Page 5 of 5 FirstFirst 12345
Results 401 to 493 of 493
  1. #401
    Sep 2014
    Tire pressure for all around XC riding?
    Quote Originally Posted by XTERRAGreg View Post
    Guess i have been on road/TT bikes too long... I still have a "mental" issue going below 30psi on my tubeless setup.. All I can think about is rolling resistance.
    Doesn't increasing the pressure increase the rolling resistance? Since when you hit an imperfect part in the road it forces the tire to push up into the bike instead of the tire conforming to the road.
    Am I wrong?
  2. #402
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by Givmedew View Post
    Am I wrong?
    you are correct.
    I run TT on road and there is one 10 miler upstate NY which is fresh paved and almost zero road imperfections (occasional cow pies that is it) I run >180psi on that road and get my best TT times. if I run these boneshakers anywhere else where there are cracks it not only annoys me but does seem to slow me down, so I use 120psi everywhere else
    there is always sweet spot between: too low pressure and obvious wasted effort, a conforming and optimal pressure for the road/trail conditions, and high pressure where bouncing and deflection robs you of forward watts
  3. #403
    Jun 2014
    and of course in mountain biking correct tire pressure can often be the difference between riding and walking. too high or too low can cause this to happen but especially in technical singletrack lower pressure can be a huge benefit
  4. #404
    Sep 2014
    Well anyways... I am from the road world and just got into MTBs. So today I was riding and my bike was set to 30 front and 25 rear. My friend knowing I was a newb to MTBs said my pressure was to low and inflated my tires to 45/40
    I didnt want to argue and tell someone that rides 10 times a week for the last 20 years that he was wrong.
    So I just let him do it.
    Anyways
    Was he right since maybe he knew more about the track than me?
    It was mostly dry and very packed dirt/clay. Smooth and hard with a few nasty mud pudals in the low areas. There where some tree roots that you hit hard and some come at the tire from the side.
    What if anything did I gain from increasing the tire pressure that high and what did I loose?
  5. #405
    Reputation: CrozCountry's Avatar
    Mar 2011
    Anyways
    First, 30 front and 25 rear is the opposite of what you should have, rear takes more pressure normally.
    What you get with higher pressure is pinch flat resistance, better rim protection and stability in turns.
    What you loose is traction mostly. Especially over sideways impacts, the tire will bounce to the side instead of deflecting around the side impact.
  6. #406
    Sep 2014
    Quote Originally Posted by CrozCountry View Post
    I just assumed that having front suspension meant it was ok to have a higher front pressure. The bike is a hard tail.
    I am running tubeless and pinch flat is tubes right?
    Also I do weigh 210LBs if that matter and tend to keep my but on the seat most of time.
    Is 25LBs too low? Should I actually be running a higher pressure in the rear than the front?
  7. #407
    old fart
    Anyways
    He was wrong.
    By having less pressure in the tyre, you increase the contact patch which means more traction & braking (longitudinal force) and cornering (sideways force). This is ALWAYS true (simple physics).
    However, once you get tyre pressure too low you suffer 2 consequences - one that everyone talks about, and the 2nd one that most don't. The first one is pinch-flats - these CAN be an issue but not if you run tubeless - then you might get a "burp" when the sidewall loses sealing. The 2nd consequence is loss of cornering precision, particularly if the front is too low. A squirmy front end doesn't help XC speed.
    I weight 90kgs and run front and rear between 25 to 30 psi depending on the conditions. Looser, then I go lower, harder then higher.
  8. #408
    Heavylegs
    Givmedew, just use what feels right. There is no magic numbers to chase. Each tire response is different and each riders riding stye is different. I do ride with the front tire inflated about 5 lbs more somtimes because it just works for me. If your buddy is a good rider and has been riding for twenty years then as a beginner that a great place to start. I hope your liking the dirt side on two wheels.
  9. #409
    Sep 2014
    Quote Originally Posted by redd4573 View Post
    There is no way I am going to be able to judge what feels right the first time on the bike. The tires recommendation is very broad.
    To my friend riding for 20 years...
    He doesn't pretend to be a pro. But I know people who have done things their whole lives the wrong way. I am a very technically minded person and am always mindful of every little thing.
    The tire recommends up to 65 pounds. I reading people running as low as 20LBs. When I went on a demo ride of a RIP 9 NINER a few months back someone on the ride with a tubeless had exactly what someone was describing where suddenly the tire went completely flat.
    Just trying to wrap my head around an entirely new world for me.
    Going off my butt dyno isn't going to work the first ride or even the first year of riding.
  10. #410
    Lone Wolf
    Reputation: Osco's Avatar
    Apr 2013
    Cool-blue Rhythm
    After reading all this I dropped from 30 psi front and rear to
    28 rear
    26 front
    No pinches, less root skipping and a bit more side bite in the smooth stuff.
    Running Rocket Ron's 27.5 and full suspension.
    I'm 185 with 100 oz's of water and gear in my Camelbak volt and ride gear, bike Is at 30 pounds :P
  11. #411
    Jun 2014
    Quote Originally Posted by Osco View Post
    28 rear
    26 front
    I run that pressure and I'm 210 and on a 29er HT. High volume tires though, 2.3"+and tubeless
  12. #412
    Reputation: nauc's Avatar
    I run my tires so that they bulge a little bit when I look straight down at them, while on my seat. Seems to work so far
  13. #413
    Armature speller
    Sep 2004
    Re: Tire pressure for all around XC riding?
