Results 1 to 9 of 9
    Stupid question: Stan's Sealant Injector
    So I don't have a compressor, and my tubeless tires involve a trip to the LBS every time I need to add sealant.
    Here's my "stupid question du jour": If I use the injector to put sealant in through the valve stem, can I inject stan's while the tire has air in it?
    I don't mean at 30 psi, but maybe 10 psi (just enough to keep the bead in tact)...
    This would save me a TON of aggravation since the Stan's seems to dry up after about 6-8 weeks here in dry Arizona.
    Second stupid question du jour: If the Stan's is dry, does that mean it is coated on the tire and will still seal, or should I add more?
    Thank you in advance for your tolerance of my ignorance.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    the bead should stay intact with 0 psi, just remove the valve core, pump in sealant, fill up!
    good luck!
    Okeydoke! Ordering now. Thanks for the info. God I hope this works.
    SPECIALizED
    Dec 2010
    Quote Originally Posted by redmr2_man View Post
    good luck!
    Try not to set the deflated tire/wheel on the ground. If you have a tight rim/tire fit you'll be okay but if not it may separate.
    Sweet. both tires deflated and removed core without breaking the bead... added 4 oz. of Stan's (dries suuuper fast here), put the core back in, and pumped like a mad man... a little sealant shot out along the rim, but they both sealed.
    That $13 is well worth the money and time I save from taking the wheels/tires to the LBS everytime I need to add sealant.
    I guess I will still have to when I change tires (those also get eaten up real fast here), but at least this cuts it in half or so...
    Jun 2010
    Once you learn how to change tyres by yourself, you donīt have to visit your LBS that much.
    Itīs not that difficult. Lots of instructions available.
    I know how to change a danged bicycle tire. lol
    But I don't have a compressor. Which makes getting the bead set on a TUBELESS tire next to, if not, impossible.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by pointerDixie214 View Post
    If sealant shoots out along the bead when inflating you do not have tubeless tires and/or rims. Tubeless tire and rim beads seat and seal easily without sealant or a compressor and stay seated when deflated.
    mtbtires.com
    Jun 2010
    Quote Originally Posted by shiggy View Post
    I have also managed to seat tires with normal floor pump (Stans rims, Schwalbe tyres)
    Like I said: check the instructions and try
  1. No Tubes Sealant Injector Syringe question
    By adamant118 in forum Wheels and Tires
    Last Post: 01-08-2010, 08:06 PM
  2. Do I need a Tire Sealant Injector?
    By Buster1971 in forum Wheels and Tires
    Last Post: 06-22-2009, 05:00 PM
  3. Stan's sealant question
    By GiantCHaDSTeR in forum Wheels and Tires
    Last Post: 05-06-2008, 10:55 PM
  4. A Question about Stan's Sealant.
    By Ronnie in forum Wheels and Tires
    Last Post: 02-14-2008, 03:42 PM
  5. Stan's sealant question
    By wallyh3 in forum General Discussion
    Last Post: 09-03-2007, 02:33 AM
