Results 1 to 8 of 8
    West Chester, PA
    Tire permanently deformed after a burp?
    Yesterday I had a pretty severe tire burp/life flashing before my eyes moment. Now the tire has a bad wobble, even though its seated evenly all the way around (based on the reference line above the bead). I even tried inflating it to max pressure and sitting it in the sun all day. Think the casing is warped forever?
    Reputation: supersedona's Avatar
    Dec 2012
    What pressure are you running? How old is it? While it is possible the tire has cord damage or it is delaminated it is unusual.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    West Chester, PA
    It's been sitting at 40 since I got home yesterday but I was running 25 when it happened. I got the tire caught between two rocks and my momentum carried me through, but the tire ripped off the rim a bit. I've been pulling it and yanking on it with no improvement. Guess the casing is damaged. There's no bubbles or sidewall damage.
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    If you completely de-seated it (rotate on rim), and it still is out of whack, then I'd replace it. Too many other things to worry about on the trail besides a gimped tire.
    West Chester, PA
    I'm replacing it. Safe or not, I can't ride with the front tire bouncing.
    Just wondering if anyone's had a tire casing deform like this. It's a specialized captain control by the way.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I just had it happen yesterday. I was powering up the side of a berm and rolled the tire off the rim. Had to put a tube in it to get home.
    Afterwards, I thought the rim was bent and put it in the truing stand. The rim was perfect. Tire is all over the place. It's getting replaced.
    I like turtles
    Dab-O-Matic
    Quote Originally Posted by 92gli View Post
    Currently running on the rear, and had zero problems. Depending on it's age, could be a defective tire. I would take it back to the dealer and see what they think.
    Quote Originally Posted by NYrr496 View Post
    Had the exact same thing happen with a 2.4 Trail King UST about 2 months ago. Destroyed the rim and had the wheel re-built, mounted the old tire and almost flipped because it looked like the brand new wheel was out of true. Turns out it was just the tire.
  1. Is a burp equivalent to a pinch flat??
    By dirt farmer in forum Wheels and Tires
    Last Post: 09-01-2012, 06:09 PM
  2. fork permanently flexed/misaligned??
    By bluebean in forum Shocks and Suspension
    Last Post: 06-08-2012, 03:13 PM
  3. Morning bead-burp
    By Surfdog93 in forum Wheels and Tires
    Last Post: 01-21-2012, 12:05 PM
  4. Tire Burp, Clyde Rider
    By 14Stone in forum Wheels and Tires
    Last Post: 09-01-2011, 10:40 AM
  5. 2001 P-Bone Shock (permanently lock?)
    By cboyd1976 in forum Cannondale
    Last Post: 07-20-2011, 09:03 PM