    Quote Originally Posted by nauc View Post
    I run my stomach that way too...
  14. #414
    Feb 2014
    just to add ....... since I perfectly dialed it all in.
    I ride a TREK EX7, I weigh 155 w/ all my gear
    Tubeless Setup - 29er
    Hans dampf Front - 18 psi (2.35)
    Nobby Nic Rear - 20 psi (2.25)
    Works flawless and I ride a lot of XC and do some fairly steep climbs and FAST downhill trail runs (no boulders).
  15. #415
    EAT MORE GRIME
    Nov 2013
    tire pressures mean nothing unless you post complete tire size
    a 26 inch 1.9 35psi feels the same as a 27.5 2.4 at 25 psi as far as firmness and
    bounce on trail (to me anyway)
    so, all these pressures in this thread, if there is not the fatness of tire listed it is not that informative.
    vredestein black panther extreme TLR 27.5 2.2 inch 25psi feels about right for XC chunder
  16. #416
    Armature speller
    Sep 2004
    Quote Originally Posted by 127.0.0.1 View Post
    Also the width of the rim and whether tubed or tubeless...
  17. #417
    On your left.
    17-20psi in my NobbyNic 2.35s on Derby 29er rims. Tubeless. Hardtail in the Alps. I weigh 185lb.
    M
  18. #418
    I run tubeless 27.5 with 2.3 High Roller II tires on ENVE AM rims...For long climbs or flat xc riding I usually air up to about 35psi rear and 32psi front.
    For long descents I air down to about 28-25psi in the front and about 30psi in the rear. Anything less and the tires start to get squirmy in turns.
    I have gotten snake bites in the actual sidewall of tubeless tires when running to low of air pressure and start banging rims on rocks. Don't know how people running 20 psi in the rear tire don't thrash their tires and rims, maybe on buff single track thats ok.
    When airing down the tires at the top after a long climb I do the squeeze test on the tire and go by feel.
    Pressure depends on your tires, bike setup, riding style, personal preference, and terrain. There is no right or wrong answer. Play around with different pressures and find whats right for you.
  19. #419
    Jan 2013
    In praise of higher tire pressure - I ran 40 psi (highest safe pressure on Stan's rims per Stan's) just because I was too lazy to tune the pressure after doing a road ride with my son.
    With the trails dried out -- WOW! Yes, I gave up some traction, and, no, these are not technical trails besides some roots. What I gave up in straight line traction I made up for in fast turning on the tight corners built into these trails. So much fun and so responsive.
    It's not a setting I'd use all the time, but on trails I know with hard conditions, it was fun!
  20. #420
    almost there!
    Reputation: AJ541's Avatar
    Sep 2003
    I ride a 29er FS Trek Superfly on XC trails that have a few rocks and I run the pressure on front and back at around 22 to 30 psi with tubeless ready tires. 1.95 - 2.2 sized tires. Rarely go above 30 psi unless I plan on riding mainly on the road/paved path.
  21. #421
    Lone Wolf
    Apr 2013
    On my Scott Spark 27.5, I am 190 lbs In ride gear and a full pack.
    Rims are 24mm O.D. and I think 20mm I.D.
    I don't have sharp rocks but I got roots of all shapes n sizes.
    Running 2.25 Rocket Ron's tubed, at 28 rear 27 front I don't pinch.
    Any lower and I get squirmy In turns. Above 30 psi front or rear and I skip off things.
    I don't care to go tubeless but with wider rims I may
    I am wanting wider rims, say 30-35mm O.D.,, 25-30mm I.D.
    My Motocross background tells me wider rims are a smart mod.
    Just saying...
  22. #422
    Armature speller
    Sep 2004
    26x2.3 X-Kings on 18mm id rims (rigid single speed).
    20r/16f is good for the bumps, but as I found today, it's easier to (almost) roll a tyre at 16psi.
    21r/18f may be safer...
  23. #423
    while sitting on my bile, looking straight down at my tires, i let out enough air, so the tires bulge a little bit. no idea what psi it is, dont care
  24. #424
    Jun 2014
    You sir are hardcore, well played.
  25. #425
    Jan 2009
    When I got my MTB, the bike shop set the pressure at the recommended 50 psi (according to Continental's website) which was fine at the time given the local MTB trail was closed and I was limited to pavement the first few rides. However, I did notice once the trail opened up the back end felt a bit loose when I'd accelerate so I'll be dialing the pressure down. Don't want to get to the point where I pinch flat though, I ride my bike to the trails since I live so close and bringing a floor pump to play with tire pressure really isn't an option for me. Maybe start at 35/40 psi and go from there? I am running tubes, just starting MTB coming from road so I want to see how much I like this (so far so good) before I start laying out money for better wheels and going tubeless.
  26. #426
    All bike, all the time
    Reputation: BikeIntelligencer's Avatar
    MIT Formula
    An MIT professor assigned this issue to his class and they came up with the following formula, where x=rider weight, y=wheel size and z=tire width.
    x times y divided by z times .01 (1 percent)
    This assumes tubeless.
