Results 1 to 10 of 10
    We get titles?
    Reputation: upNdown's Avatar
    Suggestions for 20mm hub? (xpost downhill)
    I'm looking for suggestions for a hubset or wheelset that will have a 20mm front hub and QR rear. Cheap is good. Disc obviously.
    I had a wheelset built on WTB Lazer Lites, but after riding the bike, I realize I want a dula crown fork. For this, I need a fron wheel with a 20mm hub.
    So, any suggestions for good CHEAP 20mm hubs?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by upNdown View Post
    Hard to beat a Hope. CRC has the best prices.
    mtbtires.com
    Reputation: 006_007's Avatar
    You da man Shiggy
    www.derbyrims.com
    Reputation: derby's Avatar
    Atomlab Pimplite hubs. Light weight, stiff, very quick engaging 6 pawl/60-click. Low cost.
    The rear hub needs an available adapter, 12mm through-axle to 10mm through-axle, to run in QR dropouts.
    The wheel sets aren't very light, made to be downhill durable, the rims are over 600g. I'd build with other lighter rims for trail use.
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    White Industries has a nice, stout 20mm thru front hub. You could always lace that up to a Stans Flow EX rim. That would be a rigid wheel with a great ride quality due to the wider rim.
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    Dec 1998
    Quote Originally Posted by 006_007 View Post
    You da man Shiggy
    They don't get it
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    They don't get it
    It is fun though isnt it?
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    Magura
    Reputation: Aresab's Avatar
    If cheap is what your looking for, how about these:
    Sette DH 20mm 32 Hole Hub at Price Point
    I'm using a few of them on different wheelsets, not issue and role smooth...BUT they are not the lightest.
    Reputation: Morpheous's Avatar
    Mar 2006
    Dimension or DMR hub QBP. Inexpensive and solid. plus full convertibility with endcaps.
    2015 Budnitz MTB Ti Limited 650B
    2015 Surly Instigator 2.0 26+/27.5+
