others, but it can vary from model to model.
    mtbtires.com
    Former Bike Wrench
    Rhyno Lites are notorious for being difficult to mount tires. For starters, if your using cloth rim tape (like Velox) remove it and use 1/2" strapping tape. This will give you a little more room for mounting tires. Besides that, the best tool I've used over the years for difficult tires is the Kool Stop Tire Jack.
    one chain, two sprockets
    What about Continental tires? Same fit issue?
    LBS has some welded Rhyno Lites and a few MTX's for cheap. Should I just get the MTX's to avoid the rim-fit issue?
    Tom P.
    Former Bike Wrench
    Quote Originally Posted by one piece crank
    Tom P.
    The MTX is a 33mm wide full fledged DH rim...what type of riding do you intend to do?
    Sorry for the confuson - I typed MTX, but I meant to type Singletrack!
    Will either/both Rhyno Lite or Singletrack have the tire-fit issue?
    Tom P.
    Dec 1998
    Tom P.
    Singletracks (which are also a DH rim) are easy to mount tires on.
    mtbtires.com
    Former Bike Wrench
    Tom P.
    Singletrack is wider and a tad heavier (~40 grams) than the Rhynolite but lighter and narrower than the MTX...kind of falls in between the two. As Shiggy mentioned, it is much easier to mount tires on than the Rhynolite.
    ok, is there any advantage to the Rhyno Lite over the SIngletrack?
    This is going on a SS play bike do-it-all:
    - 32-hole wheel + 2.4" tire
    - light freeride, skatepark, rocky technical singletrack
    I have a set of DH wheels, so I do no what anythng heavier-duty than the Rhyno Lite or SIngletrack.
    Tom P.
    Former Bike Wrench
    Tom P.
    Rhyno Lite...40 grams less and you can run V-brakes on them
    Singletrack...mounting, changing, and fixing tires/flats doesn't contribute to your overall stress in life