    So a rider weighing 185 riding 29er on 2.2 tires would run 24 psi.
    A rider weighing 210 riding a 27.5 bike on 2.35 tires would run 25 psi.
    A lightweight rider at 165 on a 26er and 2.1 tires could get by with around 20 psi.
    Note that this applies to overall riding, not strictly XC. It is a general rule of thumb as well, since the MIT team could not factor in such unquantifiable variables as riding style, surface type and rider intelligence, although they did suggest that the higher the IQ, the less applicable the formula is...
  27. #427
    Dec 2013
    Quote Originally Posted by BikeIntelligencer View Post
    Finally! I don't know how mountain bikers have gotten by all these years without a bunch of MIT students using a math model to tell them what tire pressures to run.
    All those brains and they ended up with a simple linear relationship? Boooo. If you're going to overcomplicate something you might as well do it right.
    Btw, what does this formula attempt to optimize? Rolling resistance? Traction? Feel?
    Because if you have a brain you know to ignore such a silly formula?
  28. #428
    Mar 2011
    I would expect MIT guys to know a simple fact that the pressure on the front and rear is different, so there should be two separate formulas for front and rear (just by another simple fact that there is more weight on the rear). Other formulas already account for that, so that's not exactly rocket science.
    How many students passed this class? Actually what class was it?
  29. #429
    Lone Wolf
    Apr 2013
    Cool-blue Rhythm
    Quote Originally Posted by Scottwax View Post
    This happens to many new riders I bet, bike shop going for lots of psi.
    I'd say a baseline starting point for a 200 pound rider including full gear on any 2.2" or up tire in 26, 27.5, 29er tubed and not riding really big hits in rock gardens should be 30 psi front and rear. Ride that for a whole day, carry TWO tubes, pump and tools.
    Next ride drop two psi at each end and see what you feel, ride that for two full rides, go by feel, handling.
    Too much air makes my bike feel disconnected, jittery, The back end skips off roots kicking the rear about some this way or that.
    I actually feel the front tire difference the most when dropping/leaning into a corner.
    I'm down to 26 psi front and rear now. No pinches, feels better.
    Now at this psi, the change in feel by dropping just one more pound of air was so profound I am ready to go tubeless...
    Still gonna carry a tube.
    “I seek only the Flow”,
    Climbing Is Supposed To Be Hard,
    Shut Up Legs :P
  30. #430
    Jun 2015
    About your tire pressure
    The pressure depends on some reason:
    1.your weight;2.the temperature 3.Stiffness and structure of your bike rims
    suggest no more than 40 PSI if everything is in normal.
  31. #431
    Sep 2014
    Yeh carry a tube even if your running tubeless. Or at least bring it with or make sure someone has a tube. I make sure someone in our group has a tube and co2 inflator or pump.
    I don't carry 2 unless I'm going far. If your going 10-20 miles from your car then sure 2 tubes for a group of 2-4 riders but if your only going to be 1-3 miles I would just make sure 1 tube is available. It doesn't matter what size it is either. If someone has a 26 w/ them that's enough.
    I've never had a tubeless fail but it does happen. If I did a century id cary 2 with and my own pump or atleast an adaptor for my shock pump.
  32. #432
    Sep 2012
    Funnily enough, I've been riding tubeless recently and it's scary to me just how low I've had to go to stop feeling like I'm being bounced around all over the place.
    Right now I'm running 20 up front and 24 on the rear.
  33. #433
    Armature speller
    Sep 2004
    My Hutchy Python's had a sweet spot around 24f/26r whereas the Mich Wild Rac'r Advanced Ultimates needed to be around 20f/22r for the same feel.
    The Hutchy's have great pedaling traction and a nice ride, the Miche's only downfall is cornering, braking and acceleration.
  34. #434
    Sep 2014
    Quote Originally Posted by NordieBoy View Post
    So your review on the wild racer would be
    Title: the tires didn't explode... Yet
    Pros: So these tires went fit onto a rim that they where supposed to fit. They have labels so you don't accidentally mix them up with a better tire. They are made from rubber.
    Cons: When turning the front washes out and the rear slides. When accelerating uphill the tire spins excessively. When braking the front locks up quick and the rear is mostly useless.
    If the purpose of these tires where to protect the rims from scratches while on the show room floor they NAILED IT 5-Stars!
  35. #435
    Armature speller
    Sep 2004
    The Wild Rac'r is light. Very light.
    Very good for trail braking into and around corners.
    At the speed I race at, it's actually a pretty good tyre.
  36. #436
    Sep 2014
    Lol good one
    Same back handed comment car and driver gave the rali art...
    Car sucks but once you get used to trail braking it then its kind of fun to drive in a pitch and catch kind of way. (Think that was close to their exact words)
  37. #437
    Reputation: BacDoc's Avatar
    I just got a set of 29 er Wild Race'r advanced Gum X 2.25 . Haven't had a chance to try them out but they look fast, wider than 2.25(compared to my Racing Ralph 2.25) and they feel very light.
    The main qualities I look for in a tire are - cornering, braking and acceleration, so your review has me concerned. I mean what else does a tire do if not these 3 important things?
    I guess rim protection is highly rated by some LOL!
