Results 1 to 12 of 12
    New question here. That's it, I'm changing from 2.1 Conti Explorer Supersonics to 2.35 Blue Groove??
    I've not had much experience using different bike tires. My past and current bikes always seemed to have fairly narrrow and fast rolling tires: 2.1's Bontrager ST2, IRC Serac XC, and currently Conti Explorer Supersonics.
    I always thought that low rolling resistance was preferable over slower knobbies. Well, I rode my Blur for an hour yesterday with the Conti's and am actually thinking about a change. While the Supersonics seemed very light and fast, I noticed was front traction during turns had more drama than I wanted. Additionally, the rear tire in many cases would slide a lot.
    So I got home wondering if getting something with more traction would help. I briefly read about the Blue Grooves and was thinking of making a change to 2.35 F and R. I ride Sierra Nevada trails -- a lot of dry high desert hardpack with rocks and some minor roots.
    I don't race and am looking for a happy medium in tracktion and decent speed.
    ALSO -- where is everyone buying their BG's? It seems everyone is selling them for $44/ea!! Thanks.
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    You might want to try the 2.1 BG's first. (They're closer to a 2.2 in acutal width) They're about 100 gr lighter apiece than the 2.35 (which are closer to a 2.4 in width, check to see if they'll fit on your bike), and shouldn't give up too much traction. I'm running the 2.35 Nevegals in CO (mainly sandy gravel over rocks & hardpack) and loving them, but thinking about switching to the narrower width and lighter weight. I think the 2.35 is overkill for my riding style. (Think nearsighted little old lady) Love the big volume though!
    hammerheadbikes.com is selling BG and Nevegals for $50 a pair right now. Stock up!
    Quote Originally Posted by coolhandluchs
    Nearsighted little old lady eh? Sounds like me too -- I've yet to wear my glasses! Wow, I didn't know the 2.35's were closer to 2.4 -- that might be an issue with the Blur rear clearance. Looks like I'll try the BG 2.1's instead
    Thanks for the link -- great price!
    Quote Originally Posted by SCHUMACHER
    Yup. I ride a 5" travel bike, not because I'm good enough too, but because I can now keep up with people on 3" travel bikes and hardtails
    It's the best price I've found so far. Hats off to Charles. I'm looking at a BG front/NVG rear 2.1 setup, as soon as I can sneak $50 away from my wife
    Complete Bastard
    Reputation: mward's Avatar
    You might try conti vertical pros. Similar tread pattern, more grip, and fatter, but not superfat like these other tires you've mentioned. I run explorers on my race bike and love the grip, but the verticals have even more. However, since you live in NV, my recommendation may be bollocks, because we ride on completely different terrain.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I 2nd the 2.1
    the casings are larger then most 2.2's. Im using a 2.1 Nevin the back and a 2.3 fat albert or a 2.1 BG up front depending on the surface. IMO a 2.1will be plenty in the back but you may want a tire with a larger casing up front.
    Reputation: shiggy's Avatar
    Dec 1998
    The BG 2.10 would probably be big enough for you. The casing is about 25% larger volume than the Explorers. I doubt that the 2.35 will fit in the rear of the Blur anyway. You could run the BG 2.35 front / 2.10 rear. I also like the Nokian NBX 2.3 for the conditions you ride.
    mtbtires.com
    Thanks for all the replies everyone. I'm going to test out the BG's and let you know what I think.
    I managed to get in a few rides with the Blue Grooves this weekend. My impressions so far -- they are indeed GOOD tires but they do have some shortcomings.
    I tested a 2.35 F and 2.10 R on my Blur. Recall that all the tires I've used have been fairly low profiles so the BG's would be my first knobbies. The 2.35/2.10 combo proved to be heavy, slow and ponderous on flats. And on ocassions when riding through loose soil/[hardpacked] top sand, the tires would loose control and almost washed out. However, downhill speed and stability was incredible. But downhill only cosists 1/3 of my typical ride. That said, I changed the F to the BG 2.10 and R to the Exp Super 2.10. This combo proved to be better. Lighter and faster than the 2.35, the BG 2.10 climbed well, rolled over rocks well, cornered well, braked well, dowhill well, and cruised well (once up to speed). However, I still felt it was a little heavy gave up too much pedaling efficiency -- it was hard for me to get it up to speed and keep a stable cadence on the flats. I guess they "roll fast" for a knobbie -- but this is my first knobbie!
    All in all, I'm impressed but not convinced that I should stick with the BGs. And I really want to like them considering all the positive comments on MTBR! It's funny that upon testing these tires, MBAction magazine came out with a comparison test. I'm not going to fully give up on the BG's yet, but I do want to try the Nevegal Lites (1.95) based on the impressive MBA rating. I'll keep everyone updated again. Thanks.
    Dec 1998
    The Stick-E rubber is not fast rolling on hard surfaces. I notice it on pavement/hardpack but not on softer/looser terrain.
    mtbtires.com
    Shiggy --
    If that is the case, can I presume the (Nevegal Lite material) DTC will increase pedaling performance and is fast rolling? Can you explain to me the merits of DTC vs. a single compound like Stick-E? Finally, will I be giving up anything going with 1) DTC and 2) a smaller tire width?
    Thanks for the help.
    Dec 1998
    Shiggy --
    The DTC tires have a harder faster rolling, longer wearing rubber in the center and the Stick-E rubber on the edges for better grip. The "Lites" also are a shallow tread design that is more suited to racing than general trail use.
    I found that raising the air pressure 3-6 psi in the rear Nevegal 2.10 helped the rolling without too much (but noticeable) traction change in the rough.
    mtbtires.com
  1. Yet more Blue Groove questions.
    By kapusta in forum Wheels and Tires
    Last Post: 06-23-2004, 03:42 PM
  2. Blue Groove / Nevegal 2.35 combo rocks!
    By Rollin'in'Zona in forum Wheels and Tires
    Last Post: 06-18-2004, 06:28 PM
  3. Kenda Blue Groove 2.3 vs Cortez 2.4
    By steelbike in forum Wheels and Tires
    Last Post: 06-04-2004, 09:14 PM
  4. Schwalbe vs Blue Groove tire size question?
    By ScottW in forum Wheels and Tires
    Last Post: 05-04-2004, 02:07 AM
  5. Kenda 2.1 Blue Groove,..how well does it shed mud?
    By Gnarlygig in forum Wheels and Tires
    Last Post: 02-25-2004, 02:35 PM
