Results 1 to 2 of 2
    Thicker than standard inner tube but not downhill thick?
    I'm running a thick Slimetube after puncturing a tire that Stan's could not plug up so was wondering if there are any tubes available that are less thick than the Slime but thicker than a standard tube?
    I remember once looking at a site that had tubes that seemed to be thicker than standard but not downhill tubes but that was probably a couple of years ago. This Slime tube is HEAVY! I'd rather
    run this tire for awhile.
    sof
    sof is offline
    Jan 2013
    I just bought some Airwave DH tubes: Airwave DH MTB Tube | Buy Online | ChainReactionCycles.com
    They're not as thick as I expected (probably because they're cheap), which may put them in the range you're looking for. Only been out on them once on single ply tyres, gave them a hell of a beating and was running around 35-40psi. So whether that's worth anything, I don't know.