  38. #438
    Armature speller
    Sep 2004
    Mine were the 26" Advanced Ultimate. Ultra light, but a sidewall cut means I have to run tubes which defeats the idea of a nice light, responsive tyre.
  39. #439
    Lone Wolf
    Apr 2013
    Cool-blue Rhythm
    Current setup,
    Scott Spark 760
    185 pounds in full ride gear.
    27.5 X 2.25 Rocket Ron out back, tubed 25 psi feels great, no pinches.
    a 500ish gram tire.
    27.5 X 2.35 Bonty XR-3 front, tubed at 23 psi,,, feels great, no snake bites yet
    a 700ish gram tire.
    Lower than this gives me a squirmy ride, lowest tested so far 23 rear, 21 front, tubed.
    Shut Up Legs :P
  40. #440
    Jun 2014
    Up until today I had always been old school and ran 2.0 to 2.1 tires. Today my 26x2.4(actual 2.33) maxxis ardents arrived and I have to say. I'm a high volume casing convert. I use them on the front at around 28psi and it was amazing what a difference it makes going over rocks and roots at speed. I have 2.1 Ignitors on the back and once they run out of tread in getting 2.2 or 2.3s. It makes such a difference. Now I see why people like high volume casing. It absorbs so much.
  41. #441
    Nov 2014
    65 kg rider, 13 kg bike, 27.5"×2.1" Kenda Kadres with tubes, 19/24 psi, no pinch flats yet, even survived a little drop.
  42. #442
    Jul 2015
    I weigh 160 lbs. Specialized Pitch 2015.
    Specialized FastTrack 650b, 2.0" tires front and back.
    Both at about 23 psi. Ride mostly xc trails. So far no flats after several months.
  43. #443
    Dec 2015
    How low pressure could I possibly go?
    I weigh 115 pounds and my bike weighs around 30.
    I'm running continental 26x2.2" tires tubeless W/ Stan's on my hardtail that has an 80mm fork.
  44. #444
    Reputation: noose's Avatar
    Quote Originally Posted by shiggy View Post
    Well said!
    Indeed! Terrific advice!
  45. #445
    20/22 front rear on stock tires and tubes. Want to run lower but getting some rollover squirm. Maybe tubeless next?
    2015 Giant Trance 3
    X-Fusion Sweep RL2 160mm fork
    Straitline Defacto pedals
    Renthal Fatbar with TV 40mm stem
    Ergon Grips
  46. #446
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by noose View Post
    Tubeless won't fix that. Maybe a different tire or a wider rim could get you there but -20 psi is approaching the limit for most situations IME.
  47. #447
    Quote Originally Posted by J.B. Weld View Post
    Well my HD 2.35 trail star for the front should be here tomorrow. Maybe I'll get something else for the back too. I would love wider rims but may have to wait for a while.
    Sent from my SM-G920W8 using Tapatalk
    2015 Giant Trance 3
    Ergon Grips
  48. #448
    So far 18 psi is working fine on the new HD TS on the front. No squirm and much more grip than the NN Performance it replaces. The rear NN Performance really can't keep up now so I ordered an HD TS SG for the back and going tubeless too. Tubeless and thicker sidewalls should help with rollover and pinch flats I am bound to get running around or just under 20 on the back.
    2015 Giant Trance 3
    Ergon Grips
  49. #449
    Jul 2014
    I'll just add this
    175lbs with gear
    2015 FUEL EX9
    Bontrager Rhythm Comp tubeless
    Bontrager XR3 experts 2.3 front and rear
    Took my bike in for some work, they trued my wheels and replaced valve stems. Got the bike back, go for a ride, terrible. Felt every root, every bump, spinning the tire trying to climb, and worse yet, wiped out 3 times on slower turns.
    Get back from my ride, check pressure, they had me set at like 35psi. Dropped it to 25psi, went back out, and it was smooth as could be, quiet, tons of traction everywhere.
  50. #450
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    Quote Originally Posted by Tillers_Rule View Post
    Historically:
    50F/50R
    35F/45R
    Now I'm at 35F/40R. I've found anything less in the rear and the tire distorts too much, I can go a bit less in the front but this combo seems ideal for me for now. I'm 215 loaded up. Picking up a new bike here, a 29", so I'll get to play with PSI again!
    Interesting looking back and what I was riding with almost exactly 4 years ago.
    Since then I got the RIP9 and put the 26'r to the side collecting dust. Cleaned it up a couple months ago, threw some wider handlebars on it and dropped two of the front chain rings (would only ever use the middle ring).
    PSI for my Niner is usually ~34R and 31F. Now that I'm back on the 26'r I've been playing with it's PSI, last time I think I was at 41R and 34F.
    My riding has improved and style has changed. I used to just blast through the trails as fast as I could. Now we jump, try out skills at balancing, work on sections, etc.
  51. #451
    Reputation: targnik's Avatar
    Jan 2014
    I weigh 235lb's in my birthday suit...
    I also advocate for the tyre determines the required pressure.
    2.4's I've run in the past @ 22-24psi... 2.35's = 23-25psi... 2.3's = 24-27psi... 2.2's = 28-30psi...
    Plus I run tubes... I get a flat once a year, on average. I run protection variety tyres only. Little extra weight for peace of mind.
