Results 1 to 9 of 9
    amd
    amd is offline
    Oct 2011
    Strong - Fast - Light: the quest
    Ever ridden a tire that is sub 650g, that is fast and fairly bombproof?
    Ignitor
    I run the 2.35 inch EXO...tubeless 770 grams but has been bomb proof.....2.1 is close to your weight.
    Reputation: expatrider's Avatar
    Feb 2005
    No. But there are a couple around 650g ish that I have found are decent volume with good sidewall protection and make good rear tires: Schwalbe Nobby Nic 2.4 snakeskin pacestar compound; and Maxxis Ardent 2.25 EXO. I wouldn't use them on the front, but good tires out back.
    I've ever ridden on Maxxis Ignitor exc weigh about 500g. I felt fast on that but didn't confident enough to ride on macadam or rocky gardens. When I used it I always avoided on those kind of tracks.
    Reputation: Bike Whisperer's Avatar
    No mention of size, riding style, terrain, trail conditions, etc.
    Kind of hard to make suggestions...
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by Bike Whisperer View Post
    True. This is impossible if you're talking about 29er tires (would have to give up either weight or bomb-proof), but pretty easy for hardpack 26" folding tires.
    Reputation: ianick's Avatar
    I like the Specialized Fast Trak and The Captain tires. The control versions are 650g and 670g respectively. Not a great sidewall for sharp rocky areas but otherwise pretty durable.
    Bicyclochondriac.
    Quote Originally Posted by amd View Post
    There are loads of bombproof tires under 650g.
    The question becomes how much are volume are you willing to sacrifice?
    You will have no problems finding a durable 2.0 at 650g. Good luck finding one in true 2.4 size, though.
    Reputation: CrozCountry's Avatar
    Mar 2011
    I thought its strong light and cheap that you cant find
    For your question, there are a few continental Protection tires under that weight.
    For example, X-King 2.2 Protection (570g claimed)
    X-King 2.4 Protection (630g claimed)
    Race king 2.2 Protection (550g)
    There are many other tires from other companies. 650g is not really super light 26" XC tire these days.
