• 03-20-2013
    Surly Knard 29 x 3 on Kris Holm Freeride 47mm Rim
    What's up all. Just wanted to share this piece of info with you, because I'm sure there are some who would like to know.
    Here is what Knards measure out to on the KH Freeride 47mm rims.
    Tread: 74.5mm @ 18 PSI
    Casing: 71.5mm @ 18 PSI
    Almost spot on with the knard/rabbit hole specs.