    Sent from my kltedv using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
  52. #452
    Current setup,
    Scott Spark 760
    a 500ish gram tire.
    a 700ish gram tire.
    I'm the same weight as you and settled in at the same pressure on tubeless HD trailstar front and same tire but in Supergravity on the back. Pleased with grip and ride quality over the rough stuff.
    Sent from my Nexus 7 using Tapatalk
    2015 Giant Trance 3
    Ergon Grips
  53. #453
    Nov 2014
    Quote Originally Posted by Gregon2wheels View Post
    I run pretty much max pressure of whatever tire im on. Currently Ikon 26 x 2.35 @ 60psi and in my experience the skitish behavior of high psi can be overcome by smooth body control and good sense. I do give up some bite on climbs and on some of the hairy corners I take them a bit slower but everywhere else, i'm flying way faster with the increased pressures and not having to pedal so much to maintain speed either. I put down a fair bit of mileage each year and the added bonus of almost never flatting out from tubes and high psi is a double bonus on a 100mile tour. I fly over roots and rocks and hang on tight, set the suspension on the soft side with lots of rebound control to do the job it was made for instead of relying on the tires as springs.
    Different strokes for different folks.
  54. #454
    Armature speller
    Sep 2004
    Wow.
    I'd consider 24psi as far to high for a front 26x2.35 Ikon.
  55. #455
    LOL! That's a bit like the guy over in the Specialized forum that said his 29x2.3 Fastrak (which actually measure out to a shy 2.2 btw) felt 'supple' at 2 bar (29psi) and his 71kg (156lbs)...
    supple he said...
    Anyway, not to discredit urban commando...what happened to the data that said that lower pressures actually attributed to faster times because the tire wasn't being deflected as much?
  56. #456
    Nov 2014
    I figured that post would pop some eyes open and invite the hecklers. Theres nothing supple about my set up thats for sure. Its skittish, but its fast and durable. Also worth noting on loose gravel the high psi is BRUTAL for wash outs around corners, thats probably where they are at their worst. On dirt or even mildly wet loose dirt its a handful but manageable and fun too. I also really like the nevagels @ 50psi on loose terrain they corner excellent, climb and roll quite well but only when its loose. Those tires are slugs on hard surfaces imo. Also in the 2.35 btw.
  57. #457
    I'm not meaning to heckle you urban commando. Your post just reminded me of that other one. Actually the way you commented about it, relayed effectively that you were dialing the suspension to help compensate and that it was still a compromise.
  58. #458
    Reputation: omarlin29's Avatar
    Jan 2017
    i run 35 rear 30 front with 2.3 geax sturdy's on my hardtail
  59. #459
    Jun 2014
    Quote Originally Posted by omarlin29 View Post
    How much do you weigh? 250?
  60. #460
    I want to run 16f/20r but am worried about rolling the tire right off the rim. I run 20 and 23 right now without squirm at slower speeds but am riding faster trails starting in the spring.
    2015 Giant Trance 3
    Ergon Grips
  61. #461
    Interesting that he is running very close pressure to me. Much faster though which increases my confidence that I won't lose a tire. https://youtu.be/RnoA05c-_os
    2015 Giant Trance 3
    Ergon Grips
  62. #462
    Mar 2017
    Hi, with 220lb ( bicycle + me) and 2.35 tire, i run 21.2f/23.4r for xc, and 24.9f/27.5r for smooth rolling on good roads.
    I use this android app that calculates pressure with 15% or 18% drop. https://goo.gl/0laa5O
  63. #463
    Quote Originally Posted by tramuntana View Post
    23.4? That's crazy! No less than 23.6 for me.
    I brake for stinkbugs
  64. #464
    Two wheels are best
    Reputation: DM-SC's Avatar
    I haven't read all of the posts in this thread so I apologize if this has already been discussed...
    I've found that comparing tire pressures are problematic, given that tire pressure gauges give such a wide range of pressures. Your gauge may say 24psi and mine could read more or less.
    I had two gauges of the same brand that I purchased at the same time and one read 3-4psi more than the other. Which one was correct? Where either of them correct?
    Never be afraid to try something new.
    Remember amateurs built the Ark.
    Professionals built the Titanic.
  65. #465
    Mar 2016
    most likely neither was correct. You should just use one of them, figure out what pressure works best for the trail on that day and in those conditions, and you will constantly have to adjust for each ride (especially as ambient temperature changes so much). It may seem stupid or not precise enough to grab your tire and squeeze, but because gauges vary so much you should try to memorize how your tire feels at your ideal pressure, so then you can use that as a rule of thumb when using other pumps.
  66. #466
    Reputation: frenco's Avatar
    Jan 2017
    I weight 210lb/95kg, ride i27 rims, use 20 psi rear and 19 psi front with Conti RaceKing 2.2 tires in tubeless configuration.
    With the previous i19 rims I had to use much higher pressures to prevent the annoying tire rollover effect
  67. #467
    Jun 2017
    Unique formula for me.
    Find some edge block... or sharp rock in that shape .^.
    -Lock out front fork
    -Put front tire on midle of rock
    -Press front brake on max
    -Holding handlebar - squeeze that front tire on peak of rock-block or whatever.
    -Push That tire as max as as u can on that rock.
    And set preasure, on that level, where u are able with all your strenght to squeez front tire not more than half off travel to edge of wheel. This will be preasure for all around.
