    I am Walt
    Reputation: waltaz's Avatar
    Sun 0 Degree XC Tire Mounting Issue?
    I'm looking at a wheelset with these rims, but heard from one experienced user that it is just about impossible to mount tires to them. Could scare me away...
    Any other feedback? Are these rims THAT difficult to mount tires to? They'll be laced to Surly News with Velociraptor 2.1's.
    Luddite technophile
    Reputation: kgginslc's Avatar
    Yes - tire mounting is very difficult. I wouldn't buy them again.
    Basura Blanca
    Not that bad. Yeah, they're tight, but as long as you make certain to keep the bead in the center of the rim (where the diameter is a bit less), you can mount/remove kevlar-beaded tires without too much of a struggle. You may need to use a tire iron, but they're not that bad. YMMV, especially if you use a tire with a wire bead.
    - Joe
    Do what NuMex said plus get a set of steel tire levers from your LBS and you'll be fine.
  1. Tires at MEC
    By turbo ultrasport in forum Eastern Canada
    Last Post: 12-04-2004, 04:00 PM
  2. You make the call...xc race tire...
    By Miker J in forum Wheels and Tires
    Last Post: 07-17-2004, 07:00 AM
  3. XC tire advice...
    By Xyzzy in forum Wheels and Tires
    Last Post: 06-24-2004, 07:50 AM
  4. Tubeless tire mounting solution.
    By B R H in forum Weight Weenies
    Last Post: 05-14-2004, 10:42 AM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
