Results 1 to 3 of 3
    New question here. Tire wobble, Rim true?
    Had my rear tire burp on me yesterday coming around a corner (Hope to never have that happen again it was quite disconcerting). The tire seated back up, I put some air in it and didn't think anything about it. Today however I noticed a pretty decent tire wobble. Removed the tire and the rim is true. Reinstalled the tire pumped up to 60psi to seat and its still there. Any ideas? If it matter Im running Bontrager Rhytmn comp wheels, with High roller 2 exos. Up to yesterday they've been flawless.
    Reputation: J.B. Weld's Avatar
    It sounds like either the tire isn't seated correctly or the casing is broken. Most tires have a line right above the rim sidewall, if you spin the wheel and look at this line it should be even all the way around. If it is high or low anywhere then the tire is not seated on the rim right, if it is even then the tire casing is bad.
    Reputation: MSU Alum's Avatar
    Yup...^^^^^
  1. wheel is true but tire is not
    By ddprocter in forum Wheels and Tires
    Last Post: 03-02-2012, 11:06 AM
  2. New tire wobble with inner tube
    By BigEarn86 in forum Wheels and Tires
    Last Post: 02-16-2012, 08:58 AM
  3. Tire rubbing chainstay, rim true...
    By thrasher_s in forum Wheels and Tires
    Last Post: 10-28-2011, 12:40 PM
  4. Flats on a true UST tire
    By ptfmb71 in forum Endurance XC Racing
    Last Post: 04-08-2011, 08:24 AM
  5. Tire out of true!?
    By butasan in forum Wheels and Tires
    Last Post: 03-17-2011, 10:46 AM