    For max grip and downhill go on 80% of that travel... if u belive in your wheelset and tires ... and if trail is not sharp rocky and u have tubeless go on 90% or even more of travel. But be ware
    For rear preasure add around 15% more psi/bar than on front.
  68. #468
    Aug 2013
    I've read all through this thread and my main question is "How can it be possible that my experience is so insanely divergent from every other post here?" I am 50 years old. Been riding MTB for 30 years. I am ~200lb. Vast majority of my time has been spent on 26" tubed tires. If I have less than 60 psi in a 26 x 2.2(ish) tubed tire I will flat on that ride. Every time. I can get away with less in a 29x2.3 tubed. Maybe 50 psi. I recently decided to get modern and bought a new bike. With 27.5x2.8 on sun duroc 40 rims I was getting away with 35-40, though I did flat the front once. The 2.8's felt lifeless and sluggish, though they did have great traction. Felt going to 2.4's was a great time to also try tubeless. Ardent/HRII. Shop recommended 30 psi. I think they were being conservative. I, being very conservative, went with 40 psi. Shakedown proof of concept ride ~1hr felt scary, bottoming on rims, squirmy rear coming out of corners, but no flats so why not give it a shot. 30ish mile out and back (on admittedly rooty, rocky trail) at 40 psi. Nearly constant pranging of rims, all kinds of squirming in corners (enough that I ate shit a couple of times when the bike wouldn't hold a line), but no flats. After two rides the rims are pretty much trashed. They'll never be true again but can probably be made rideable.
    How can anybody, let alone ALL of you, be riding sub 30 psi? Granted I am big (6-2/200), posess little finesse and less inclination to use what little I have, and ride chunky trails. But I am also old = relatively slow and cautious. I read these posts like, "yeah, running 18f/22r with tubes and no problems" and Dude. You and I live on different planets. 18 psi I'd flat at the trailhead. Seriously. Somebody explain this to me.
  69. #469
    Armature speller
    Sep 2004
    Is your gauge 20psi out?
    I run 22psi front and 24-26psi rear on the 26" at about 185lbs.
    Never pinch flatted yet.
    On the 29er, I can run as low as 18-20f and 20-22r.
  70. #470
    Aug 2013
    no problems with gage accuracy. 26 with tubes=60psi or flat. thats been proven true for me over decades of riding. less experience on different wheel sizes. only had a niner 2 years and the new 27.5 a few months. your pressures... you've got to be kidding me. that's got to be tubeless. with tubes id flat immediately, like on the first bump at those pressures. Tubeless it'd be trashed rims after one ride for me. are your trails super buff? mine are scattered with fist size + square edged embedded rocks, enough that it's not feasible to try to avoid them all... I tend to miss or loft over the bigger ones and plow through the rest.
  71. #471
    Aug 2013
    also the steering is scary. feels great until vrrrrpppp and the whole wheel shifts a couple inches over and I feel and hear the rim hard on the ground and its all vague and unpredictable, like riding a flat tire. ok when just the back does it as that tends to just tighten up the turn a little, but the front rolls off and I am all of a sudden blowing off the trail on the high side of the turn
  72. #472
    Quote Originally Posted by oldgearstillrolls View Post
    I don't know, you say your gauge is correct so I'll take your word but just realize that you are in the extreme minority and those are some very unusual tire pressures to say the least. "back in the day" when crappy 1.9 tires were the norm I'd run them in the 40's to avoid pinching but I can't imagine running a 2.2 tire @ 60psi. Actually I can't envision riding a 2.2 tire @ 60 psi under any circumstance, even on the road.
    I'm pretty skinny but I know a lot of guys your weight and more that keep their tires in the 20's and they do not ride conservatively. Time is ticking, you owe it to yourself to get some good tires and run them at reasonable pressures, no way could you bottom out a rim on decent 2.3 tires @ ~30 psi even if you were a very aggressive rider.
  73. #473
    Aug 2013
    Ok I'm an idiot.
    I went and checked my pressures again. Rear was lower than front. I think it burped at some point yesterday when I was wallowing through the corners. Both my gauges matched each other on both tires. But I decided I cant possibly be this different from the whole rest of the internet so I set the regulator on my compressor to 40 psi and dug through my crap and found a schrader adapter and used that to check pressure - both bike gauges are reading wrong by about 15psi. So my "40" was probably about 25. Thanks for the feedback. I don't think I'd have guessed I had two bad gauges bad by the same amount without hashing through it here.
  74. #474
    Armature speller
    Sep 2004
    My "safe" pressures (tubed or tubeless) for rocky races are around 24f/26r.
    We have one 20min descent that's called Boulder Valley for a good reason.
  75. #475
    Ok I'm an idiot.
    I would think your bike pump gauge and your tire pressure gauge would read much closer.
    I bought a digital tire pressure gauge, and my analog bike pump gauge tracks pretty closely to the new digital gauge.
    I trust the new digital gauge as my true tire pressure.
  76. #476
    Ok I'm an idiot.
    Are you using the old "stick" type of tire gauge? Those are notoriously inaccurate.
    You should consider getting a digital gauge or an analogue dial gauge. They are more accurate and more precise.
