Good day
Wanted to get some feedback from riders who have ridden on a set of the Sun Ringle Charger Expert wheels.
I had picked up a set of these wheels in the 26 inch version for my Giant Reign. They look and sound great, fairly low weight, nice engagement, and ready to run tubeless. What is not to like ...
Well, it might just be me not certain. Despite having some failures with these wheels this is not a rant, as when they work, they are great, and customer service has also been good.
1st issue, constantly dropping chain off lowest gear into spokes. Bike setup was spot on. Contacted Sun Ringle support and was sent a stainless steel alxe and new freehub. Installed and wheel worked fine for a little longer.
2nd issue, started having issues with hub and not free-wheeling while coasting, felt like having a branch getting stuck in rear derailleur. Took wheel apart looked ok. Contacted Sun Ringle customer service again and was asked to ship the rear wheel back in. I sent the wheel back in and was told they had found a crack in the shell that was causing issues with the pawls and the free-wheeling issue. Sun Ringle rebuilt the wheel with a new hub. It was a Disc Jockey hub, which is what I was told is what the Charger wheels are built with.
3rd issue - Now have almost 10 rides on the wheel from Nov 12 - Feb 13, as I switch between the Charger wheels for pedally rides with smaller tires and a Hope/Flow with larger tires for more techincal rides. Part way down the trail the issue with the the free-wheel not working well was happening. Had to ride out as single speed peddling so the chain would not rip the derailleur off. Pulled the wheel off when I got home and wiped it down to find a very obvious crack in the hub shell. I have emailed Sun Ringle customer support and will wait to see what happens. Pictures attached to show the latest issue.
I have never had issues with other hubs in all my years of riding. I once had to replace a Shimano freehub on an old Shimano LX or DX hub and once had to replace the springs on the pawls on a Hope hub, that's it. I don't ride that hard, my wheels stay pretty close to the ground (my trail bike might get 1 - 3 feet of air occasionally if there is a smooth landing). I have been trying to climb a little more to get in shape, so I really doubt I am over-torquing the hub, if such a thing is possible.
Comments as to why the issues.
Results 1 to 8 of 8
Hot DealsContestsLatest Mountain Bike ArticlesVideosMTBR on Facebook |
LinkBack URL
About LinkBacks
