Results 1 to 11 of 11
    Reputation: Smilerz's Avatar
    Tire pressure question
    I'm running tubeless front and back. Do you vary the pressure in the tires, meaning do you run a higher pressure in the rear to help with climbing, and run a lower pressure in the front to help with gripping in the corners and handling?
    Reputation: Lone Rager's Avatar
    Dec 2013
    I run lower in the front because there's generally less weight on it and I'm better at lifting the front wheel over obstacles than I am lifting the rear.
    Do the math.
    Yeah, I'm that a$$hole.
    Reputation: Guy.Ford's Avatar
    Yes
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Me too!
    Bikesexual
    Reputation: jcd46's Avatar
    Quote Originally Posted by noapathy View Post
    #Metoo!
    Fify.
    Sent from my LGMS210 using Tapatalk
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
    Jan 2014
    Quote Originally Posted by Smilerz View Post
    Yes, but not for the reason you called out.
    Your weight is going to be more over the rear tire than the front.
    So you end up needed more pressure in the rear than the front.
    You'll find this experimentally too, the pressure that stops bottoming out the rim hard tends to be higher in the rear tire for most people.
    And the pressure that stops the tire from squirming in corners tends to be higher in the rear.
    To figure out my pressures I either increase my pressures until I stop bottoming out or squirming or decrease my pressures until these two things happen then go back up a little bit.
    Reputation: sturge's Avatar
    Lots of variables but I prefer rear to be slightly higher pressure than front. Only a couple of psi difference for me (20-22 rear / 18-20 front). Primarily because my riding technique and terrain is best ridden with center of gravity being more toward the rear than the front. For what it's worth, I've found climbing is better with as low a pressure as possible on rear (wider footprint = better traction on rocks/roots).
    That being said, there is a fine line between just right and too low a pressure where the tire begins to loose stability side to side. Everyone is different...you need to find what combination works best for you.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    I run 30psi rear, 20 front. Im more likely to smash my rear rim. That's about as low as I can go on both sides without ruining stuff.
    Quote Originally Posted by jcd46 View Post
    Fify.
    I haven't felt that kind of pressure from my tires, thankfully.
    Bikesexual
    Well played
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
    Quote Originally Posted by One Pivot View Post
    Thank you. I tried this as a starting point and it felt good.
  1. Replies: 23
    Last Post: 02-25-2016, 10:48 AM
  2. Replies: 16
    Last Post: 05-21-2015, 07:42 PM
  3. Tire/Tire pressure question
    By Mr. 68 Hundred in forum Downhill - Freeride
    Last Post: 06-24-2014, 10:26 AM
  4. Tyre Pressure & Front Suspension Pressure on 2009 Badboy
    By fumi in forum General Discussion
    Last Post: 07-05-2013, 10:30 AM
  5. Tire pressure, tire, and trail question.
    By mdutcher in forum 29er Bikes
    Last Post: 10-25-2004, 01:58 PM
Members who have read this thread: 92