    I am 200 lbs with gear. I ride on 27.5 x 2.6 tubeless tires. Front pressure is 21 psi and rear pressure is 25.
  77. #477
    Mar 2011
    Quote Originally Posted by Rockohaulic View Post
    Are you using the old "stick" type of tire gauge? Those are notoriously inaccurate.You should consider getting a digital gauge or an analogue dial gauge. They are more accurate and more precise.
    My stick gauge and two digital gauges read within 0.5 PSI of each other. The dial gauge on the floor pump on the other hand can miss by 5.
  78. #478
    I stand corrected! That is an accurate stick gauge.
  79. #479
    Oldgearstillrolls
    I'm confused. Your other post just before this said that you did figure out that your gauges were both off by at least 15 psi?
    That would answer a lot of your questions........
  80. #480
    Armature speller
    Sep 2004
    Yes, in his LAST post, he said he found out they were out by 15psi.
    You might have the wrong poster in mind?
  81. #481
    Yes you are correct.
    It was the same poster. But for some reason, when I wasn't logged in, the post where he said no problems with gage accuracy was displayed as his last post.
    Confusing.
    Anyway, makes more sense now. Hope he got it all straightened out.
  82. #482
    Reputation: Karlewski's Avatar
    Dec 2016
    WOW,
    I ride steep rooty rocky trails in CO, not really XC, 24" drops at least, high speeds till the rocks get to be about grapefruit size or bigger. My weight all up is 165ish, tires are 29er Nobby Nicks 2.35 rear @ 19PSI and 2.6 front @ 16PSI tubeless on 29mm internal carbon rims. I ride very "light" preloading, pumping, hopping and picking clean lines but there's no avoiding many drops and mistakes do happen. I have not flatted or hurt a rim on this set up for 1 full season of major adventure. I am not burping either during fast cornering.
    Climbing traction is AWESOME though a well tuned suspension must be helping there.
    I think widish rims (about 30mm), quality high volume, 2.3-2.6" side wall protected tires(EXO, snakeskin...), and proper suspension tuning should allow riders my weight to be in the low 20's PSI. The one extra thing I use is the foam Huck Norris Rim protector in my rear tire just in case, I love my carbon rims!
    I have been extremely happy with this set up, climbing and descending. On anything but smooth trails low pressure is king for me! Check out what Schwable says on rolling resistance, https://www.schwalbetires.com/tech_i...ing_resistance
    My next wheel build will be as pictured. Huck Norris DH rim protector, 28mm internal, Ultralight Carbon Nextie rims, and a 2.35 Vittoria TNT Barzo rear tire. This light and fast set up will be used on friendlier trails and PSI's in the low 20's. Higher then usual for me on smoother trails with more fragile rims . . .
    As one poster above said, time your descents at various PSI's, your fastest time ought to be the lowish PSI run with a mellower feel to the ride. Use the mellow feeling to relax and bust a move! Hop a water bar or boulder, pre-load/pump then release and float over the little rocky chattery section, use the sidewall of the trail to ramp down and ease the pain on bigger drops, find the "bridges" and unweight over the holes. In simplest terms, whenever it gets interesting, keep your ass off the seat, LOL!
    Attached Thumbnails Attached Thumbnails Tire pressure for all around XC riding?-img_0226.jpg
  83. #483
    Feb 2018
    my setup:
    Rocket Ron 29er 2.25 front and back
    22mm inner width rims
    Rooty and muddy terrain
    rider weight: 145pounds
    Front 18psi
    rear 19.5psi
    could not imaging riding any higher pressures!
  84. #484
    Armature speller
    Sep 2004
    Quote Originally Posted by dieselhead View Post
    my setup:
    Front 18psi
    rear 19.5psi
    I couldn't imagine being 145lbs.
  85. #485
    Feb 2018
    HTML Code:
    why are side wall proteced tyres beneficial over non side wall protected tyres (apart from puncture resistance)?
    non protected tyres are significantly lighter and give a much lower rolling resistance:
    https://www.bicyclerollingresistance...speedgrip-2017
  86. #486
    Go tubeless yesterday with sidewall protected tires EXO, snakeskin etc. That will let you run lower pressure without pinch flatting or cutting sidewalls and handle cactus etc. 185lbs geared up and 22f and 25r and haven't flatted in two years on two different bikes. I ride light granted but almost all tech sharp rocks in Phoenix all winter so far.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    2015 Giant Trance 3
    Ergon Grips
  87. #487
    Armature speller
    Sep 2004
    Read a little further...
    Ok I'm an idiot.
  88. #488
    Okay my bad. That's better but still go tubeless unless I missed that also.
    2015 Giant Trance 3
    Ergon Grips
  89. #489
    Dec 2016
    HTML Code:
    We're entering the trade off zone here. Ideally, rolling resistance is born of supple casings with good elasticity or "rebound" like a basket ball, actually returning energy. Great for bunny hopping, trials bike bouncing around OR XC racing where the tire actually absorbs smallish rocks into the tire, slowing the bike, but then it recaptures most of that energy when the tire rebounds back into shape actually pushing off that same rock/trail imperfection as the tire goes past it. . .For those situations supple casings are key for retaining energy, the tire rubber compound also matters, whole other story about elasticity there.
    On the other extreme, hauling butt through a gnarly steep rock garden is most secure with highly dampened casings, ie stiffer, energy absorbing, dead feeling tires. Those characteristics keep you from pin balling off every mean chunck of trail allowing for much greater control. Here obviously suspension helps too but, not so much laterally, side to side.
    For the do it all trail rider we're always better off with puncture resistance; that will get us piece of mind. But, a balance must be met concerning the issues above and even more . . . somewhat stiffer side walls (reinforced) gives more tire support allowing for lower PSIs and efficiency (absorbing that rock in the first place), less tire squirm when cornering hard, improved traction and better protection/support to keep from bottoming out on your rim. Wider rims help support any side wall too.
    The short answer, puncture resistant side walls gives the added benefit of increased tire support for running LOW PSIs and getting all of those associated benefits.
    The trade off for me / us. I love bouncing/hopping up and over trail obstacles climbing and descending, rebound is my friend (personally, I hardly dampen my shocks and that helps me climb) supple casings are great for that. Often I can't spring over everything and have to plow, here some tire dampening is a good thing, especially on the hair raising decent! More like DH/motocross style. In ALL the cases a low PSI (traction and efficiency) is my friend as long as my rims don't ever bottom out and front tire squirm is absent.
    Way long winded here . . . in a perfect world with no trade offs, I'd have super light supple casings for my climbs and heavier stiffer, think more supportive and dampening, for the high G corners and widow maker descents.
    On a HUGE constant climb, think 3k feet up roughish terrain to the continental divide, I'll set 14-15 PSI on a 2.6" rear tire, normally foolishly low, and moon buggy my way, up absorbing the chuck. No way am I going to go back down with those PSIs though, I love my rims, out comes the pump. LOL!
    Time waster theoretical babble . . .
    Theoretically now, I have been thinking way to much over this stuff and I own both a Plus bike and XCish trail bike. In a perfect world with only efficiency and ride quality in mind, I'd run my tire size and PSI's to match the size of the trail debris I plan on running over. If I plan on running over a ton of 2" rock/trail chatter it would sure be cool to have a 3" tire set up to literally swallow 2" rocks never pitching the bike up/altering it's angle of attack/wasting energy at all. There is no perfect world, trail conditions vary wildly and often huge climbs can make the 3" tires unpleasantly heavy. PSI's would HAVE to increase for descending and the odd bigger rock hits. Food for thought though, with new molecular level materials construction and huge innovation these obstacles can be over come.
  90. #490
    Mar 2011
    Don't forget the tread. Deep spaced knobs penetrate the earth more and that creates more friction, compared to faster treads that stay more on the top of the soil.
    More important on the back where there is more weight on the tire.
  91. #491
    Reputation: Halfabrain's Avatar
    Jun 2014
    Tire Tension vs Pressure (T=PxD)
    I looked back through 2016 posts on this thread and didn't see any references to this video which is the best I've seen r/t wide vs. narrow tires and psi experimentation.
    I have typically run a smaller rear tire for faster rolling - but maybe I've been wrong all along? I tried a Minion DHF/DHR Wide Trail (2.5) and felt the larger rear was dragging so changed DHR to an Aggressor (2.35). On 27.5 Ibis 738's, 35mm internal rim width.
    As most folks, I run a slightly lower front pressure than rear...or so I thought! (18psi front and 20 psi rear).
    Turns out my 'tire tension' was exactly the same! (which may not be a bad thing).
    Pressure x Diameter = Tension
    Aggressor[R] (20psi) x (2.35[R]/2.5[F]) = 18.8psi
    So, if I have the DHF at 18psi = slightly less tire tension in front than rear.
  92. #492
    Dec 2016
    That is an excellent video, 2nd time seeing it for me, first time I have considered casing tension in depth. If I understand it correctly the casing tension truly dictates the amount of casing deflection. Simply put, how much the casing will absorb or conform around a trail imperfection.
    Here’s the “thing” if you have bigger tires/deeper tires, you can afford more casing deflection before that trail imperfection is going to contact your rim so, running even lower pressures would seem reasonable. That said, obviously there is about 2x the weight on our rear tires and that is also a huge consideration. Tire volume is yet a different consideration. I would assume the air pressure in a lower volume tire would ram up quicker with tire deflection. . . The clear conclusion, trials is likely a simpler way to arrive at optimal pressure for any given tire but, recognizing the variables with greatly improve your trials. . .
    On tire tread, clearly tread depth matters but, the elasticity of said tread rubber also plays a roll. Highly elasitc nobbies, to a degree, will return the energy used to compress them. Not all rubber is created equally and a huge area of tire developement in general but, grabbing and displacing dirt will always be an additional cost as stated above. . . I like semislicks for this reason on xc trails.
  93. #493
    Jan 2014
    Here's a tire pressure question I'd never considered before - Do you guys find that in addition to size, conditions, etc. that tire pressure is a function of tread count?
    For example: assume a Maxxis HighRoller II - one in 60tpi and another in 120tpi, everything else is the same. Are you running the same pressure in both tires?
    I'm tempted to think that 60tpi tire will tolerate lower pressure than a 120tpi tire. The 120 should be more supple but, other things being equal, more prone to damage. Of course in the case of the example HRII the difference in thread count also comes with a different tread compound.
Members who have read this thread: 187
